Forum » Pomoč in nasveti » sistemska ura
sistemska ura
OOTBOXZY ::
Zanima me, ali obstaja program, ki bi naredil, da sistemska ura tece hitreje ali pocasneje. Recimo, da v pol ure naredi celo uro, ali obratno.
OOTBO XZY
OOTBO XZY
StratOS ::
Sistemski uri se ne da nastavljati hitrosti :D, lahko pa programsko narediš in nastaviš uro, tako da bo ustrezala tvojim potrebam.
V Winxp lahko preko konzole z time ukazom ali pa programsko.
Displays or sets the system time.
TIME [/T | time]
Type TIME with no parameters to display the current time setting and a prompt
for a new one. Press ENTER to keep the same time.
If Command Extensions are enabled the TIME command supports
the /T switch which tells the command to just output the
current time, without prompting for a new time.
TIME [/T | time]
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | [Java] Zasnova shoot em up igreOddelek: Programiranje | 1585 (1264) | PecenkA |
| » | java / mysql / počasne poizvedbeOddelek: Programiranje | 1091 (1020) | BRBR |
| » | Pomoč za excellOddelek: Programska oprema | 1648 (1554) | Silikon |
| » | Nastavitev ure v UNIX-u?Oddelek: Operacijski sistemi | 1969 (1794) | sverde21 |
| » | Windows Commander 5.1Oddelek: Novice / Operacijski sistemi | 3510 (3510) | darh |
