No sound (Wolfenstein...)
Slo-One ::
Igre kot so wolfenstein in quake nočejo izstisniti nobenega zvoka v Linuxu...
ET 2.60 linux-i386 Mar 10 2005
----- FS_Startup -----
Current search path:
/root/.etwolf/etmain
/usr/local/games/enemy-territory/etmain/pak2.pk3 (22 files)
/usr/local/games/enemy-territory/etmain/pak1.pk3 (10 files)
/usr/local/games/enemy-territory/etmain/pak0.pk3 (3725 files)
/usr/local/games/enemy-territory/etmain/mp_bin.pk3 (6 files)
3763 files in pk3 files
execing default.cfg
couldn't exec language.cfg
execing profiles/SloOne/etconfig.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
------- Input Initialization -------
Joystick is not active.
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
...loading libGL.so.1: Initializing OpenGL display
...setting mode 7: 1152 864
Xlib: extension "XFree86-VidModeExtension" missing on display ":93.0".
Using 4/4/4 Color bits, 24 depth, 0 stencil display.
GL_RENDERER: GeForce 6600 GT/PCI/SSE2/3DNOW!
Initializing OpenGL extensions
...GL_S3_s3tc not found
...ignoring GL_EXT_texture_env_add
...using GL_ARB_multitexture
...GL_EXT_compiled_vertex_array not found
...GL_NV_fog_distance not found
... GL_EXT_texture_filter_anisotropic not found
Initializing GLX extensions
... GLX_SGI_swap_control not found
... GLX_SGI_video_sync not found
GL_VENDOR: NVIDIA Corporation
GL_VERSION: 1.2 (2.0.2 NVIDIA 87.74)
GL_EXTENSIONS: GL_ARB_depth_texture GL_ARB_imaging GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ARB_texture_non_power_of_two GL_ARB_vertex_program GL_ARB_fragment_program GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array GL_ATI_texture_mirror_once GL_HP_occlusion_test GL_IBM_texture_mirrored_repeat GL_NV_blend_square GL_NV_texgen_reflection GL_NV_texture_rectangle GL_NV_texture_env_combine4 GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow
GLX_EXTENSIONS: GLX_ARB_multisample GLX_EXT_visual_info GLX_EXT_visual_rating GLX_EXT_import_context GLX_SGIX_fbconfig GLX_ARB_get_proc_address
GL_MAX_TEXTURE_SIZE: 4096
GL_MAX_ACTIVE_TEXTURES_ARB: 4
PIXELFORMAT: color(32-bits) Z(24-bit) stencil(0-bits)
MODE: 7, 1152 x 864 fullscreen hz:N/A
GAMMA: software w/ 0 overbright bits
CPU:
rendering primitives: multiple glArrayElement
texturemode: GL_LINEAR_MIPMAP_LINEAR
picmip: 0
texture bits: 32
multitexture: enabled
compiled vertex arrays: disabled
texenv add: disabled
compressed textures: disabled
anisotropy: 1.0
NV distance fog: disabled
Initializing Shaders
----- finished R_Init -----
------- sound initialization -------
''/dev/dsp'': No such file or directory
Could not open ''/dev/dsp''
Sound memory manager started
Sys_LoadDll(/root/.etwolf/etmain/ui.mp.i386.so)...
Sys_LoadDll(/root/.etwolf/etmain/ui.mp.i386.so) failed:
"/root/.etwolf/etmain/ui.mp.i386.so: cannot open shared object file: No such file or directory"
Sys_LoadDll(/usr/local/games/enemy-territory/etmain/ui.mp.i386.so)... ok
Sys_LoadDll(ui) found **vmMain** at 0xaed0cf40
Sys_LoadDll(ui) succeeded!
--- Common Initialization Complete ---
Opening IP socket: localhost:27960
Hostname: localhost
IP: 127.0.0.1
Started tty console (use +set ttycon 0 to disable)
^5PunkBuster Client: PunkBuster Client (v1.152 | A0) Enabled
^5PunkBuster Client: Game Version [ET 2.60 linux-i386 Mar 10 2005]
^5PunkBuster Client: Not Connected to a Server
Resolving etmaster.idsoftware.com
etmaster.idsoftware.com resolved to 192.246.40.60:27951
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutdown tty console
Prosim za pomoč.
  • odbrisal: Mavrik ()
R33D3M33R ::
Glede na
bi lahko bili dve možnosti:
a) namesti gonilnike za zvočno, ker je očitno s temi nekaj narobe
b) mogoče kak drug proces uporablja zvočno (recimo artsd), izvedi killall artsd pred igranjem in to bi moralo biti to.
