odpovedal canon a 70
bukev ::
prosim za diagnozo cca dve leti starega digitalca
zjutraj je sliko roza obarval - tudi čudne linije.
sedaj so pa čisti zmazki - tole je hi-fi stolp.
ali je komu kaj znano?
bukev
Trancedeejay ::
HI
To je standardno serijska napaka na starejsih powershotih. Okoli displaya stisni(ne po displayu).Vglavnem fizicno pritiskaj po foticu in opazuj kako se spreminja slika(ne recimo da postane tam kjer stisnes bolj vijolicasto ampak da recimo se slika normalizira, pa spet nekaj crt, pa vijolicasto crni obrisi, pa spet normalna slika...)
Have a nice Day
Matt
Music is the key
bukev ::
hojla
slika se med stiskanjem res malo spreminja, vendar na žalost ne na bolje!
vseeno hvala
B
sparklyslo ::
Pred kratkim sem ga dobil iz servisa zaradi takšne napake.
Cena popravila 60 €. Verjetno več kot je vreden aparat :D
bukev ::
odnesel na servis-rabijo 14 dni za diagnozo, ampak če je okvara ccd sem na konju.
spodnji tekst je kopiran iz Canon Europe.
It has been found, that in rare case, some of the CCDs, used in Canon digital camera and digital video cameras, have a problem that causes abnormal image output.
We apologise for any inconvenience this may have caused. Canon will offer free repairs where an error is caused by this malfunction.
Canon would like to advise our customers of the details of this issue and our policy for handling it.
Problem details:
Among the CCDs used in the affected products, it has been confirmed that in extremely rare cases, under high-temperature/high-humidity environments, some of the internal wiring comes off.
If this defect occurs, the signal is not output from the CCD correctly when in shooting mode. This results in image abnormalities such as:
Images do not appear
Image colors are abnormal
Images appear distorted
These symptoms can be confirmed on the LCD monitor.
Solution:
We kindly request users who have confirmed these symptoms to contact the nearest Canon Service Centre.
Free repairs will be made for affected products in cases where it has been confirmed that the internal CCD wiring has come off.
Last modified date: 17-Jan-07
Battlefield Bad Company 3
Oddelek: Igre
92202 (1797) oo7
Iron Maiden - A Matter of Life and Death
Oddelek: Sedem umetnosti
183096 (2324) jazbec
Canon powershot A60
Oddelek: Zvok in slika
252753 (1830) Djuro
Wikileaks: email sporočila med raziskovalci klimatskih sprememb
Oddelek: Problemi človeštva
303612 (2800) AtaStrudl
Nov test
Oddelek: Novice / Nova vsebina
112574 (2574) Jux
