Forum » Omrežja in internet » A1 xDSL
A1 xDSL
MiranRxx ::
3 vrstica maribor3-vlan-5amis.net
4 vrstica www.amis net in to je vse.
Sem pa na amisovi centrali, skoraj sigurno, saj imam popolnoma razvezan inernet itn.
Za vse ki bi radi poleteli ali se šolali: http://www.lcm-club.si/
jadralno.letenje@amis.net
DeletedUser ::
tle se vid... http://speedtouch.lan/cgi/b/dsl/dt/?ce=...
Vendor ID (Local/Remote): TMMB / BDCM
če piše "BDCM" pol je amisov dslam
MiranRxx ::
Tole men napise, kaj pa to pomeni, pa jaz ne vem.
Kdo kaj ve kaj to pomeni, je dobro ali slabo?
Link Information
Uptime: 0 days, 10:47:49
Modulation: G.992.5 Annex B
Bandwidth (Up/Down) [kbps/kbps]: 920 / 9.837
Data Transferred (Sent/Received) [MB/GB]: 5,47 / 21,21
Output Power (Up/Down) [dBm]: 13,0 / 18,5
Line Attenuation (Up/Down) [dB]: 14,5 / 27,5
SN Margin (Up/Down) [dB]: 14,5 / 10,0
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 25 / 0
FEC Errors (Up/Down): 13 / 37.749
CRC Errors (Up/Down): 0 / 19
HEC Errors (Up/Down): 10 / 14
Link Information
MiranRxx ::
kocka mi ne, samo obcasno mi malo postoji slika delno za trenutek. Samo nekateri kanali.
Tako da skoraj ne opazim.
Prej sem imel sobno anteno in je to prava amerika.
Pravkar zraven gledajo TV in se mi zdi slika suepr. Naj le tako ostane!
- spremenil: MiranRxx ()
kulSMS ::
jeje997 koliko pa ima tisti kolega (6km od centrale z 2mbit) resničen upload/download?
meni je na 2mbit (2048/384) razdalja 4,5km
max upload= 370kbps (46,3 kBps)
max download= 1648kbps (206 kBps) --> povprečno je okrog 195kBps
stabilnost: OK
Link Information
Uptime: 0 days, 13:26:27
Modulation: G.992.1 Annex B
Bandwidth (Up/Down) [kbps/kbps]: 588 / 2.422
Data Transferred (Sent/Received) [MB/MB]: 283,93 / 585,36
Output Power (Up/Down) [dBm]: 13,0 / 18,0
Line Attenuation (Up/Down) [dB]: 31,5 / 52,0
SN Margin (Up/Down) [dB]: od 13,0 do 14,0 / od 9,0 do 12,5
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 1.141 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 1.106
HEC Errors (Up/Down): 0 / 685
Če kdo potrebuje programček, ki mu iz modema periodično bere zgornje podatke in mu jih shranjuje v tabelo ga lahko prenese Tukaj. (priporočeno je, da se ga odzipa v prazno mapo, ker program naredi nekaj datotek)
stabilnost: OK
Link Information
jerry2000 ::
Lahko za ta program kdo garantira da ni virus. Meni AntiVir takoj javi, da je virus v datoteki :-(
Jerry and Tom
DeletedUser ::
Scan taken on 29 Aug 2007 15:37:23 (GMT)
A-Squared Found nothing
AntiVir Found TR/Delphi.Downloader.Gen
ArcaVir Found nothing
Avast Found nothing
AVG Antivirus Found nothing
BitDefender Found nothing
ClamAV Found nothing
CPsecure Found nothing
Dr.Web Found nothing
F-Prot Antivirus Found nothing
F-Secure Anti-Virus Found nothing
Fortinet Found nothing
Kaspersky Anti-Virus Found nothing
NOD32 Found nothing
Norman Virus Control Found nothing
Panda Antivirus Found nothing
Rising Antivirus Found nothing
Sophos Antivirus Found nothing
VirusBuster Found nothing
VBA32 Found nothing
zgleda ok
Avast Found nothing
NOD32 Found nothing
VBA32 Found nothing
zgleda ok
kulSMS ::
Lahko mi verjameš na besedo, da ni nobenega virusa, ali pa še enkrat povlečeš program in pregledaš kodo, ki je priložena. Thomson DSL
Kaj pa drugače vam dela? jaz imam Thomsona 706i. A na drugih tudi dela?
