Copy na več destinacij
bazzz ::
Kako lahko definiram več destinacij za kopiranje z ukazom copy (DOS)?
(COPY source destination [options]). Ima kdo kakšen primer, skripto? (For..Do..copy....)
StratOS ::
Več izvajanj ukazov ...
copy config.sys d:\ /y
copy cards.exe "C:\Program Files\MSN Gaming Zone\Windows" /y
copy /b "1 file.1"+"2 file.2" "out file.exe" /y
xp sp2 copy :
COPY [/D] [/V] [/N] [/Y | /-Y] [/Z] [/A | /B ] source [/A | /B]
[+ source [/A | /B] [+ ...]] [destination [/A | /B]]
source Specifies the file or files to be copied.
/A Indicates an ASCII text file.
/B Indicates a binary file.
/D Allow the destination file to be created decrypted
destination Specifies the directory and/or filename for the new file(s).
/V Verifies that new files are written correctly.
/N Uses short filename, if available, when copying a file with a
non-8dot3 name.
/Y Suppresses prompting to confirm you want to overwrite an
existing destination file.
/-Y Causes prompting to confirm you want to overwrite an
/Z Copies networked files in restartable mode.
The switch /Y may be preset in the COPYCMD environment variable.
This may be overridden with /-Y on the command line. Default is
to prompt on overwrites unless COPY command is being executed from
within a batch script.
To append files, specify a single file for destination, but multiple files
for source (using wildcards or file1+file2+file3 format).
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
MS-DOS/cmd xcopy
Oddelek: Operacijski sistemi
111968 (1830) DeeJay
BAT kopiranje mape
101957 (1825) StratOS
Gigabitni switch za domaco uporabo?
212372 (1732) lopov
[Batch] xcopy ukaz
Oddelek: Programiranje
61839 (1651) Ethical
script za premaknit fajl
81210 (1083) ABX
