Sempron 2,8 Ghz?
Sempron 2,8 Ghz?
Dany ::
Naj mi nekdo razloži kako je mogoče da dela procesor Sempron 2,8 Ghz na tej plošči ?
Key Specifications A7V600-X Motherboard
Manufacturer Asus
Manufacturer Part # A7V600-X
CPU Support Socket Type Socket A
CPUs Supported
AMD Athlon XP/Athlon / Duron / Thoroughbred/ Barton Core Support
Front Side Bus Speed (FSB) 400/333/266/200MHz
Form Factor ATX
Chipsets VIA KT600
VIA VT8237
BIOS 2Mb Flash ROM, ASUS JumperFree, Award BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ASUS EZ Flash, ASUS CrashFree BIOS 2, ASUS C.P.R.
Memory Number of Slots 3 x 184-Pin DIMM Sockets
Memory Type
DDR SDRAM
Maximum Memory 3 GB
Storage / Raid 2 x UltraDMA 133/100
2 x Serial ATA with RAID 0, 1 function
Integrated Features Audio ADI AD1888 6-channel CODEC
S/PDIF out interface
Network LAN Integrated 10/100 Mbps LAN controller with external PHY
Expansion Slots 1 x AGP 8X
6 x PCI
Industry Standard PCI 2.2, USB 2.0
Overclocking Features ASUS JumperFree
ASUS C.P.R.(CPU Parameter Recall)
CPU voltage adjustable
SFS (Stepless Frequency Selection) from 100MHz up to 250MHz at 1MHz increment
Special Features ASUS EZ Flash
ASUS C.O.P. (CPU Overheating Protection)
ASUS Instant Music Lite
Back Panel
I/O Ports 1 x Parallel1x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Audio I/O4 x USB 2.0
1 x RJ-45 Port
1 x S/PDIF output
Internal I/O
Connectors CPU/Chassis FAN connectors
20-pin ATX power connector
Chassis Intrusion
GAME/MIDI connector
CD/AUX audio in
Front panel audio connector
2 x USB 2.0 connector supports additional 4 USB 2.0 ports
2 x SATA ports
Dimensions
(W x D) Unit 12" x 9.6"
Warranty 3 Years
Includes in the Box User's manual
Ultra DMA cable
FDD cable
I/O shield
Drivers
ASUS PC Probe
Trend Micro PC-cillin 2002 anti-virus software(OEM version)
ASUS LiveUpdate Utility
bluefish ::
podrobno si preberi to. Če je za Socket A, potem ni problema. Malo me edino čudi frekvenca 2,8GHz.
Dany ::
Hvala lepa za odgovor! A je drgač vredu procesor to? Problem imam z glasnim ventilatorjem na procesorju. Katerega naj kupim da bo zelo tiho?
farko ::
Tolk spet ni glasen da bi povzročal ne vem kako velik hrup.Lahko pa ventilator poskusiš zamnjat.Bistvo je da ti hladi.
farko
Sempron ni 2.8 GHz ampak 2800+, hitrost pa ima 1600 MHz (FSB je 333, če se ne motim... no vsaj pri S754 verziji z 64-bitnimi ukazi je to bilo tako)
_mOuSe_ ::
Zakaj pa ne bi? Plata podpira Socket A procesorje do 3200+. Ta Sempron 2800+ ima pa verjetno Thoroughbred jedro. Če te moti glasnost ventilatorja ga pač zamenjaj, malo pobrskaj po netu. Sam sem stock hladilnik zamenjal z Zalmanom.
Urc ::
_mOuSe_
Lahko dodaš kakšno sliko oz. kak link kateri sempron na socket A je delal na 2.8 Ghz ? :\
Kr_Edn ::
  • spremenil: Kr_Edn ()
_mOuSe_ ::
Kaj si pameten, a sem slučajno napisal da dela s hitrostjo 2800 MHz? Ne vidiš onga +:\ Meni je bilo takoj jasno za gre le za oznako, ampak Danyu ni bilo. Dany tvoj Sempron dejansko dela na 166 MHzx12, torej nekje 2 GHz.
lp, mOuSe
bluefish ::
čisto mimogrede, tukaj je zbranih kar nekaj overclockov.
Kr_Edn ::
Ste pa hitri. Medetem, ko sem jaz popravljal povezavo, sta dobesedno "ustrelila" kar dva.:)
(Ma pišuka,spet popravljam.)
Urc ::
Da, se opravičujem.. Sem videl + ja, zmotilo me je; Zakaj pa ne bi?
whatever, case solved
_mOuSe_ ::
Je že v redu; zakaj pa ne bi 2800+ delal na plati, ki podpira do 3200+, tko sem mislo.
lp, mOuSe
__Devil__ ::
zanima me koliko se da naviti amd sempron 3200+ ?? jaz sem ga spravil na 2,56 enkrat.. sedaj pa mi ne upse več, ker sem nekaj spreminjal in je na 2,46 sedaj. plata je asrock am2 vsta.. nekaj takega. je to max. za to plato?
lp!
Blinder ::
Poglej magari na netu, če je še kdo navijal s tako plato. Bolj tezko boš našel kakšne podatke.
ASUS plošča
132193 (1925) AngelOfDeath
Je ta konfig OK? Hitra pomoč potrebna
82336 (2141) Area_51
Najcenejša plata (socket A) + proc
412097 (1748) jest10
Šum
Oddelek: Zvok in slika
122126 (1983) CaqKa
Plata ???
71719 (1569) nodes
