Forum » Programska oprema » Program Lock my Folder in velika tezava
OmegaM ::
Kot vidite sem sel malo sprobat omenjen program, sedaj pa sem najprej sel testirat zaklenit/odklenit direktorij in je bilo vse dobro in prav, nato disk, sedaj pa naenkrat nimam vec dostopa do diska pa ceprav sem odstranil zaklep diska?! Sem se poizkusil vse enkrat ampak nic ne pomaga! Kaj naj storim?
Ni nam lahko, bo pa boljše!!!
OmegaM ::
Sedaj sem program se zaprl pa odprl pa diska ne morem niti gor dat na seznam v tem programu ker kao "access denied"
krho ::
AFAIK je zadeva čisto useless. pod safe mode imaš dostop do vseh podatkov..
OmegaM ::
Pozdravljeni
Spet odpiram to temo
Namrec, sedaj pa je punca uporabljala program in nazadnje to proti koncu avgusta, sedaj pa skorajda november, geslo je pozabila, skusam nekak priti do dokumentov, pa mi ne uspe.
Gesla se nikakor ne spomni, skusal sem pod varnim nacinom, kaj mi je za storiti, ima kdo kako idejo?
"uporablja" pa verzijo 5.7.5, koliko je meni znano
Hvala
Hvala
- spremenilo: OmegaM ()
Matej_K ::
Q39. I have forgotten my password, how can I get my files back?
You can use your Master Key, which is your registration key in the password text field, and click the OK button to access your files. Master Key is available to registered users only. Enabling this allows people who have forgotten their password to use their registration key in place of a password to unlock their files. This option is checked by default in the registered version. You can uncheck it if you feel it would be even safer. However, you should uncheck it only if you have a very good memory. But for oblivious people like me, it is better to keep it checked, because it is the only way you can get your files back if you forget your password.
To je za progam folder lock..nevem če je to isto..probaj in poročaj
| » | Po Sloveniji se širi Cryptolocker (strani: 1 2 )Oddelek: Novice / Varnost | 36417 (23413) | alro |
| » | Kim Dotcom zagnal kriptografsko oblačno storitev Mega (strani: 1 2 )Oddelek: Novice / Omrežja / internet | 49415 (44190) | snezak |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20202 (17042) | arrigo |
| » | star laptop, zaklenjen bios, disk pa write protectedOddelek: Pomoč in nasveti | 1762 (1535) | Spajky |
| » | Izšel TrueCrypt 4.0Oddelek: Novice / Ostala programska oprema | 5821 (4962) | poweroff |
