sistemska ura
sistemska ura
OOTBOXZY ::
Zanima me, ali obstaja program, ki bi naredil, da sistemska ura tece hitreje ali pocasneje. Recimo, da v pol ure naredi celo uro, ali obratno.
OOTBO XZY
StratOS ::
Sistemski uri se ne da nastavljati hitrosti :D, lahko pa programsko narediš in nastaviš uro, tako da bo ustrezala tvojim potrebam.
V Winxp lahko preko konzole z time ukazom ali pa programsko.
Displays or sets the system time.
TIME [/T | time]
Type TIME with no parameters to display the current time setting and a prompt
for a new one. Press ENTER to keep the same time.
If Command Extensions are enabled the TIME command supports
the /T switch which tells the command to just output the
current time, without prompting for a new time.
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
[Java] Zasnova shoot em up igre
Oddelek: Programiranje
111586 (1265) PecenkA
java / mysql / počasne poizvedbe
51092 (1021) BRBR
Pomoč za excell
Oddelek: Programska oprema
51648 (1554) Silikon
Nastavitev ure v UNIX-u?
Oddelek: Operacijski sistemi
71969 (1794) sverde21
Windows Commander 5.1
53511 (3511) darh
