Šum
Šum
RisPo ::
Imam iz zvočne kartice na rač. zvezano na stolp (rač. 3polni konektor (stereo), na stolpu 2činči (mono)), ok vse vredu. Vsake toliko časa pa začne v zvočnikih obupno šumet in tega šuma se ne morm znebit, sem že na nov zlotu kabel, vse nastavitve prečikiru in nič. Kaj mislite, da bi bilo narobe, mogoče elektromagnetizem račnalnika??
alesrosina ::
hm, mogoce bi dal se info kaksen racunalnik mas ... kaksna zvocna itd.
Tle je lahko razlog v slabi zvocni kartici (na maticni recimo) al pa kej tazga.
RisPo ::
Pozabu napisat:8) :8)
Zvočno imam intergnirano na mamo plato (6-kanalna). Mama plata pa je Asus A7V8X-X/LAN
Evo sem kr celotno config. prekopiru:
CPU Socket A for AMD Athlon XP/Athlon/Duron up to 2.25GHz+
Thoroughbred/Barton Core Support
Chipset VIA KT400
VIA VT8235
FSB 333 / 266 / 200MHz
Memory 3 x DDR DIMM Sockets
Max. 3 GB unbuffered PC2100 / PC1600 non-ECC SDRAM Memory (PC3200 Max. to 2 banks only / PC2700 Max to 4 banks only)
Expansion Slots 1 x AGP 8X
6 x PCI
IDE 2 x UltraDMA/133/100/66
Audio ADI 1980 6-channel CODEC
S/PDIF out interface
LAN Realtek 10/100 Mbps Ethernet PHY
USB 2.0 VT8235 built-in USB2.0 ? 6 x USB 2.0 port
Special Features ASUS MyLogo
ASUS EZ Flash
ASUS JumperFree
SFS (Stepless Frequency Selection)
ASUS C.O.P. (CPU Overheating Protection)
ASUS C.P.R. (CPU Parameter Recall)
CrashFree BIOS
Back Panel I/O Ports 1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Audio I/O
1 x S/PDIF out
4 x USB 2.0
1 x RJ-45 Port
Internal I/O Connectors CPU/Chassis FAN connectors
20 pin ATX power connector
IDE LED connector
Chassis Intrusion
Game port
CD/AUX/ audio in
Front panel audio connector
1 x USB 2.0 connector supports additional 2 USB 2.0 ports
BIOS Feature 2Mb Flash ROM, ASUS JumperFree, Award BIOS, TCAV, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ASUS EZ Flash, MyLogo, ASUS CrashFree BIOS, ASUS C.P.R
Inustry Standard PCI 2.2, USB 2.0
Manageability WfM2.0, DMI2.0, WOR, WOL, Chassis Intrusion
Support CD Drivers
ASUS PC Probe
Trend Micro PC-cillin 2002 anti-virus software
ASUS LiveUpdate Utility
Accessories User's manual
Driver CD
UltraDMA 133/100 / 66 cable
FDD cable
I/O shield
Form Factor ATX Form Factor 12 x 9.6 (30.5cm x 24.5cm)
glinik ::
Dečko,problem je čist enostaven.Rač. in stolp nista na isti masi.Tu se je pojavila neka razlika v potencialu,rezultat je šum v zvočnikih.Poveži maso rač. in stolpa pa bo vse v redu.Uporabi en tanki kabel.To je to.
CaqKa ::
predno probaš glinikov nasvet probaj na veršterkeru vtikač v vtičnici obrnit za 180°.
pri oni povezavi mas sem namreč malo skeptičen da se nebi kaj skurlo....
btw glinik.,.. zakaj pa ravno tanek kabl? da se prej skuri? >:D
RisPo ::
a ti bi kr maso vezal. Vtikač, ja no lahko bi bilo to, da bi tokokrog potekal v nasprotni smeri, bom poskusil. Glede mase pa nevem no, itak sta pa štekana na istem podalšku
hordak ::
Jaz sem imel podoben problem z integrirano realtekovo zvočno na Gigabyte GA7-N400pro2. Po inštalaciji na CD-ju priloženih realtek driverjih je začelo ogabno pokat in hreščat v sprednjem desnem zvočniku, tudi če računalo ni oddajalo nobenega zvoka. Če sem jih odinštaliral in pustil driverje, ki so jih našli nforce gonilniki je pokanje sicer ponehalo, vendar sta delovala samo sprednja zvočnika. Potem sem inštaliral najnovejše zvočne driverje iz Gigabytove strani in vse dela super, brez hreščanja. Poizkusi instalirati najnovejše driverje.
chilloutman ::
RisPo ::
Sem obrnil tokokrog, se pravi vtikač, pa zaenkrat še ni šumel, upam da ne bo več. Upam.
glinik ::
CaqKa,
ti pa bi res moral vedet,da nima kaj bit če povežeš mase!Glede kabla sem misli,da nima veze kakšen kabel je.
Saj mislila sva isto,to da je obrnil šteker je samo ozemljil in nič drugega.
moricy: Zdaj bo vse špilalo,ne se bat :D
alesrosina ::
N0o jst mam asus A7N8X-X in mi je tud hrescal (sicer sele po recimo par urah neprestanega poslusanja muzike). Sem dal potem notri eno staro SoudBlaster 128 in mi spila ko svicarska urca.
Ne vem ce je to pr teb isto, ce mas ksno staro (mal bolso) zvoco ni greh probat.
RisPo ::
zdj dela
CaqKa ::
glinik zaradi tega ker ni nujno da je masa/minus na ojačevalcu enaka masi na računalniku. en od drugega sta namreč galvansko ločena .. ko pa povežeš mase pa več nista galvansko ločena...
Sempron 2,8 Ghz?
141940 (1550) Blinder
ASUS plošča
132184 (1916) AngelOfDeath
Je ta konfig OK? Hitra pomoč potrebna
82324 (2129) Area_51
Najcenejša plata (socket A) + proc
412087 (1738) jest10
Plata ???
71704 (1554) nodes