kulSMS ::
spremenil sem še način prenašanja podatkov iz modema, tako da sedaj ne bi smelo javiti niti tega AntiVir Found TR/Delphi.Downloader.Gen.
jerry2000 ::
A ne, ne javlja več. Saj ne da sem sumnjičav, samo nikoli pa ne veš kdo je na drugi strani. Bom jutri probal, ko me preklopijo iz Siola, 2.5km, prosil sem za 10Mbit linijo...
Upam, da se da temu Thompsonu spremeniti lokalni IP, ker moje omrežje je na 192.168.0.x.
Jerry and Tom
- spremenilo: jerry2000 ()
kulSMS ::
Danes sem ugotovil, da tudi meni dela download okrog 250kBps (in ne 200kBps), sem včeraj testiral samo iz amisovega pubilc ftp-ja in od tam več kot 205 ni šlo.
Zgleda, da sem narobe sklepal, da bi od tam moralo prenašat na maximum.
MiranRxx ::
KulSMS, meni tvoj programcek lepo deluje.
Ti posljem kaj za kaksno analizo?
LP Miran
LP Miran
strictom ::
Cca. 2.5km od centrale in 10Mbs/768Kbs šiba z mogoče 100Kbs nihanji. Super je tale amis.
D-PaX ::
Nekateri, ko so testni uporabniki AMISA imajo zastonj net in tv :) hitrost 20mb/s. Imam kolega, ki je testni uporabnik že 1leto ima net free. :)
Eni so pač srečkoti. :) V prodaji pa še ni tega paketa pri amisu.
Paxy
globe ::
Tut jest menjavam ponudnika in saltam na amis. Danes sem dobil v podpis pogodbo, kero moram izpolnit in jo poslat. Ko sem navajal podatke sem zravn dodal se, da bi rad imel tut telefon pri njih. V podpis sem dobil samo pogodbo za internet. Mi bojo sami spremenil in postimal se telefonsko linijo?. Trenutno imam siol isdn, kterga bi se rad znebil. Koliko me pride cenovno internet 2mbs + telefon pri amisu? hvala
Ted ::
Zdaj majo akcijo po kateri dobiš 4/0,765 + telefon za 25 evrov. Je pa problem v tem, da očitno na tvoji lokaciji še nimajo svoje centrale (ali pa tega ne vedo) in zato ne moreš vzeti njihove telefonije - ostaneš na ISDN-ju. Lahko poveš na kateri centrali si?
Mah...
globe ::
sem najprej poslal, zraven se svoj tel st. in so mi odgovoril, da je mozen priklop. sem se posebi navedu, da bi rad dal stran isdn in da bi mel tut telefon pri njih. tko da bi moralo bit mogoce. drgac sem pa na centrali globoko.
jerry2000 ::
Jutri me priklopijo. V pogodbi sem prosil statični IP. Kako naj vem ali imam statičnega jutri ko vklopim modem?
Jerry and Tom
jerry2000 ::
Tako dobil sem Amis, bom poročal, kot sem obljubil. Malo sem razočaran, ker se mi menda modem poveže na 8.6/1Mbit, samo hitrosti so pa download samo 4, upload pa 996Kb/sek.
Kako je mogoče da imam tako dober upload (naročil sem 1) in tako slab download (naročil sem 10)... Ali če si zmanjšam upload na 768 imam potem download lahko večji?
Prilagam test, meni nič ne pove, morda kdo razume tole?
