Forum » Strojna oprema » 8x AGP na 4x AGP
8x AGP na 4x AGP
darkcloud88 ::
A lahko grafično kartico z 8x AGP vodilom priklučim na matično ki ima 4x AGP slot? Trenutno mam Geforce2 MX400...bi pa nabavu ati radeon 9550 ..al pa katero iz serije 9600.
aja,procesor je AMD Athlon XP 1600+ , matična pa K7S5A
- spremenil: darkcloud88 ()
darkcloud88 ::
a to je vseeno da ma moja geforce2 ta priklop drugače oblikovan kot npr. radeon9550? (fizično gledano)
darkcloud88 ::
http://www.e-trgovina.com/productdetail...
geforce2 ma tko 3 manjše reže, radeon ma pa samo eno mal večjo,pa eno manjšo..a se to fizično lahko potem sploh priklopi?
dejansan ::
ja, kot so ti že povedali lahko
ne bi pa mogel radeona stlačit v agp 2x, ker so te reže ravno kontra obrnjene
dejansan
dejansan ::
kaj tebe spet mede
ni samo razlika v voltaži tudi fizično se razlikujejo
konkretno tegale radeona iz linka ne moreš stlačit v agp 2x port
drugače pa kar je najbolj pomembno darkcloud88 ta tvoja zamisel bo delovala brez problemov
dejansan
amigo_no1 ::
http://www.geek.com/glossary/glossary_s...
AGP 8x - This AGP standard features a parallel 32-bit bus running at 533MHz effectively (66MHz*8 literally) for a maximum data transfer rate of 2GB/second. This is the last parallel form of AGP, and is compatible with all previous AGP cards.
Accelerated Graphics Port @ Wikipedia
AGP cards are backward and forward compatible within limits. 1.5 V-only keyed cards will not go into 3.3 V slots and vice versa, though "Universal" slots exist which accept either type of card. AGP Pro cards (rarely used) will not fit into standard slots, but standard AGP cards will work in a Pro slot. Some newer cards like nVidia's GeForce 6-series or ATI's X800-series only have keys for 1.5 V to prevent them from installing in older mainboards without 1.5 V support. The graphic cores can only handle 0.8 V for AGP8x and 1.5 V for AGP4x and will be damaged by 3.3 V slots. Some of the last modern cards with 3.3 V support were the nVIDIA GeForce FX5000-series and the ATI Radeon 9500/9700/9800(R350) (but not 9600/9800(R360)).
- spremenilo: amigo_no1 ()
dejansan ::
kaj si hotel s tem povedati, da še zmeraj ne kapiraš ali da si pokapiral da ni vse isti šmorn?
dejansan
OZZY ::
Eni so teorektiki, drugi pa praktiki..on pač spada med prve....pač tako je danes, da ko neki preberejo mislijo, da vejo vse...
Go with the flow.
- spremenil: OZZY ()
darkcloud88 ::
za grafično bi dal tam okol 15.000sit. Bolj se nagibam k 9600..ne vem še katero serijo. Razmišlam še ali bom rabljeno ali novo. A kaj priporočate?
AngelOfDeath ::
15k je preveč za 9600 pro serijo vredna je kvečjemu 5-8k :)
računaj da za 15k dobiš rabljeno 6600 Ki poje 9600 pro za malo malco za 12k se prodavajo nove 6200
Vendar je pri tebi težava procesor ki je počasen mogoče bo kdo drug dal primernejšo grafiko.
edit: Slovnica
darkcloud88 ::
kaj pa ta 9600xt
a mi lahko potem priporočiš katera grafična je tista, katere zmogljivosti bo moj procesor še lahko izkoristu?
pa še to me zanima kje imajo tako nizke cene?
dejansan ::
ta grafika je drugače ok samo cena je previsoka
malo spremlaj oglase pa vzemi kakšno 9600pro za tam okrog 8000, lahko tudi 9550 samo glej, da bo imel 128 bitno pomnilniško vodilo, se pravi, da ne bo SE
dejansan
darkcloud88 ::
nekje sm prebrau da naj bi bla 9600 PRO slabša kot 9500 PRO... še vedno pa ne vem kje bi lahko kupil novo 9600pro za samo 8k..ali imaš v mislih rabljeno? a mi lahko konkretno poveš v kateri trgovini (v ljubljani) majo ugodne cene za grafične kartice. Ker tako poceni sem zasledil samo rabljene....pa sem gledal tudi na spletnih trgovinah.
dejansan ::
jaz sem imel v mislih rabljeno ja
offtopic: a je že kdo naročal tle pri pixmania
dejansan
darkcloud88 ::
Klemzz ta ponudba mi je dost ušeč..me pa tud zanima če je že kdo naroču pri pixmania,ker bi res najraje kar to 9600XT nabavu!!
| » | Katero grafično ste že imeli ? (strani: 1 2 3 4 )Oddelek: Strojna oprema | 24663 (17728) | Janac |
| » | Grafična za 4x AGPOddelek: Kaj kupiti | 2301 (1764) | dejansan |
| » | grafična kartica (strani: 1 2 )Oddelek: Kaj kupiti | 5554 (4719) | sid911 |
| » | Katero graficno kartico uporabljate? (strani: 1 2 3 4 )Oddelek: Strojna oprema | 14024 (10560) | mtosev |
| » | NASA World WindOddelek: Programska oprema | 3121 (3039) | Person |
