REVERSE ME
REVERSE ME
StratOS ::
Hm, imam nažalost zopet en puzzle exe problem.
Vem približno kaj dela, vendar pa ne vem kako iz njega dobiti rešitev, ki jo potrebujem.
P.S.: Za tiste z softiceom :
oh boy, if you are reading this then
you must not be made of the right stuff for this problem. you need to get in the
re and examine the asm and follow the program around. OK, I'll give you a start -
it was designed for people to play with in SoftIce, and believe me by the end of
this you might just know a little bit more about asm and SoftIce. :P
Aja, zip fajl programa se nahaja Tukaj
StratOS ::
Hard one, i guess.
Ampak je easy ! ... not
Rdeča kapica
82345 (2282) BigWhale
Začetki programiranja ?
Oddelek: Programiranje
72447 (2285) Tody
Win XP-mali hack?
131584 (1192) CaqKa
.EXE -> SOURCE CODE
111386 (1081) StratOS
Lahko noč, otroci!
72018 (1705) rozica