Datum, Cas: Uptime: Modulation: Bandwidth (Up/Down) [kbps/kbps]: Data Transferred (Sent/Received) [KB/KB]: Output Power (Up/Down) [dBm]: Line Attenuation (Up/Down) [dB]: SN Margin (Up/Down) [dB]: Vendor ID (Local/Remote): Loss of Framing (Local/Remote): Loss of Signal (Local/Remote): Loss of Power (Local/Remote): Loss of Link (Remote): Error Seconds (Local/Remote): FEC Errors (Up/Down): CRC Errors (Up/Down): HEC Errors (Up/Down):
31.8.2007 13:45:15 0 days, 0:40:22 G.992.5 Annex B 1.126 / 10.289 48,00 / 24,00 13,0 / 19,0 16,0 / 28,0 10,5 / 9,0 TMMB / BDCM 0 / 0 0 / 0 0 / 0 0 5 / 0 16 / 230 0 / 5 13 / 5
Jerry and Tom
kulSMS ::
SN Margin : 10,5 / 9,0 je nizek.
Če bi bil še manjši bi bili verjetno problemi z stabilnostjo linije.
Kje si pa testiral download?
Da nisi tako kot jaz iz amisovega ftp-ja.
jerry2000 ::
Joj imam neurejeno, bom popravil malo...
Ja z Amisovega ftp-ja so mi dali ta navodila. Potem s speedtest.si in pa z speed.amis.net. Vse se tam ustavi pri 5 max. Kako pa da je upload max?
A S/N ratio je slab že? Kaj to pomeni, da je slaba parica? Modem se menda poveže z 8.8 Zakaj do mene potem pride le 5?
Datum, 31.8.2007
Cas: 13:45:15
Uptime: 0 days, 0:40:22
Bandwidth (Up/Down) [kbps/kbps]: 1.126 / 10.289
Data Transferred (Sent/Received) [KB/KB]: 48,00 / 24,00
Output Power (Up/Down) [dBm]: 13,0 / 19,0
Line Attenuation (Up/Down) [dB]: 16,0 / 28,0
SN Margin (Up/Down) [dB]: 10,5 / 9,0
Loss of Signal (Local/Remote): 0 / 0
Error Seconds (Local/Remote): 5 / 0
FEC Errors (Up/Down): 16 / 230
CRC Errors (Up/Down): 0 / 5
HEC Errors (Up/Down): 13 / 5
Datum, 31.8.2007
Cas: 13:45:15
Jerry and Tom
Ted ::
Oddaljenost oz. kvalitetno linije gledaš pri Line Attenuation. Download linijo maš na 28, oddaljenost do centrale maš okoli 2,5 km. Sn Margin pa ti pove stabilnost na liniji, ti maš že precej nizkega in če bi mel višjo hitrost bi še bolj padel, to pa pomeni nadležno prekinjanje in nestabilno linijo. Kolikor je videti se ti modem lepo poveže 10/1, zakaj prenos ni večji kot 5 mega je pa drugo vprašanje, po moje bi moralo, poskusi najti dober vir.
Mah...
kulSMS ::
uploada imaš samo 1mbit to ni problem stestirat, 10mbit je pa že večji problem.
Poskusi recimo iz 5ih oz še več strani, ki imajo dober download pranašat kake iso datoteke pa seštej prenose oz. izmeri z DU metrom oz. kakšnim podobnim programom.
jerry2000 ::
Hvala za odogovre. Tudi moja računica je bila 2.5 kilometra od centrale, jaz sem preden sem bil priklopljen naračunal 2.3 km :-)
Čisto še vedno ne razumem (mislim da to tudi druge zanima). Kako to, da imam kvalitetno linijo in je precej nestabilna? Torej kako je lahko tako nizek S/N pri kvalitetni liniji?
