Forum » Strojna oprema » Memory test
Memory test
tonex23 ::
Odločil sem se da testiram ram v si soft sandri 2005 in se res nič ne spoznam na te rezultate:) Ali so vredu? timingi so vredu? nasplošn vse štima? ok, hvala in lep pozdrav:)
pc3200 2048mb ddr-sdram 400 dual channel
SiSoftware Sandra
Benchmark Results
RAM Bandwidth Int Buff'd iSSE2 : 4876 MB/s
RAM Bandwidth Float Buff'd iSSE2 : 4876 MB/s
Results Interpretation : Higher index values are better.
Int Buff'd iSSE2 (Integer STREAM) Results Breakdown
Assignment : 4748MB/s
Scaling : 4723MB/s
Addition : 5022MB/s
Triad : 5013MB/s
Data Item Size : 16 byte(s)
Buffering Used : Yes
Offset Displacement Used : Yes
Bandwidth Efficiency : 76% (estimated)
Float Buff'd iSSE2 (Float STREAM) Results Breakdown
Assignment : 4744MB/s
Scaling : 4719MB/s
Addition : 5030MB/s
Triad : 5014MB/s
Performance Test Status
Run ID : AMD64-EF72E21D0 on 1. september 2005 at 4:14:44
Memory Used by Test : 512MB
NUMA Support : No
SMP Test : No
Total Test Threads : 1
Multi-Core Test : No
SMT Test : No
Dynamic MP/MT Load Balance : No
Processor Affinity : P0C0T0
Page Size : 4kB
Use Large Memory Pages : No
Chipset 1
Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration
Front Side Bus Speed : 2x 1005MHz (2010MHz data rate)
In/Out Width : 16-bit / 16-bit
Maximum Bus Bandwidth : 8040MB/s (estimated)
Logical/Chipset 1 Memory Banks
Bank 0 : 1GB DDR-SDRAM 3.0-3-3-8 2CMD
Bank 1 : 1GB DDR-SDRAM 3.0-3-3-8 2CMD
Channels : 1
Bank Interleave : 2-way
Speed : 2x 201MHz (402MHz data rate)
Width : 128-bit
Maximum Memory Bus Bandwidth : 6432MB/s (estimated)
Features
(W)MMX Technology : Yes
SSE Technology : Yes
SSE2 Technology : Yes
SSE3 Technology : No
EMMX - Extended MMX Technology : Yes
HTT - Hyper-Threading Technology : No
Performance Tips
Notice 5008 : To change benchmarks, click Options.
Notice 5004 : Synthetic benchmark. May not tally with 'real-life' performance.
Notice 5006 : Only compare the results with ones obtained using the same version!
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
SiSoftware Sandra
Benchmark Results
Scaling : 4723MB/s
Addition : 5022MB/s
Triad : 5013MB/s
Scaling : 4719MB/s
Addition : 5030MB/s
Triad : 5014MB/s
NUMA Support : No
SMP Test : No
SMT Test : No
Page Size : 4kB
Chipset 1
Channels : 1
Width : 128-bit
Features
Performance Tips
intel Core 2 Extreme QX6700, asus commando 965P, 400 gb disk,250gb
external,4gb ddr2 st 800mhz, evga 8800 Ultra, hp lp3065 + 24"dell
tonex23 ::
ok na enem forumu sem dobil odgovor na vse to, da...
you have two Modules yet your not running dual channel?? - why is that??
and 2T is holding your bandwidth back by around 1000 points.
Ima prav kar je rekel? kako se da to popravt?
tonex23 ::
Kaj sploh je 2T ... Mislm kako je to sploh najdu notr? res bi rabu kle pomoč.... hvala
Moonman ::
Dol si potegni A64tweaker in poskusi narediti tako kot sem narisal na sliki.
Če sistem ne bo zmrznil pojdi v bios in tam nastavi to vrednost na 1T.
tonex23 ::
tej hvala! A to naredim v tem programčku in v biosu al bo zadostovalo v tem programčku sam?
- spremenil: tonex23 ()
tonex23 ::
sem bil v biosu, pa sploh nism najdu funkcijo da bi nastavu na 1t ... kaj nej naredim zdaj?
tonex23 ::
sej moram prvo v tem programčku to narest sam se hočem prepričat da bom lahko pol še v biosu...sam nism zdej najdu te funkcije v biosu. a povem kero verzijo mam in podobno?
tonex23 ::
ok še moje dodatne informacije o biosu... res ne vem kje bi to v biosu naštimu pa sm že celga preisku ne vem...
General Information
Manufacturer : Phoenix Technologies, LTD
Version : ASUS A8N-E ACPI BIOS Revision 1006
Date of Manufacture : 30. junij 2005
Plug & Play Version : 1.00
SMBIOS/DMI Version : 2.30
(EE)PROM Size : 512kB
General Information
tonex23 ::
ok v biosu sem dal na 1T. v benchmarku v sandri dobim 1000 točk več. problem je rešen. hvala
| » | Kateri CPU mate in utemeljite zakaj? (strani: 1 2 3 4 5 )Oddelek: Strojna oprema | 29761 (21541) | 54j0 |
| » | SiSoft Sandra 2004 Memory Bandwith Benchmark rezultati (strani: 1 2 3 )Oddelek: Navijanje | 13041 (8950) | GaS |
| » | Opis DFI LANParty nF3 250Gb in pa test 754 plat... (strani: 1 2 3 4 5 6 7 8 )Oddelek: Strojna oprema | 24642 (15183) | mzidy |
| » | Ram Geil in timingiOddelek: Strojna oprema | 1715 (1470) | cojss |
| » | Wow kaj bi skoraj prodalOddelek: Navijanje | 4144 (3045) | MEDENA |