Slo-One ::
Samo kako to da v drugih igrah dela? :(
R33D3M33R ::
Igre na quake pogonu dostopajo do strojne opreme neposredno. Matevzk je v tej temi napisal vzrok:
Matevzk: Problem je, da je pri poceni (=običajnih) zvočnih karticah potrebno miksanje zvoka izvesti softversko. To (po meni neznani trapariji) delajo user-space daemoni, recimo na gnome in še nekaterih sistemih običajno ESD, na KDE pa ARTS. Ta igra pa hoče direktno (ekskluzivno) do zvočne kartice. Za čas igranja boš moral ugasniti tega demona
Slo-One ::
NAjlepša hvala :D :D :D :D :D :D :D 300x tnx.
To je bilo 1 vprašanje za 100€.
Vprašanje za 200€ (kao virtualnih) zakaj imam tako zelo malo FPSjev...? :(
A se da tudi to popravit?:D
Imam ATHLON 3500+, 1024MB RAMA, Geforce 6600GT,...
Orbit89 ::
Če se ne motim obstajajo nekakšni predelani pogoni od teh iger, ki igro zaženejo v OpenGL-ju.
Stem dodatkom ti bi moralo vse normalno delat.
Slo-One ::
Kje pa dobim takšne dodatke? :(
Ali pa mi povejte kakaršnokoli rešitev, ki bo zvišala FPSje. :D
  • spremenil: Slo-One ()
Verjetno nimaš 3d pospeševanja v linuxu.
Preveri če imaš tole v /etc/X11/xorg.conf (predvidevam, da ne uporabljaš xfree86 :))
Section "DRI"
Mode 0666
EndSection
# This loads the GLX module
Load "glx"
# This loads the DRI module
Load "dri"
Load "drm"
Če pa ne bo pomagalo, pa verjetno nimaš pravih modulov v kernelu naštimanih (apgart ...). Ampak strojno opremo bi ti moralo pravilno prepoznati pri inštalaciji.
R33D3M33R ::
Namesti si gonilnike iz nvidine strani. Prenesi si paket in ga iz konzolnega načina zaženi (X-server moraš prej ustaviti), zadeva se bo skompajlala in to je to. Potrebuješ kernel headerje. Če ti karkoli drugega manjka te bo že opozorilo. Tako sem vsaj naredil jaz za mojega gf2 mx :)
Lahko pa si potegneš tudi binary. Kakor hočeš...
Slo-One ::
What?
A to pod linuxi so že keri gonnilniki al samo inšataliram in nič ne brišem?
Kaj je to X-Server?
A da preko konzole inštaliram (tak ko sem ET ko je bil v .RUN)
kAJ PA SO TO KERNEL HEADERJI. (2. dan Linux user, skratka zelenec)
Kaj pa je to Binary?
Hvala za nadalnjo pomoč... :))
EDIT: Moram inštalirati x64 ali x86
imam Linux Mandrivo (2006 al 2007) powerpack.
R33D3M33R ::
Ok. Mogoče bi bilo najbolje, če si gonilnikov ne bi kompajlal sam, ker če bo šlo kaj narobe si verjetno ne boš znal spomagati (saj si tudi jaz nisem znal).
X-server
Kernel headerje moraš imeti za kompajlanje določenih modulov in programov. So pač set knjižic, če se ne motim.
Binary so pa že skompajlani programi.
Na Mandrivo se ne spoznam, ampak če imaš kakšen nameščevalec paketov, uporabi tega. Pa preden karkoli na novo nameščaš upoštevaj karafekin nasvet.
Ja pa sej ima inštalirane nvidia gonilnike
V terminalu zaženi ukaz:
glxinfo
in poglej kaj ti napiše pri direct rendering (verjetno imaš NO).
Pa skopiri sem xorg.conf (ali pa še boljše, uploadi nekje in samo daj link).
R33D3M33R ::
Aha, tega pa sploh nisem opazil :8)
Slo-One ::
glxinfo
name of display: :93.0
display: :93 screen: 0
direct rendering: No
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float
GLX version: 1.2
GLX extensions:
GLX_EXT_import_context, GLX_SGIX_fbconfig, GLX_ARB_get_proc_address
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 6600 GT/PCI/SSE2/3DNOW!
