Forum » Kaj kupiti » Kje dobim E8400
Kje dobim E8400
McMallar ::
Kupujem E8400. Kolikor sem se pozanimal, ga nikjer nimajo. Mogoče kdo ve, kje bi se ga dobilo?
Because OCT31 = DEC25
McMallar ::
Hvala. Koliko siguren je ta baje?
OZZY ::
Jaz sem dubu isti info od večih trgovin tko da bo kr držalo. Nekje sredi tedna naj bi bilo v trgovinah.
Go with the flow.
McMallar ::
OZZY: hvala. Upam, da bo res...
sej lohk tut tuki napises ceno
IVo ::
Če ti praviš... Trenutna cena (najnižje kar lahko dam) je 210€. Podražil so se in mi ga čist mori... Sm mislu da bo cenej...
So pa na zalogi...
- spremenilo: IVo ()
Hehe, jest vec kot 180€ ne dam...
Ne, a ti to resno? Ti je to kdo povedu, al si se sam spomnu??
LOL
Za 180 EURov dobim več kot 2 komada E2180 in bom imel prav tako štiri jedra
Za 210 € pa dobim 3 komade E2180 in bom imel celo šest jeder!
Overclockers Worldwide Report Heat Problems With Intel Core 2 Duo E8400
Basically, there's not much more to this story than the title: the E8400 series of Core 2 Duo processors might have a heat problem. A consensus among the more daring overclockers is that the thermal diode on-board these processors is very far off from the actual temperature of the processor, tricking overclockers into not giving the CPU adequate cooling, and tricking the motherboard into not turning the fan speed up high enough (if the CPU fan speed is controlled by the motherboard). Intel denies all of these allegations, and their very detailed response can be read here.
For any of you getting an E8400, make sure to give it proper cooling, and to not let it go above 72.4 degrees centigrade.
- spremenil: mtosev ()
Kibby ::
@Dr_M: Ma dej, ce pises take bedarije... se delas neki pametnega bla bla bla... ziher si gorenc
Kibby: pa kaj teb ni jasn? kaj si prsu smetit v to temo? ce nimas kej pametnga za povedat, pejt naprej delat, karkoli pac psihicni bolniki delate.
Kibby ::
Smetis jo ti s tvojim skrtlarjenjem na celi crti... koga briga kolko si pripravljen dati za proc... Cene so kake so in noben jih nebo tebi na ljubo spreminjal ker pac ne mislis toliko placati... raje prilepi kak test ipd., ne pa da tu na velko nakladas kolk si pripravljen dati ipd. pa da isces neke izgovore v bugih ipd... Sicer pa si z zadnjim delom posta dokazal na kakem nivoju si... bravo, kapo dol zate
- spremenil: Kibby ()
Povej, zakaj bi dajal 210€ za cpu, ce se gadobi za manj oz ce ne takoj zdaj, pa cez 1 teden. tuki ne gre za skrtarjenje, ampak za racionalnost. jest ne jokam zarad visokih cen, tako kot drugi, ampak bil je samo pac en komentar. ce je taka cena, nej bo, pac pocakam na nizjo.
In ja, plemenito od tebe, ce mislis, da si nekaj boljsega. Ocitno hoces samo pokazat, da si pod mojim nivojem. Lep dan zelim.
Volta ::
Vsekakor mislim, da nam bodo te serije, ki jih imamo zdaj na voljo, preko zadosti, dokler ali se cene ne znižajo, ali pa intel izda še kaj močnejšega
AlienRex ::
@mtosev Lahko izdas vir tvojega posta? A Velja to vse za E8xxx a samo za E8400?
Dropbox: http://db.tt/Jg5BmDw
No brain - No tumors
IVo ::
DOC...AGT jih NIMA in jih ne bo prodajal po ceni po kateri jih je skoraj kupil... Trenutno samo zavajajo kupce s tisto ceno! Če se pa odločijo za prodajo po tej ceni, pa bodo poslovali z izgubo, sam ne verjamem da bodo...
Turtle ::
agt jih res nima. kar se tiče zavajanja, pa lahko tisti ki so ga že kupili po tej ceni kaj povejo. Ko bodo se cena NE bo spremenila....
lahko me citirate
lahko me citirate
IVo ::
AHA... no lepo da stojijo za svojimi cenami! Zelo pohvalno! Sam je pa tut res da bodo večje dobave šele marca...Tak da se bodo kupci res načakali.
dzinks63 ::
- spremenil: dzinks63 ()
JIM22 ::
dzinks: dej napiš batch/FPO.
Digitalni marketing, nastop na spletu v naročnikovem imenu.
Vsi na FB pridružite se itVision :)
Volta ::
Kdo bi vedel
Vsekakor pa pomoje ne bo takšna atrakcija, kolikor je govora okoli tega procesorja. Je 6850 ali pa 6750 ravno tako zelo dober nakup
McMallar ::
@Volta: 6850 je počasnejši in dražji + 2Mb cache manj.
Meizu ::
Hja, kot da je tale +2mb cache tolk boost no... Je blo že veliko predebatiranega o tem. Pomojem bo po tisti zaslugi kakšnih 5% hitrejši. To je pa tudi vse.
McMallar ::
Cenejši...?
Zaradi cache 5% hitrejši in cenejši, manjša poraba el. energije... Meni se je zdel smiseln nakup in sem ga pač kupil. Dejansko se mi je trenutno zdel best buy.
Meizu ::
Sej ne da je slab. Jst čm rečt sam tistim ki imamo E6550, E6750 in E6850, da se nam ne splača upgrejdat na tele proce, ker se denarno ne splača (ubistvu ni tko močnega performance boosta). Sam to sm hotel povedat. Sam ponavadi zmerej pozabim polovico napisat
McMallar ::
Nadgradnja s teh procesorjev pa se ne splača, se strinjam (sedaj, ko si vse napisal
Dami ::
no pa so tu...niste prav dolgo čakali
Tu je kje?
Meizu ::
Volta: Sej pravim, če gledaš zaradi cacheja kakšnih par%, pa mogoče zaradi novejše tehnologije še kakšen%. Prav gotovo pa razlika ni tako očitna, da bi se ti splačalo menjavat proc, če si na E6xxx seriji. Če pa sestavljaš komp, pa nimaš s tem procom kej falit, kr je res best buy trenutno
JIM22 ::
Dejte napiše dilerji kdo ga ima na zalogi. In če se da celo batch/FPO napisat.
Volta ::
Meizu - Sem malo prebrskal Tomshardware in podobno in ja. Razlika je od 2 - 15% v nekaterih aplikacijah. V povprečju pa tam 5%, tako da nakup oz. zamenjava na E8xxx ni smiselna.
| » | Računalnik za pisarno.Oddelek: Pomoč in nasveti | 1465 (1272) | Brias |
| » | Rabim plata, procesor in rame. PredlogiOddelek: Kaj kupiti | 2423 (1865) | GrimReaper |
| » | E8500 ali E8400?? (strani: 1 2 )Oddelek: Kaj kupiti | 6797 (5407) | JIM22 |
| » | Nove pocenitve Intel procesorjevOddelek: Strojna oprema | 3786 (1875) | Dr_M |
| » | sestavljanje kompa...kaj kupitOddelek: Kaj kupiti | 2658 (1549) | iLichu |
