Fatal error
Fatal error
John Abruzzi ::
Danes sem inštaliral cod2. Ob zagonu igre se mi pokaže tole:
Kaj naj nardim;(
Good Guy ::
preinštaliraj driverje za grafično
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
StratOS ::
Tipično pri Cod.
Rešitev tukaj
Če malo prebereš kateri post :
The game error log says this right?
"CoD2 1.0 build win-x86 Oct 6 2005"
So I searched around a bit in the game folder and noticed that if I popped in the cd 1 of COD2 and explored the CD. I found the file "gfx_d3d_x86_s.dll" and replaced the same file in the Program Files/Activision/Call of Duty 2/gfx_d3d_x86_s.dll
I ran the game and I can now play it again! Its version 1.0, but oh well, I don't plan to update the patch until I complete the game now ha ha!
Thanks for recommendations
Running Direct X 9.0c :)
Darn patch!
Ilegalci :D
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
John Abruzzi ::
Hvala, sm zrihtov-rabu sm pa 2 ure. Me že glava buli:D ;((
Drgač sm pa mogu gonilnike za grafo, directx, pol pa še to k ni hotl delat;(( nakonc sm pa mogu še windows explorer;((
Call of Duty serija - pomoč in nasveti. (strani: 1 2 3 4 5 6 7 8 )
Oddelek: Igre
35685294 (28060) tropico2078
cod 2 zmrzne - win7
61815 (1516) Dejan5
Dober Singleplayer campain FPS špil?
Oddelek: Igre
355737 (4911) Bor H
Call of duty 2!ne dela server!problems!
Oddelek: Igre
276065 (4067) ViperR
Deus Ex 2: Invisible War (strani: 1 2 )
Oddelek: Igre
957388 (5639) Freelancer
