SnapShot programi
SnapShot programi
Kriko ::
Zanima me z katerim programom lahko "slikam" trenutni ekran vendar tako da vidim tudi vse kar je daljše od trenutne slike.
recimo sem na kakšni internetni strani katera je precej dolga jaz pa bi jo rad snapshotal tako da lahko kasneje stran prav tako celo prgledujem tako gor kot dol!
Gandalfar ::
Kriko ::
hello!
ja imam ta program, samo prosim če mi poveš kaj naj nastavim da mi bo snapshootalo celo stran, ne samo trenutni ekran!
Gandalfar ::
[sigh] RTFM [/sigh]
V capture settings si vklopi scrolling.
Auto-scroll window during Window capture - check this to automatically scroll the captured application's window. It scrolls long pages with a vertical scroll bar, allowing you to capture more than you can see on the screen. In general, leave this function disabled unless you absolutely need this functionality.
Auto-scroll doesn't work for all applications that have a vertical scroll bar. Some applications erase the marks that HyperSnap-DX 4 draws over the window it captures while scrolling. These marks allow it to find out how many pixel lines the window was scrolled during the scrolling interval. If these control marks are erased, HyperSnap-DX 4 has no way of knowing how much data to capture.
In such a case, it will display an error message and capture what it could without scrolling. The most popular web browsers (Netscape and MS Internet Explorer) work well with auto-scroll, and many other programs tested well with it. However it may not work with programs who handle the screen in a method hostile to the control mark method.
Here are the steps for making an Auto-scroll window capture. Please read them carefully before attempting an Auto-scroll capture.
Make sure the auto-scroll option is enabled.
Have the target window ready, with the vertical scroll bar set to the top, or to the place where you want to start the Auto-scrolling capture.
Select Capture / Window from HyperSnap-DX 4's menu, or press the "capture a window" hot key Ctrl+Shift+W.
Move your mouse to the middle of the document that you want to Auto-scroll capture and click the left mouse button inside the document.
Watch how HyperSnap-DX 4 scrolls the window, and as it does this, it draws horizontal marks over it.
If you want, you can abort this process early by left-clicking the mouse or by pressing any key on the keyboard. If you elect to wait until it finishes, the window will scroll until all of the available text has scrolled into view and has been captured. On some documents, remember, this might be very, very long resulting in a huge capture that consumes much memory (or disk space).
The capture is complete. Examine the contents of HyperSnap-DX 4's window to make sure it captured the contents correctly, and save the file using the name you wish to use.
Copyright (c) 2000 Hyperionics - Help by Dangerous Cybernetics
Enostaven programčič za screen capture
Oddelek: Programska oprema
81531 (1314) Matthew
Zopet malo iger
Oddelek: Novice / Igre
63011 (3011) pingo76
clipboard
62207 (2160) Cokolesnik
Kje bi dobu program za zajem slike
131618 (1503) madmitch2
WIN
52141 (1956) Quickbeam
