Forum » Pomoč in nasveti » kako film, ki se predvaja v brskalnuki prenesti na disk
r0b3rt ::
StratOS :: 4. apr 2009, 14:18:14
Ne vem kako naj drugače označim citat, ker javi napako...
Naj preidem k vprašanju:
Lahko kdo obrazloži iz česa je v linku: "http://streamflv1.24ur.com/24ur.com/200... pridobljen del: 290f9069a7? Sploh pa kako smo prišli do začetnega dela: streamflv1.24ur.com?
Rad bi namreč prenesel movie http://24ur.com/ekskluziv/film_tv/spozn...
Novica http://24ur.com/novice/svet/slovenija-p...
Pregledaš js in object stringe:
<script language="JavaScript1.1" type="text/javascript"> //user track variables var section_id = "3"; var article_id = "3163174"; var gallery_id = "3163198"; var media_id = "60272976"; var article_date = "20090404"; var app_lang = "slo"; var show_banners = "1"; var allow_refresh = "0"; </script>
in objekt :
<object width="420" height="376"><param name="movie" value="http://24ur.com/static/slo/shared/app/MediaCenter.swf"></param><param name="allowfullscreen" value="true"></param><param name="flashVars" value="media_id=60272976&ad_file=noad&autostart=false"><embed src="http://24ur.com/static/slo/shared/app/MediaCenter.swf" type="application/x-shockwave-flash" allowfullscreen="true" width="420" height="376" flashvars="media_id=60272976&ad_file=noad&autostart=false"></embed></param></object>
Razrešiš in voila :
- spremenil: r0b3rt ()
r0b3rt ::
Se da dobiti obrazložitev, kako se je prišlo do naslova ter kako pridobim še ostala dva dela?
gorenjc ::
Kar se tiče 24ur, je zadeva v FF zelo enostavna. Kot je že napisal asdffghhhhh, se namesti dodatek NetVideoHUnter. Druga opcija dodatek za http header-je, recimo Live HTTP headers. Za flv datoteke ( flash player) se poišče niz flv? in dobi URL za mp4 datoteke pa se poišče niz mp4?
laguna ::
jedinica 1 del:
http://vid2.24ur.com/2010/09/29/dff7d47...
jedinica 2 del:
http://vid4.24ur.com/2010/09/30/a9e6155...
jedinica 3 del:
http://vid3.24ur.com/2010/09/30/00b1aaa...
Kako pa se pride do .flv videov na rtvslo. Ostali dva .wmv in .rm ni problem dobiti, saj ta dva zna poiskati mnogo programov, ne vem pa kako poiskati .flv stream.
Pa še nekaj, kako bi se dalo na movie2k dobiti streame videov za movshare, torej za ta naslov:
http://www.movshare.net/video/69m7sgnx6...
ki da potem direktni link
http://www.movshare.net/stream/w12/4782...
in
http://w12.movshare.net/dl/478209e1d622...
Torej ni problem dobiti ta link, vendar se le ta iz dneva v dan spremnija, torej kakšna je ta .php skripta, ki obdela ta naslov in kako se da to naredit.
jedinica 2 del:
jedinica 3 del:
in
lagunaaaa
Saso123 ::
Mi lahko prosim nekdo sestavi link za
http://24ur.com/novice/slovenija/zgrabi...
Hvala za pomoč
Srečno in zdravo 2011
Hvala za pomoč
dukedl ::
Hvala za pomoč
Srečno in zdravo 2011![]()
http://vid3.24ur.com/2010/12/31/0f5b4f9...
lp dukedl
- spremenil: dukedl ()
Maš tud Orbit downloader, ko prestreže linke.
- spremenil: iloveboobz ()
d0rK ::
Poskusil sem sam, a ne znam. Downloadal z Orbitom pa je video neuporaben. Zvok zaostaja, slika je zatikajoča. Potrebujem tale video: Nanosvet.
Lahko kdo pomaga? Če ne drugače tudi če mi razlozi tocno kako downloadam, da se naučim. Prišel sem do xml-ja, kjer je link 12/66/Nanosvetx201012141812x700000x351x413x.mp4. Ampak ne znam pa dobiti celotnega naslova. GetASFStream tudi ne znam uporabljati. Nekaj sem štrikal, pa dobim odgovor programa "There is no response from a server".
Hvala!
Hvala!
fizikalac ::
Stream uporablja RTMP protokol, kar sm uspel najdt je:
XML: http://tvslo.si/media.php?id=90610939&m...
IP: 94.103.65.137
PLAYER: http://tvslo.si/media_player.swf
tcUrl: rtmp://stream.rtvslo.si/simplevideostreaming&autostart=true&repeat=list
IP: 94.103.65.137
cegu ::
vid88 ::
Pozdravljeni!
Mene pa zanima kako bi lahko posnel vsebino ki se trenutno predvaja na Siol Twin. Gledam pa preko računalnika.
SLO_Matej ::
Pozdravljeni!
Uporabi Microsoft Expression Encoder Screen Capture. Brezplačna verzija snema do 10 min, bi se pa tudi plačljivo dalo kako dobiti, samo o tem ne bi tukaj.
| » | Download video (flash) iz rtvslo (strani: 1 2 )Oddelek: Pomoč in nasveti | 60589 (22999) | Pizzicato |
| » | Kako presnamem video prispevek z RTVSlo portala?Oddelek: Zvok in slika | 12587 (8281) | Naabo |
| » | rtv - download posnetkovOddelek: Zvok in slika | 14803 (8060) | Valvoline |
| » | Poslušanje Intrnetnega radijaOddelek: Pomoč in nasveti | 2565 (2430) | k4vz0024 |
| » | download odmevov z rtv.sloOddelek: Pomoč in nasveti | 4434 (4132) | sprasujem |