Zdaj so mi še malo nastavili tehniki (rekli so da sem imel na 8/1), zakaj mi je potem kazalo 10/1 pa ne vem. Pravi če bo pa linija dol padala bo moral znižati download. Torej mi je še zmanjšal S/N verjetno (nisem tam kjer imam to linijo v tem trenutku, zato ne morem pogledati)...
Ali lahko sam vidim, kolikorat mi je linija dol padla vmes ko me ni bilo?
Pa še eno vprašanje: Če se poveže na 10/1 ali to pomeni da so me na toliko priključili ali to pomeni, da mi linija prepušča 10/1 in je potem problem zakaj ne dosegam te hitrosti, drugje?
Probal sem iz različnih virov od koder mi trenutni net dostop na T-2 8/1 potegne 900Kb/sek brez težav. Hec na T2 imam težave z uploadom mi gre samo nekih 60Kbajt/sek. Download se pa modem sinhronizira na 16... Mislil sem da je vedno upload problem, samo tukaj na Amisu pa zgleda da je upload maximum. Ni mi res tole čisto jasno, ampak programček tvoj je pa super kulSMS.
Kaj pa je tole: FEC Errors (Up/Down): 16 / 230
Nekam veliko errorjev za 40 minut...
Jerry and Tom
MiranRxx ::
Verjetno je to odvisno od linije. Za priblizno oceno, sam sem oddaljen cca 2200 m, pa mi gre trio paket z 1 M interneta. Se vse kar zadovoljivo deluje. Tv ima obcasno minimalne motnje.
klihk ::
Kmalu bom novi uporabnik AmisDSL in bi vprašal, ali je tisti varovalni sistem, ki ga pač imaš kot Amisov uporabnik (F-secure ali nekaj takega) dovolj za navadno brskanje po netu, dovnload ipd? Ali je potrebno dodatno si nabavit še kak antivirus?
- spremenil: klihk ()
MiranRxx ::
Naceloma bi naj bil dovolj. En del ti "sciti" ze amis, drug del, pa ta F secure.
Sam sem imel prej pando, sedaj sem si namestil fsecure, pa bi ti tesko rekel, kateri je "boljsi". Glede hitrosti pa sta oba bolj pocasna. Pri prvem pregledu me je f secure zelo razocaral, saj je "mlel" vec ur. Bom videl kako in kaj,. ker fsecure imam komaj dva dni.
jerry2000 ::
Zdaj so mi nekaj nastavljali in imam višjo hitrost, samo S/N na downloudu je pa 6.5. Ali ni to premalo? Pa FEC errorjev imam milijon v dveh urah!
Jerry and Tom
Matofast21 ::
Meni tud prije SN Margin za Down ob večerih do 6dB 4/1 paket 3km. Koliko maš kabla od modema pa do linije pa priporočam da imaš FTP kabel. 10/1 bi moglo komot it na tej razdalji.
- spremenil: Matofast21 ()
dejanslo ::
pozdravljeni
ta amisova ponudba 10/768 za 20€ je dokaj mikavna, pa me zanima, če je kaj, kar mi preprečuje, da preklopim za eno leto na to, potem pa prekličem pogodbo in naredim kar mi pač paše?
MiranRxx ::
Kolikor se meni zdi, si potem en cas vezan, pri varianti za 4 M ni vezave. Za podrobnosti poklici 080 20 10.
Mobidick ::
Paket je brez pogodbene časovne vezave.
Piše pri obeh paketih. Razen da ta 10/768 preide na 2/512 po enem letu.
The future is digital!
jerry2000 ::
FTP kabel? A ni FTP UTP kabel za mrežo, za telefon je pa telefonski kabel?
Jerry and Tom
kulSMS ::
To je res kar praviš.
Telefonski je dober za telefon, vendar FTP je pa še boljši.
Ted ::
jerry2 :
Ja, to je posledica nizkega SN Margina. Zna bit še huje, da ti bo zadevo prekinjalo... Boljše kak mega dl-ja manj pa bolj stabilna linija. Jaz bi jih poklical pa rekel, naj znižajo download za kak mega.
