Plata ???
Plata ???
HiNaVeC ::
Kako se vam zdi ta omenjena plata???
CPU Socket A for AMD Athlon XP/Athlon/Duron up to 2.25GHz+
Thoroughbred/Barton Core Support
Chipset VIA KT400
VIA VT8235
FSB 333 / 266 / 200MHz
Memory 3 x DDR DIMM Sockets
Max. 3 GB unbuffered PC2100 / PC1600 non-ECC SDRAM Memory (PC3200 Max. to 2 banks only / PC2700 Max to 4 banks only)
Expansion Slots 1 x AGP 8X
6 x PCI
IDE 2 x UltraDMA/133/100/66
Audio ADI 1980 6-channel CODEC
S/PDIF out interface
LAN Realtek 10/100 Mbps Ethernet PHY
USB 2.0 VT8235 built-in USB2.0 ? 6 x USB 2.0 port
Special Features ASUS MyLogo
ASUS EZ Flash
ASUS JumperFree
SFS (Stepless Frequency Selection)
ASUS C.O.P. (CPU Overheating Protection)
ASUS C.P.R. (CPU Parameter Recall)
CrashFree BIOS
Back Panel I/O Ports 1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Audio I/O
1 x S/PDIF out
4 x USB 2.0
1 x RJ-45 Port
Internal I/O Connectors CPU/Chassis FAN connectors
20 pin ATX power connector
IDE LED connector
Chassis Intrusion
Game port
CD/AUX/ audio in
Front panel audio connector
1 x USB 2.0 connector supports additional 2 USB 2.0 ports
BIOS Feature 2Mb Flash ROM, ASUS JumperFree, Award BIOS, TCAV, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ASUS EZ Flash, MyLogo, ASUS CrashFree BIOS, ASUS C.P.R
Inustry Standard PCI 2.2, USB 2.0
Manageability WfM2.0, DMI2.0, WOR, WOL, Chassis Intrusion
Support CD Drivers
ASUS PC Probe
Trend Micro PC-cillin 2002 anti-virus software
ASUS LiveUpdate Utility
Accessories User's manual
Driver CD
UltraDMA 133/100 / 66 cable
FDD cable
I/O shield
Form Factor ATX Form Factor 12 x 9.6 (30.5cm x 24.5cm)
Grimlord ::
Model plate ?
Iz malenkosti nastane popolnost in popolnost ni malenkost.
schurda ::
SDRAM?
I want to know God's thoughts, the rest are details. (Einstein)
HiNaVeC ::
ASUS A7V8X-X/LAN, 266/333 FSB Skt.A
nAVID ::
Pr men se obnese. Navija se za šalo... ;)
nAVID do konca....
nodes ::
...ja nekoč, je bila kar dobra plata.
nAVID ::
Nodes: kaj si JI pa naredu ? :D
nAVID do konca....
nodes ::
abrahama je srečala...
Sempron 2,8 Ghz?
141940 (1550) Blinder
ASUS plošča
132184 (1916) AngelOfDeath
Je ta konfig OK? Hitra pomoč potrebna
82324 (2129) Area_51
Najcenejša plata (socket A) + proc
412087 (1738) jest10
Šum
Oddelek: Zvok in slika
122118 (1975) CaqKa
