Forum » Pomoč in nasveti » Ob vsakem zagonu CHDSK
strijcmarko ::
Pozdravljeni !
Imam težavo, v svoj računalnik ( Dell Pentium 4 2.0 1G RAM-a) sem dodal
še en disk(WDC 80GB). Disk mi sicer dela vredu vendar se mi ob vsakem ponovnem zagonu Windows XP pojavi CHDSK in preverja ta disk, to traja precej časa zato me moti.
Prosim če mi lahko kdorkoli pomaga z nasvetom.
Hvala v naprej
Hvala v naprej
V command prompt(run--> cmd) napiši chkdsk C: /r.
Tam, kjer sem napisal C: napiši svojo črko od particije.
StratOS ::
CHKDSK [volume[[path]filename]]] [/F] [/V] [/R] [/X] [/I] [/C] [/L[:size]]
volume Specifies the drive letter (followed by a colon),
mount point, or volume name.
filename FAT/FAT32 only: Specifies the files to check for fragmentation.
/F Fixes errors on the disk.
/V On FAT/FAT32: Displays the full path and name of every file
on the disk.
On NTFS: Displays cleanup messages if any.
/R Locates bad sectors and recovers readable information
(implies /F).
/L:size NTFS only: Changes the log file size to the specified number
of kilobytes. If size is not specified, displays current
size.
/X Forces the volume to dismount first if necessary.
All opened handles to the volume would then be invalid
(implies /F).
/I NTFS only: Performs a less vigorous check of index entries.
/C NTFS only: Skips checking of cycles within the folder
structure.
The /I or /C switch reduces the amount of time required to run Chkdsk by
skipping certain checks of the volume.
on the disk.
(implies /F).
size.
(implies /F).
structure.
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
Če ti to ven vrže potem nisi dobro napisal. Klikni na Start --> Run --> cmd --> napiši chkdsk C: /r
| » | Blue Screen errorOddelek: Pomoč in nasveti | 1605 (1402) | F-22 |
| » | disk boot failureOddelek: Pomoč in nasveti | 1853 (1756) | amigo_no1 |
| » | Zakaj mi ne ponudi opcije formatiranja v FAT32 ?Oddelek: Pomoč in nasveti | 1565 (1486) | sinko999 |
| » | ? spremeniti FAT32 particijo v NTFS, ne da bi formatiral? Help!Oddelek: Operacijski sistemi | 3286 (3062) | ZLOky |
| » | w2k in NTFS quick format?Oddelek: Programska oprema | 1864 (1738) | CaqKa |