Mah...
jerry2000 ::
Ja saj download je zašibal, pol se je pa skoraj ustavil... Nekaj ni tole... Prej sem imel SN/14 in je bilo bolje kot tale 6.5.
Bom jim rekel naj mi nazaj znižajo. Ne morem verjeti da imam tako bedno parico da na 2.4 dejanske oddaljenosti dobim le 5Mbit :-( Upload pa polni 1Mbit.
Imam pa v omarici še 2x2 kabla ki nista zvezana. Ali to pomeni da gre do nas več paric?
Torej lahko potegnem UTP kabel in dam tel. bananico gor pa bo delalo? Samo barve žic so druge, ne?
Jerry and Tom
Ted ::
Še dobro da poznam folk na Amisu, ker drugače bi mi te 4 mega še cel mesec priklapljali.
Link Information
Uptime: 0 days, 0:04:49
Bandwidth (Up/Down) [kbps/kbps]: 865 / 4.880
Data Transferred (Sent/Received) [KB/MB]: 686,00 / 15,40
Line Attenuation (Up/Down) [dB]: 17,0 / 29,5
SN Margin (Up/Down) [dB]: 16,0 / 13,5
Error Seconds (Local/Remote): 2 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Works like a charm
. 10 mega bi pa blo že na meji verjetno.
Link Information
Works like a charm
Mah...
Tr0n ::
Jaz pa sem sel stran od Amisa po 2 letih. Na zacetku je delalo super, zadnjih par mesecev pa je odzivni cas do centrale obupen, download in uplpoad pa je tudi zelo nekonsistenten. Izvedli so neke meritve, ampak nic pametnega niso pogruntali.
Deluje, kot da imajo prevec uporabnikov in se ob vecji obremenitvi vse zabase.
AMIS, it was nice while it lasted. T-2, here I come!
- spremenilo: Tr0n ()
afneguncam ::
prosil bi ce lahko kdo iz amisADSL preveri ping do:
- www.google.com
- www.arnes.si
- do nemčije (80.86.82.228)
run...
cmd
ping -n 5 www.arnes.si
- www.google.com
- www.arnes.si
run...
cmd
kulSMS ::
>ping -n 5 www.google.com
Pinging www.l.google.com [209.85.135.99] with 32 bytes of data:
Reply from 209.85.135.99: bytes=32 time=40ms TTL=242
Reply from 209.85.135.99: bytes=32 time=45ms TTL=242
Reply from 209.85.135.99: bytes=32 time=39ms TTL=242
Reply from 209.85.135.99: bytes=32 time=37ms TTL=242
Ping statistics for 209.85.135.99:
Packets: Sent = 5, Received = 5, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 37ms, Maximum = 45ms, Average = 40ms
Pinging kanin.arnes.si [193.2.1.87] with 32 bytes of data:
Reply from 193.2.1.87: bytes=32 time=14ms TTL=248
Reply from 193.2.1.87: bytes=32 time=13ms TTL=248
Reply from 193.2.1.87: bytes=32 time=12ms TTL=248
Ping statistics for 193.2.1.87:
Minimum = 12ms, Maximum = 14ms, Average = 13ms
>ping -n 5 80.86.82.228
Pinging 80.86.82.228 with 32 bytes of data:
Reply from 80.86.82.228: bytes=32 time=25ms TTL=56
Reply from 80.86.82.228: bytes=32 time=24ms TTL=56
Reply from 80.86.82.228: bytes=32 time=26ms TTL=56
Ping statistics for 80.86.82.228:
Minimum = 24ms, Maximum = 26ms, Average = 24ms
TgT ::
AmisADSL Telekom omrežje
ping -c 5 www.google.com
PING www.l.google.com (209.85.135.104) 56(84) bytes of data.
