ASUS plošča
ASUS plošča
Dany ::
Naj mi nekdo razloži kateri disk gre na to ploščo piše da gre SATA ?
Key Specifications A7V600-X Motherboard
Manufacturer Asus
Manufacturer Part # A7V600-X
CPU Support Socket Type Socket A
CPUs Supported
AMD Athlon XP/Athlon / Duron / Thoroughbred/ Barton Core Support
Front Side Bus Speed (FSB) 400/333/266/200MHz
Form Factor ATX
Chipsets VIA KT600
VIA VT8237
BIOS 2Mb Flash ROM, ASUS JumperFree, Award BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ASUS EZ Flash, ASUS CrashFree BIOS 2, ASUS C.P.R.
Memory Number of Slots 3 x 184-Pin DIMM Sockets
Memory Type
DDR SDRAM
Maximum Memory 3 GB
Storage / Raid 2 x UltraDMA 133/100
2 x Serial ATA with RAID 0, 1 function
Integrated Features Audio ADI AD1888 6-channel CODEC
S/PDIF out interface
Network LAN Integrated 10/100 Mbps LAN controller with external PHY
Expansion Slots 1 x AGP 8X
6 x PCI
Industry Standard PCI 2.2, USB 2.0
Overclocking Features ASUS JumperFree
ASUS C.P.R.(CPU Parameter Recall)
CPU voltage adjustable
SFS (Stepless Frequency Selection) from 100MHz up to 250MHz at 1MHz increment
Special Features ASUS EZ Flash
ASUS C.O.P. (CPU Overheating Protection)
ASUS Instant Music Lite
Back Panel
I/O Ports 1 x Parallel1x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Audio I/O4 x USB 2.0
1 x RJ-45 Port
1 x S/PDIF output
Internal I/O
Connectors CPU/Chassis FAN connectors
20-pin ATX power connector
Chassis Intrusion
GAME/MIDI connector
CD/AUX audio in
Front panel audio connector
2 x USB 2.0 connector supports additional 4 USB 2.0 ports
2 x SATA ports
Dimensions
(W x D) Unit 12" x 9.6"
Warranty 3 Years
Includes in the Box User's manual
Ultra DMA cable
FDD cable
I/O shield
Drivers
ASUS PC Probe
Trend Micro PC-cillin 2002 anti-virus software(OEM version)
ASUS LiveUpdate Utility
krucymucy ::
PATA in SATA ... IDE kanala ima verjetno dva, se pravi 4 naprave, dodatno pa se 2 SATA priklopa.
Dany ::
Tanks ! Imam v mislih tegale od WD 320 gb, 7200 rpm, 16mb, SATA!
Bo to vredu?
Še nekaj me zanima kateri ventilator zelo dobro ohladi procesor Semprona 2,8 Ghz imam na tej plošči.
V mislih imam ta dva Zalmana 7700-Cu 120mm in model CNPS 8000 ?
  • spremenilo: Dany ()
AngelOfDeath ::
Seagate Baracuda 320GB sigurno deluje na tej plošči. Imam namreč 2 v Raid.
edit: Slovnica
Dany ::
Sem zelen pri tej zadevi a mi prosim razložiš zakaj nebi delal wd ?
AngelOfDeath ::
Pri Seagate moraš zadaj vstavit en jumper da jo plošča prepozna (kao Sata1).
Kako ima WD to rešeno pa ne vem.
edit: Slovnica
Dany ::
Hvala za odgovor !
Dany ::
Zanima me vaše mnenje kateri ventilatorji zelo dobro hladijo procesorje!
Ker imam zdaj nekakšno ropotarnico gor na AMD Sempron 2,8 /754?
Ta procesor se zelo fajn greje temp. pride do 60˙C.
Dany ::
Kateri SOCKET moraš gledat da pravilno izbereš ventilator?
Plošča Asus socket 462!
Procesor AMD Sempron 2,8 Ghz socket 754 oziroma je socket A !
Urc ::
Kateri SOCKET moraš gledat da pravilno izbereš ventilator? Plošča Asus socket 462! Procesor AMD Sempron 2,8 Ghz socket 754 oziroma je socket A !
Nah... Tukaj vsaj 2 stvari ne držita.
1. Na ploščo paše samo socket A procesor, torej ne more bit gor sempron s 754-mi pini.
2. Če bi ti res laufal na 2,8 Ghz se ne bi grel samo do 60 °C ampak krepko čez.
Glede na to da imaš Socket A ki podpira procesorje s 462-mi pini, glej za hladilnik ki je namenjen tvojemu socketu.
edit: typ0
  • spremenil: Urc ()
Dany ::
Potem moram gledat za socket 462 da bom našel pravi ventilator ?
Pri navodilih od procesorja piše socket A.
Kateri pa je potem dober in tihi vetilator da bi ohladil to mašino ?
AngelOfDeath ::
462 je socket A
Dobri in tihi ventilatorji so npr: Zalmani
Pred nakupom preveri kompatibilnost s tvojo ploščo.
edit: Slovnica
Dany ::
Katera grafična kartica paše na ta vodila pci in agp na plošči ASUS A7V600-X!
Do cene 150 Eur! Ker nakater grafične imajo AGP , PCI in PCI-E vodila ?
AngelOfDeath ::
Rabiš grafično kartico za AGP vodilo.
edit: Slovnica
Sempron 2,8 Ghz?
141948 (1558) Blinder
Je ta konfig OK? Hitra pomoč potrebna
82336 (2141) Area_51
Najcenejša plata (socket A) + proc
412095 (1746) jest10
Šum
Oddelek: Zvok in slika
122126 (1983) CaqKa
Plata ???
71719 (1569) nodes
