CD-RW in DVD -> kako priklopit?
kuntek ::
Kako priklopit CD-RW in DVD??? Kateri master in kateri slave?
Gh0st ::
CDRW je pametno ce ga das na MASTER, se bolje pa ce ga mas na celem SECONDARY kanalu.
torej:
primary master: disk
primary slave: dvd (optional)
sec. master : cdrw
sec. slave : dvd (opt)
you might start believe in Gh0st stories. you're in one. :)
BlackHole ::
Ni res (čeprav ti bo morda delalo), samo če boš hotel DVD hacknit, ga boš moral imeti na SEC master.
Jaz imam tako:
1. disk - PRI master
2. disk - PRI slave
DVD - SEC master
RW - SEC slave
In vse dela brez problemov.
ToniT ::
Jaz se strinjam z Gh0stom, zakaj tako, pa si lahko prebereš tukaj
jumperji na IDE ATA disku
111615 (1498) turist1
problemi z DMA & pekacem v winXP
282155 (1908) fictionel
teac 40x neče pospešt na 40x
173322 (3105) Han
liteon 40/12/48 ali teac40/12/48
151557 (1152) SmoKey
priklop pekača
61785 (1606) drofa