64 bytes from mu-in-f104.google.com (209.85.135.104): icmp_seq=1 ttl=244 time=43.2 ms
64 bytes from mu-in-f104.google.com (209.85.135.104): icmp_seq=2 ttl=244 time=42.3 ms
64 bytes from mu-in-f104.google.com (209.85.135.104): icmp_seq=3 ttl=244 time=42.1 ms
64 bytes from mu-in-f104.google.com (209.85.135.104): icmp_seq=4 ttl=244 time=42.7 ms
64 bytes from mu-in-f104.google.com (209.85.135.104): icmp_seq=5 ttl=244 time=43.5 ms
--- www.l.google.com ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 3996ms
rtt min/avg/max/mdev = 42.146/42.782/43.503/0.545 ms
ping -c 5 www.arnes.si
PING kanin.arnes.si (193.2.1.87) 56(84) bytes of data.
64 bytes from kanin.arnes.si (193.2.1.87): icmp_seq=1 ttl=248 time=21.7 ms
64 bytes from kanin.arnes.si (193.2.1.87): icmp_seq=2 ttl=248 time=21.3 ms
64 bytes from kanin.arnes.si (193.2.1.87): icmp_seq=3 ttl=248 time=21.9 ms
64 bytes from kanin.arnes.si (193.2.1.87): icmp_seq=4 ttl=248 time=21.0 ms
64 bytes from kanin.arnes.si (193.2.1.87): icmp_seq=5 ttl=248 time=22.4 ms
--- kanin.arnes.si ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4027ms
rtt min/avg/max/mdev = 21.060/21.717/22.453/0.510 ms
ping -c 5 80.86.82.228
PING 80.86.82.228 (80.86.82.228) 56(84) bytes of data.
64 bytes from 80.86.82.228: icmp_seq=1 ttl=58 time=28.7 ms
64 bytes from 80.86.82.228: icmp_seq=2 ttl=58 time=28.6 ms
64 bytes from 80.86.82.228: icmp_seq=3 ttl=58 time=29.5 ms
64 bytes from 80.86.82.228: icmp_seq=4 ttl=58 time=30.2 ms
64 bytes from 80.86.82.228: icmp_seq=5 ttl=58 time=30.0 ms
--- 80.86.82.228 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4025ms
rtt min/avg/max/mdev = 28.668/29.458/30.229/0.675 ms
Hit'N'Run
afneguncam ::
hvala obema! zgleda da so tudi odzivni casi napram siolu nekoliko nizji. tako da je amis zmagal glede na cena/kakovost.
Ted ::
Itak da so nižji, v tujino pa sploh. Celo tako bom rekel, pokaži mi providerja kjer so višji kot pri Siolu
Mah...
- spremenilo: Ted ()
AapocalypseE ::
Reply from 193.2.1.87: bytes=32 time=12ms TTL=247
Reply from 193.2.1.87: bytes=32 time=11ms TTL=247
Minimum = 11ms, Maximum = 12ms, Average = 11ms
Reply from 209.85.135.99: bytes=32 time=33ms TTL=243
Reply from 209.85.135.99: bytes=32 time=35ms TTL=243
Reply from 209.85.135.99: bytes=32 time=34ms TTL=243
Minimum = 33ms, Maximum = 35ms, Average = 34ms
Reply from 80.86.82.228: bytes=32 time=20ms TTL=57
Reply from 80.86.82.228: bytes=32 time=19ms TTL=57
Minimum = 19ms, Maximum = 20ms, Average = 19ms
| » | počasnejši internet za polovicoOddelek: Omrežja in internet | 5969 (4728) | Veron |
| » | SIOL ali AMIS? (strani: 1 2 3 )Oddelek: Omrežja in internet | 33152 (26923) | Tydek |
| » | 4Mb + tel + tv po kabluOddelek: Omrežja in internet | 1827 (1727) | borut_p |
| » | Sinhronizacija modemaOddelek: Omrežja in internet | 2200 (2157) | Tilen |
| » | ADSL za "nesrečneže"Oddelek: Omrežja in internet | 6767 (3126) | KoMar- |
