Forum » Sedem umetnosti » Gordian Knot
Gordian Knot
bbobst ::
Če se je kdo ukvarjal z GordianKnot-om,naj mi prosim pomaga:
Opiral sem se na GordianKnot Help.
Do Faze 8 je šlo vse v redu,zataknilo pa se mi je pri Fazi 8 - točki 4 in 5 kjer piše:
4> go to 'Bitrate Curve' and load the stats-file you saved in 'Encode using:'. in the filename you see the bitrate and the
minimum bitrate you scaled for.
5> go to the DivX-tab and enter these values in 'Bitrate' and 'Minimum allowed Bitrate'.
New in v0.16: Minimum allowed Bitrate always is 270, so you don't have to change anything there.
Ne vem, kje dobiti podatek "Bitrate" ,ki ga je treba vpisati v Nandub-Video-SBC Options-SBC Settings-DivX
Prosim HELP !
Prosim HELP !
| » | DVD ripanjeOddelek: Zvok in slika | 1757 (1624) | CaqKa |
| » | kako v divx formatOddelek: Pomoč in nasveti | 1216 (1108) | grga001 |
| » | DVD -> DivXOddelek: Sedem umetnosti | 2443 (1743) | CaqKa |
| » | Pomoč pri idelavi Divx-aOddelek: Pomoč in nasveti | 1513 (1299) | freejack |
| » | DivX s čem jih delatOddelek: Zvok in slika | 2473 (1919) | EX-B |
