formatiranje
formatiranje
simoncek ::
Zanima me samo kako bi lahko sformatiral disk, da ne bi bilo gor nič več podatkov? Disk je en sam in gor so windowsi. Preko oken ne gre, ker se ne pustijo sformatirat.
Se pravi samo format diska brez operacijskega sistema.:\
simoncek
apachee ::
To partition and format your hard disk by using the Windows XP Setup program:
1. Insert the Windows XP CD-ROM into your CD-ROM drive or DVD-ROM drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer.
Note To start your computer from the Windows XP CD-ROM (or from the startup disk), your computer must be configured to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive. In some cases, you may have to modify your computer's BIOS settings to set this configuration. For information about how to configure your computer to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive, see the documentation that is included with your computer, or contact the computer manufacturer.
2. If you are starting the computer from the Windows XP CD-ROM, select any options that are required to start the computer from the CD-ROM drive if you are prompted to do this.
3. At the Welcome to Setup page, press ENTER.
4. Press F8 to accept the Windows XP Licensing Agreement.
5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
POZOR: JAZ BI TVOJO EDINO PARTICIJO POBRISAL IN USTVARIL 2 NOVI V RAZMERJU cca (C:\ 20% : D:\ 80%)
POSTOPEK JE SLEDEČ:
6. All the existing partitions and the unpartitioned spaces are listed for each physical hard disk. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition by using unpartitioned space. If you press D to delete an existing partition, you must then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each of the existing partitions that you want to use for the new partition. When all the partitions are deleted, select the remaining unpartitioned space, and then press C to create the new partition.
Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition.
7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
8. Repeat Steps 4 and 5 to create additional partitions if you want them.
9. If you want to install Windows XP, use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER. If you do not want to format the partition and install Windows XP, press F3 two times to quit the Windows Setup program, and then do not follow the remaining steps. In this case, you must use a different utility to format the partition.
10. Select the format option that you want to use for the partition, and then press ENTER. You have the following options:
• Format the partition by using the NTFS file system (Quick)
• Format the partition by using the FAT file system (Quick)
• Leave the current file system intact (no changes)
The option to leave the current file system intact is not available if the selected partition is a new partition. The FAT file system option is not available if the selected partition is more than 32 gigabytes (GB). If the partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm). If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
Note If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you will be prompted to select a file system for both the System and startup partitions.
You can't win without The Finn!
fahrenGONE ::
East-Tec Eraser (very cool!) in Acronis Drive Cleanser (tudi cool).
Mac OS Snow Leopard na PC
Oddelek: Operacijski sistemi
485655 (4203) Gray_Warden_
kako razsiriti datoteko večjo od 4gb?
131720 (1720) Mr.B
od 160gb diska prikaže le 32, prvo mi je v partition magic prikazalo 160...
202514 (2190) sirotka
trdi disk hitachi
282532 (2167) kerrigh
Kako rešiti podatke???
Oddelek: Programska oprema
61890 (1807) dr.J
