napaka pri odpiranju videov
Mag!C ::
Lep pozdrav!
Zanima me zakaj mi pri usakem odpiranju nekega videa pokaze tole
kliknem ok spet pokaze, kliknem spet ok, potem pa dela lahko gledam normalno ampak moti me da mi javlja to napako! A mi lahk kdo pove ka naj naredim da bo laufalo tk ko ej treba!? Hvala
0_0
  • spremenil: Mag!C ()
StratOS ::
Vzeto iz konteksta http://forums.afterdawn.com/thread_view.cfm/468065
How to remove the problem :
Please follow the steps exactly. Do not rush.
Download the All clean tool from Nero and save it on your desktop.
http://www.nero.com/nero7/eng/General_CleanTool.html
Open Control panel- Then go to Add-Remove Program and delete All Nero Applications.
Run Nero clean Tool twice.( which saved on desktop)( select all options to remove)
Then exit.
Restart the computer.
Reinstall the Nero software.
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
  • spremenila: StratOS ()
Pesem dati v obratno predvajanje
Oddelek: Zvok in slika
91744 (1585) 5er-->
Odklenitev telefona in garancija???
Oddelek: Mobilne tehnologije
72399 (2214) LuGi
Label flash
358796 (6066) shany
Multimdijski center
Oddelek: Programska oprema
51376 (1257) BIG_Yack
Zuanje ohiške + NEC 3500A
261642 (1472) Golden eye
