mshta.exe????
mshta.exe????
lanzur ::
Na starem računalniku ko ga zalavfam se mi na začetku zalavfajo 4procesi mshta.exe
Ima kdo idejo kako se ga znebiti? Iskal sem po netu vednar videl da je to tudi nek Microsoftov proces
Help>:D
matvoz ::
mshta.exe is a part of Microsoft Windows Operating System which is needed to execute .HTA files. This program is a non-essential system process, but should not be terminated unless suspected to be causing problems.
Microsoft described an HTA as running much like an .exe file
"But I didn't download anything to allow this happen!" you might say. Well, if you don't regularly update your browser or use Windows Update to install security fixes, then you did. Several of these hijackers exploit an Internet Explorer/Outlook Express bug that let's them secretly install a program (called an ActiveX control) on your system just by viewing their Web page. Hijackers exploiting this bug will insert one or several .hta files on your hard drive which run when you start up Windows.
imas kak antispyware in/ali antivirus instaliran? kaj pa firewall? je ta pc povezan na net?
lahko je pa samo false alarm :)
Varnost
1125029 (6730) techfreak :)
Diagnostično orodje za WD
Oddelek: Programska oprema
145050 (4910) clovk
Win XP SP2 in Blutooth
82449 (2294) jast
Logitech MouseWare bug (?)
272610 (2206) Swiwer
Iščem alternativo vuduju
122450 (2214) Arthur
