Forum » Strojna oprema » CD-RW in DVD -> kako priklopit?
Gh0st ::
CDRW je pametno ce ga das na MASTER, se bolje pa ce ga mas na celem SECONDARY kanalu.
torej:
primary master: disk
primary slave: dvd (optional)
sec. master : cdrw
sec. slave : dvd (opt)
torej:
sec. master : cdrw
you might start believe in Gh0st stories. you're in one. :)
BlackHole ::
Ni res (čeprav ti bo morda delalo), samo če boš hotel DVD hacknit, ga boš moral imeti na SEC master.
Jaz imam tako:
1. disk - PRI master
2. disk - PRI slave
DVD - SEC master
RW - SEC slave
In vse dela brez problemov.
Jaz imam tako:
2. disk - PRI slave
DVD - SEC master
RW - SEC slave
| » | jumperji na IDE ATA diskuOddelek: Pomoč in nasveti | 1615 (1498) | turist1 |
| » | problemi z DMA & pekacem v winXPOddelek: Pomoč in nasveti | 2155 (1908) | fictionel |
| » | teac 40x neče pospešt na 40xOddelek: Strojna oprema | 3322 (3105) | Han |
| » | liteon 40/12/48 ali teac40/12/48Oddelek: Kaj kupiti | 1557 (1152) | SmoKey |
| » | priklop pekačaOddelek: Pomoč in nasveti | 1785 (1606) | drofa |
