Forum » Pomoč in nasveti » Fatal error
Fatal error
StratOS ::
Tipično pri Cod.
Rešitev tukaj
Če malo prebereš kateri post :
The game error log says this right?
"CoD2 1.0 build win-x86 Oct 6 2005"
So I searched around a bit in the game folder and noticed that if I popped in the cd 1 of COD2 and explored the CD. I found the file "gfx_d3d_x86_s.dll" and replaced the same file in the Program Files/Activision/Call of Duty 2/gfx_d3d_x86_s.dll
I ran the game and I can now play it again! Its version 1.0, but oh well, I don't plan to update the patch until I complete the game now ha ha!
Thanks for recommendations
Running Direct X 9.0c :)
Darn patch!
Ilegalci :D
Rešitev tukaj
Darn patch!
Ilegalci :D
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
John Abruzzi ::
Hvala, sm zrihtov-rabu sm pa 2 ure. Me že glava buli
Drgač sm pa mogu gonilnike za grafo, directx, pol pa še to k ni hotl delat
nakonc sm pa mogu še windows explorer
| » | Call of Duty serija - pomoč in nasveti. (strani: 1 2 3 4 5 6 7 8 )Oddelek: Igre | 85292 (28058) | tropico2078 |
| » | cod 2 zmrzne - win7Oddelek: Pomoč in nasveti | 1815 (1516) | Dejan5 |
| » | Dober Singleplayer campain FPS špil?Oddelek: Igre | 5737 (4911) | Bor H |
| » | Call of duty 2!ne dela server!problems!Oddelek: Igre | 6065 (4067) | ViperR |
| » | Deus Ex 2: Invisible War (strani: 1 2 )Oddelek: Igre | 7388 (5639) | Freelancer |
