Forum » Programska oprema » php + vista + cmd = ne dela
_n00b_ ::
Pozdravljeni.
Vsakič ko poskusim pognati php preko cmd-ja na visti PHP najprej zajamra, da ne more naloziti kup dll-jev, nato pa se zruši. Nekak tak:
Komu priblizno jasno zakaj (ne dela)?
c:\php>php -f c:\test.phpVsi ddl-ji so tam kot bi morali biti (c:\php\ext). Noben od teh dll-jev se po php.ini nebi smel naloziti. Prav tako sem probal na XP-jih tam pa je pa stvar delovala kakor bi morala...
PHP Warning: PHP Startup: Unable to load dynamic library 'C:\php\ext\php_pdo_oci.dll' - The specified module could not be found.
in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library 'C:\php\ext\php_pdo_oci8.dll' - The specified module could not be found.
PHP Warning: PHP Startup: Unable to load dynamic library 'C:\php\ext\php_pspell.dll' - The specified module could not be found.
PHP Warning: PHP Startup: Unable to load dynamic library 'C:\php\ext\php_sybase_ct.dll' - The specified module could not be found.
PHP Warning: PHP Startup: Unable to load dynamic library 'C:\php\ext\php_ibm_db2.dll' - The specified module could not be found.
[itd]
| » | instalacija dll-jaOddelek: Operacijski sistemi | 1187 (992) | settler |
| » | Grafična kartica in Windows7 64bit-ni problemOddelek: Strojna oprema | 2287 (1788) | jizzer |
| » | Plesk [php] in interbaseOddelek: Izdelava spletišč | 1791 (1556) | c3p0 |
| » | [Visual Studio .NET] Uvoz Delphi DLL-ja v okolje ASP.NETOddelek: Programiranje | 1931 (1832) | Kekec |
| » | ATIOddelek: Pomoč in nasveti | 1281 (1168) | Toomy |
