DEP (Data Execution Prevention)
zupinio ::
Mam en hud probllem.
Včeraj sem se spravo pretvarjat videoposnetek v avi format.programček mi to naredi, vse lepo in prav, zdaj pa ne moram več gledat filmov oz. nobenih video datotek.BS player in tudi WMP mi zablokirata, javita napako in vključi se mi ta DEP (Data Execution Prevention), ki mi javi da je to datoteka, ki bi lahko škodovala mojemu računalniku, zato se mi tudi windows exsplorer zapre.
ima kdo kakšno idejo kako bi lahko to napako odpravo oz. izključo ta DEP.
StratOS ::
- How can I tell if DEP is available on my computer?
To open System Properties, click Start, point to Settings, click Control Panel, click Performance and Maintenance and then click System.
Click the Advanced tab and, under Performance, click Settings.
Click the Data Execution Prevention tab.
Evo
- V boot.ini na rootu :
primer :
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windo ws XP Professionnel No DEP" /fastdetect /NoExecute=AlwaysOff
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windo ws XP Professionnel DEP " /fastdetect /NoExecute=OptIn
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
Boot.ini in Windows XP SP3 problem
191936 (1685) kixs
Pomoč pri bootanju vista, xp
132196 (2058) matjaz23
en problem
61510 (1427) Good Guy
Windows XP PRO Boot problem
81688 (1655) 50Cent
DEP error
71637 (1579) boko34
