En zelo čuden bug
En zelo čuden bug
fastfury ::
Imam naslednji problem:
prižgem komp in vse se normalno zalaufa, pol k hočem odpret bilo kakšen program (datoteke .exe) se te nočejo odpret, PC pa ni zamrznjen saj se lahko normalno sprehajam po datotekah ampak noben .exe file se noče odpret, niti ctrl+alt+del se noče odpret. Po 10-15 min pa se vse normalno odpira in dela bp:\ To se ne dogaja samo kakšen krat ampak je pri vsakem zagonu tko, da morem počakat 10-15 min, preden lahko odprem kakšen program. Virusov kao ni, ker sem že z dvemi up to date antivirusi prečekiral PC in je kao brez virusov. A kdo ve kaj je to, pomoč prosim:'(
Imam pa angleški XP Pro SP2.
  • spremenil: fastfury ()
5er--> ::
Mrežni kartici določi IP.
How to change the IP address that is assigned to a network adapter1.
Log on to the computer by using the Administrator account.
2. Click Start, click Settings, and then click Control Panel.
3. In Control Panel, double-click Network and Dial-up Connections. The Network and Dial-up Connections dialog box opens.
4. Right-click the local area connection that you want, and then click Properties. The Local Area Network Connection Properties dialog box opens.
5. In the Components checked are used by this connection box, click Internet Protocol (TCP/IP), and then click Properties. The Internet Protocol (TCP/IP) Properties dialog box appears.
6 . Click Use the following IP address if you want to specify the IP address for the network adapter.
7. In the IP address box, type the IP address that you want to be assigned to this network adapter. This IP address must be a unique address in the range of addresses that are available for your network. Contact the network administrator to obtain a list of valid IP addresses for your network.
fastfury ::
A si ziher, da je v tem problem, ker me zanima zakaj ga enkrat ni motilo, da nima statičnega IP??
5er--> ::
Problem je, ker mrežna ob vsakem zagonu išče naslov. Sicer pa probaj. Še vedno lahko vrneš na Obtain an IP address automatically.
fastfury ::
Kje pa lahko dobim en IP naslov za ga vpisat tja notr?
zaejec ::
navadno je vredu vse od 192.168.1.100 do 129.168.1.255 . ce se motim, naj me kdo popravi, nisem ravo strokovnjak za mreze.
jaz sem tvoj problem resil takole:
Control Panel\Administrative Tools\Services
poisci service "Workstation" in ga onnemogoci(disable)
ce bos pogledal opis tega "servisa" bos videl da je tesno povezan z networkingom, zato probaj prej z IPjem.. sicer pa jaz, po tistem ko sem servis izklopu nisem imel nobenih tezav, zato sem ga imel izklopljenega :)
fastfury ::
Hvala, bom probal pa sporočim.:)
zaejec ::
v zgornjem postu sem se zatipkal
pravilno je od 192.168.1.100 do 192.168.1.255
fastfury ::
Sm probal oba predloga, posebej, skupaj in nč ne deluje. Zgleda da je težava za ta bug nekje drugje:( Ima še kdo kakšen predlog?
fastfury ::
A ma še kdo kakšen predlog?
DominusSLO ::
Probaj izklopit kabel od mrežne in zalaufat pc, da vidimo, če je to problem.
cpu&nb watercooled, gpu on air at the moment
fastfury ::
Bom probal čez vikend:)
tvich ::
Poskusi še zbrisat tole iz registra:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ Explorer\RemoteComputer\NameSpace\{D6277990-4C6A-11CF-8D87-00AA0060F5BF}]
To je sicer v zvezi z brskanjem po drugih računalnikih v mreži, samo se splača sprobat.
And AC said, ''LET THERE BE LIGHT!''
And there was light--
Vajenc ::
MOgoče se ti tako dolgo zaganja antivirusnik, probaj ga odinštalirat in poizkusi znova.
fastfury ::
Ni antivirus. Sm že sprobal.
Stratus ::
Poskusi bootat v "safe mode" če se normalno dvigne in deluje (seveda brez gonilnikov) potem se spomni kaj si nazadnje spreminjal, ko je še vse delovalo normalno. katero mrežno kartico imaš in katero plato ( če je Intlova poglej če imaš slučajno inštaliran Intel Aplication Accelerator ta dela težave podobne kot si jih navedel). Poskusi tudi onemogočit mrežno kartico v "Device Managerju". Če je možno priti v Task Manager takrat ko ti šteka poglej kateri proces ti jemlje CPU.
Javi kaj si ugotovil pa bova nadaljevala
Nije žvaka za seljaka !
A ma kdo žvečilni :)
fastfury ::
malo sm raziskal zadevo in stvar je sledeča:
ko vžgem PC dela vse normalno, ko pa vzpostavim zvezo ADSL potem za nadaljnih 5-10 minut ne morem zagnat nobenga programa, sicer PC ne zamrzne lahko se še vedno nomramlno sprehajam po mapah ampak noben program noče štartat niti Task Manager. Po 10 minutah pa vse dela normalno.
5er--> ::
Če probaš vzpostavit povezavo s čim drugim kot windowsovim wizardom?
Npr: raspppoe ali pa cfos?
fastfury ::
Sm poskušal in mi noben program ne dela. Oba napišeta, da ne zaznata modema, ku češ da ga ni:\
težave z Linksys Wireless- WRT54G routerjem
424206 (2125) AC_DC
Zaflešan Linksys wrt160nl
Oddelek: Omrežja in internet
91625 (1362) Spc
ICS Internet Connection Sharing in IP naslov 192.168.0.1
93321 (2532) MrStein
[Windows][XP] Zakaj po zagonu traja še par minut, da vse normalno dela?
Oddelek: Operacijski sistemi
422935 (2254) bluefish
pohitritev dsl ali kabelskega neta v win xp
62190 (1928) BlueRunner
