Kaka je razlika med chipsetom 865 ali 875 za P4?????
Henixman ::
Kaka je razlika med chipsetom 865 ali 875 za P4????? :( :( :(
Je, 875P je hitrejši. Pa PAT tehnologija je uporabna.
Henixman ::
I PAT tehnologija je kaj????
Intel PAT (Intel Performance Acceleration Technology) is a trigger for extreme performance.
Zheegec ::
Janez Janša, 29.04.2014
zbogi ::
ubistvu ma 865 tud PAT, sam sam do 200mhz FSB, torej default, če naviješ, se izklop.
Tomay ::
Če ne potrebuješ ecc je 865 čisto dovolj. Mislim, da so bile ene 865 plate celo hitrejše od 875.
Voodoo 4Ever
zbogi ::
tomay, misliš narobe.
Tomay ::
Ko sem pred kakima dvema letoma nabavil ASUS P4P800 je bila po testih hitrejša od nekaterih 875. Če bi se malo pobrska po netu bi našel ta review.
In sem tudi ga:
Our key findings are as follows: the marketing strategists from Intel argue that the two chips differ from one another in that the 875P essentially performs better than the 865PE. The performance advantage is mainly said to result form the fast "PAT" memory access, which is officially not possible in the case of the 865.
In practice, however, a completely different picture emerges: the benchmark results of our test field prove that, depending on the manufacturer, boards based on the Intel 865PE are just as fast as boards with the Intel 875P. The key factors here are optimization of the BIOS software and adjustment of running times through the appropriate layout of the track conductors. The fast storage access (in the case of the 875P) is therefore not the sole factor determining the speed of a board.
Vir
Priznam pa, da so razlike minimalne.
Voodoo 4Ever
zbogi ::
Ja ne moreš primerjat ploščo na 865 čipsetu enega prozivajalca z ploščo na 875 od drugega.
Asusu so s to serijo plošč na intelovima cipsetoma ratale full dobre plošče in jih ni primerjat kr tak z ostalimi.
Če primerjaš P4C800 z 875 in P4P800 z 865, boš videl da je vedno P4C800 hitrejša.
Tomay ::
Zakaj pa ne?
Saj so plošče med sabo konkurenčne. Če primerjamo intela in amdja zakaj pa ne bi dveh različnih čipsetov?
Zraven tega pa je v tem testu msi-jeva 865 potolkla vse vključno z msi-jevo 875.
Voodoo 4Ever
zbogi ::
lohka primerjaš, samo ne če hočeš naredit primerjavo med dvema čipsetoma, to je isto kot če bi testiral pneumatike za avto, pa testiral michelinke na Hyundayu, savo pa na Mercedezu.
pri sock nastavitvah so razlike tok majhne, da tud ne bi mogel govoriti o nekih bistvenih predostih enega ali drugega, ti pa povem da 875 odleti, ko se spraviš navijat.
Tomay ::
To bo držalo, ker intel za 875 uporablja boljše čipe kot za 865, podobno kot med p4 in celeroni.
Sicer pa je razlika v ceni med P4P800 in P4C800 par jurjev. (comtron)
Voodoo 4Ever
zbogi ::
P4C plate so full overated, majo tako ceno da te sam glava boli, pa fora je ko jih sploh ne delajo več. Če ti povem da sem 2 leti nazaj dal za plato 53k, zdej je pa cena 41k, pa še dobit je ne moreš. Nabavna cena plate je okol 39k.
Tomay ::
Zdaj pa spat, da bo mir, ker očitno sva edina, ki sva še na forumu.
Voodoo 4Ever
a13misko ::
Če kupuješ ploščo kupi to Msi neo2-pfssicer nima PAT ima pa
MAT=Memory Acceleration Technology!
Najboljša plata za S478 je P4C800-E Deluxe.
a13misko ::
Saj vem mtosev ampak najboljše je tudi drago če pa hoče za mal denarja velik muzke si naj kupi tisto MSI-jevo! ;((
PrimozR ::
Tut IC7 MAX3 ni švoh BTW.
a13misko ::
Ja pa tud cena ni slaba!
Ja tudi IC7 MAX3 je dober (za dobro navijanje).
Kero S478 matično
201772 (1565) mtosev
Počasi bo potrebno nadgraditi sistem... Kaj svetujete?
261972 (1490) Zheegec
DOBRA maticna pa Socket 478 (Pentium 4)
Oddelek: Navijanje
141958 (1776) DjTonic
Springdale/Canterwood -- kaj je že boljše? (strani: 1 2 )
567823 (6597) VASkO
Intelov chipset 875PE vs 865PE (razlika??)
101471 (1299) morphling1
