problem pri linux ubuntu
hotjamajkan ::
pri inštalaciji ubunta sem prišel do petega koraka kjer je potrebno nastavit datotečni korenski sistem. Mi lahko razložite kako to nastavit ker vsakič napiše ni datotečnega korenskega sistema
drola ::
Ubuntu 6.10 Edgy Eft ima bug v namestitvenem programu pri LiveCDju. Tole je workaround, sicer pa pri tekstovni različici namestitve teh težav ni:
You can also quickly get around the "no root file system" error by changing the validation.py file.
When running the liveCD, but prior to installation:
Code:
sudo gedit /usr/lib/ubiquity/ubiquity/validation.py
go to the end of the file, and edit the line that says
Code:
if not root:
 result.add(MOUNTPOINT_NOROOT)
Change to:
Code:
if not root:
 pass
Make sure you leave the indentation in before the word "pass". Save the file, close it, and then you can run the installer.
Now, when you run the installer, it won't check for a "/" directory, so make sure you have one!
Klik!
https://drola.si
  • spremenil: drola ()
hotjamajkan ::
Kerega mi pa predlagate da naj uporablam. Oz. kje ga naj snamem
SMB povezava Winows 10 s Synology NAS
Oddelek: Operacijski sistemi
324353 (3619) dukedl
C# težava
Oddelek: Programiranje
234850 (3696) mladec
OpenSUSE pomoč
111341 (1234) Redorange
Problem instalacije XP - SATA disk
162838 (1844) Duhec
Skoraj že obupal pri inštalaciji Linuxa
141761 (1580) Brane2
