Forum » Omrežja in internet » Net se mi ne vzpostavi nazaj samodejno
SkyX ::
Em tkole mam kableski internet preko UPC Telemach, imam modem TCM420, iz modema imam speljan utp kabel v strežnik na katerem poganjam freebsd 6.1. V samem stržniku imam 3 mrežne 2 za vsak računalnik posebej in 1 za modem. nastavitve za net v rc.conf imam naslednje:
ifconfig_rl0="DHCP"
natd_enable="YES"
ifconfig_rl1="inet 192.168.0.1 netmask 255.255.255.0"
natd_interface="rl0"
router_flags="-q"
router="/sbin/routed"
router_enable="YES"
defaultrouter="82.192.58.1"
gateway_enable="YES"
Problem pa je naslednji:
- na vsake 1 ali do 3 dni mi pade net dol in se mi ne vzpostavi samodejno nazaj dokler ne sklopim modema iz vtičnice in ga priklopim nazaj, zakaj se mi samodejno ne vzpostav anzaj je problem pri meni ali pri ISP ?
Priložene slike iz modema(log/statistika)
[url=http://shrani.si/o.php?modemdiagn109110...
[url=http://shrani.si/o.php?modemevent109110...
[url=http://shrani.si/o.php?modeminiti109110...
[url=http://shrani.si/o.php?modemmain1091106...
Na sliki se ne vid vseh logov zato sem jih prilepu še tukaj:
Time Priority Description
Time Not Established Error (4) ToD request sent- No Response received
Time Not Established Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Time Not Established Warning (5) DHCP RENEW WARNING - Field invalid in response
Time Not Established Notice (6) TLV-11 - unrecognized OID
Time Not Established Critical (3) DHCP WARNING - Non-critical field invalid in response.
Time Not Established Critical (3) No Ranging Response received - T3 time-out
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC f...
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/Q...
ifconfig_rl0="DHCP"
natd_enable="YES"
router_flags="-q"
router_enable="YES"
| » | KKS > Triera > UPC > Telemach (strani: 1 2 3 4 … 372 373 374 375 )Oddelek: Omrežja in internet | 3622143 (1819) | unn:doo |
| » | kabelski internet in težave [Telemach]Oddelek: Omrežja in internet | 2492 (2373) | V-i-p |
| » | Telemach router-modem problemOddelek: Omrežja in internet | 3772 (3515) | gregyk |
| » | Problemi z start up fajliOddelek: Pomoč in nasveti | 1243 (1099) | FuBu |
| » | Internet mi ne dela!!!Oddelek: Omrežja in internet | 2151 (1842) | Frici |