OpenGL version string: 1.2 (2.0.2 NVIDIA 87.74)
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_imaging, GL_ARB_multitexture,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shadow,
GL_ARB_texture_border_clamp, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_window_pos, GL_ARB_texture_non_power_of_two, GL_ARB_vertex_program,
GL_ARB_fragment_program, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
GL_EXT_packed_pixels, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap,
GL_EXT_texture3D, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_lod,
GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_vertex_array,
GL_ATI_texture_mirror_once, GL_HP_occlusion_test,
GL_IBM_texture_mirrored_repeat, GL_NV_blend_square,
GL_NV_texgen_reflection, GL_NV_texture_rectangle,
GL_NV_texture_env_combine4, GL_SGIS_generate_mipmap, GL_SGIS_texture_lod,
GL_SGIX_depth_texture, GL_SGIX_shadow
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x2c 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x2d 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x2e 32 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 Ncon
0x2f 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 Ncon
XORG.CONF
# File generated by XFdrake (rev 57713)
# Refer to the xorg.conf man page for details about the format of
# this file.
Section "Files"
# font server independent of the X server to render fonts.
FontPath "unix/:-1"
# minimal fonts to allow X to run without xfs
FontPath "/usr/share/fonts/misc:unscaled"
EndSection
Section "Extensions"
Option "Composite"
EndSection
Section "ServerFlags"
# DontZap # disable < Crtl >< Alt>< BS> (server abort)
# DontZoom # disable < Crtl >< Alt>< KP_+>/< KP_-> (resolution switching)
AllowMouseOpenFail # allows the server to start up even if the mouse does not work
EndSection
Section "Module"
Load "dbe" # Double-Buffering Extension
Load "v4l" # Video for Linux
Load "extmod"
Load "type1"
Load "freetype"
Load "/usr/lib/xorg/modules/extensions/nvidia/libglx.so"
Load "glx" # 3D layer
EndSection
Section "InputDevice"
Identifier "Keyboard1"
Driver "kbd"
Option "XkbModel" "pc105"
Option "XkbLayout" "si"
Option "XkbOptions" "compose:rwin"
EndSection
Identifier "Mouse1"
Driver "mouse"
Option "Protocol" "ExplorerPS/2"
Option "Device" "/dev/mouse"
EndSection
Section "Monitor"
Identifier "monitor1"
VendorName "Plug'n Play"
ModelName "L1715S "
HorizSync 30-83
VertRefresh 56-75
# Monitor preferred modeline (60.0 Hz vsync, 64.0 kHz hsync, ratio 5/4)
ModeLine "1280x1024" 108 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
# TV fullscreen mode or DVD fullscreen output.
# 768x576 @ 79 Hz, 50 kHz hsync
ModeLine "768x576" 50.00 768 832 846 1000 576 590 595 630
# 768x576 @ 100 Hz, 61.6 kHz hsync
ModeLine "768x576" 63.07 768 800 960 1024 576 578 590 616
EndSection
Section "Device"
Identifier "device1"
VendorName "nVidia Corp."
BoardName "NVIDIA GeForce 6 Series"
Driver "nvidia"
Option "DPMS"
EndSection
Section "Screen"
Identifier "screen1"
Device "device1"
Monitor "monitor1"
DefaultColorDepth 24
Subsection "Display"
Depth 8
Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "640x480" "480x360" "320x240"
EndSubsection
Depth 15
EndSubsection
Depth 16
EndSubsection
Depth 24
EndSubsection
EndSection
Section "ServerLayout"
Identifier "layout1"
InputDevice "Keyboard1" "CoreKeyboard"
InputDevice "Mouse1" "CorePointer"
Screen "screen1"
EndSection
To mi je vun vrglo v konzoli. 0:)
To toraj pomeni?
EDIT: Zvok spet ne dela pa sem napisal kill komandi... ;((
EDIT: 2 sam restartat morem igro aja ups...
Aja pa pozabil sem še povedati, da imam na velikih mapah kar lukne v teksturi ĆRNA BARVA. :(
To torej pomeni, da vstavi v xorg.conf tisto, kar sem napisal že v mojem 1. postu.
Ni pa nujno, da bo pomagalo.
Če ne bo, prilimi še rezultat ukaza
lsmod
oz. kakršenkoli ukaz že imaš za seznam naloženih modulov.
Slo-One ::
Ni delalo ker ma Linux MAndricva že namizje po defaultu 3d dveh 3d aplikacij pa ni hteu zagnanih met. AL PA JE ŠTEKALO... :D
Feisty Fawn je tukaj (strani: 1 2 )
539695 (7909) Matevžk
Tezave z ATI RADEON 9200 v FEDORA CORE 3
201611 (1507) CCfly
Linux vprašanja
Oddelek: Operacijski sistemi
313260 (2493) BigWhale
Linux / ATI Radeon / problem z driverji
132224 (2041) ahac
Aalchemy (strani: 1 2 )
Oddelek: Zvok in slika
637964 (7202) Senitel
