Gordian Knot
Gordian Knot
bbobst ::
Če se je kdo ukvarjal z GordianKnot-om,naj mi prosim pomaga:
Opiral sem se na GordianKnot Help.
Do Faze 8 je šlo vse v redu,zataknilo pa se mi je pri Fazi 8 - točki 4 in 5 kjer piše:
4> go to 'Bitrate Curve' and load the stats-file you saved in 'Encode using:'. in the filename you see the bitrate and the
minimum bitrate you scaled for.
5> go to the DivX-tab and enter these values in 'Bitrate' and 'Minimum allowed Bitrate'.
New in v0.16: Minimum allowed Bitrate always is 270, so you don't have to change anything there.
Ne vem, kje dobiti podatek "Bitrate" ,ki ga je treba vpisati v Nandub-Video-SBC Options-SBC Settings-DivX
Prosim HELP !
BlackHole ::
Verjetno ga boš našel pod predalčkom BITRATE v GordianKnot-u. (silly):O
muc` ::
Tuki mas kompleten vodic v slovenscini (pa ne preveden, ampak na novo napisan) GordianKnot
DVD ripanje
Oddelek: Zvok in slika
51726 (1593) CaqKa
kako v divx format
61201 (1093) grga001
DVD -> DivX
Oddelek: Sedem umetnosti
282427 (1727) CaqKa
Pomoč pri idelavi Divx-a
71501 (1287) freejack
DivX s čem jih delat
262456 (1902) EX-B
