Forum » Navijanje » Wow kaj bi skoraj prodal
MEDENA ::
Imam te BUFFALO CH-5 - Melco javi CPU-Z...rame
DUAL oba enaka itd.....no sem jih prodajal kar teden-dva...najprej 21k.....20.5k....20k.....19.5.....danes 19k....
Pa sem si rekel a kurc dej jih grem malo probat itd......
Najprej 1 modul.....200 2-2-2-11 2.6vdimm....malca
potem 210 2-2-2-11 2.9vdimm w00t ....okej sem si rekel kurc ga gleda ...dam še drugi modul notr...tako da laufa DUAL....
230mhz dela enkratno 2.5-2-2-11 pri 3.0v / kdor ima vdimm ali DFI
SiSoftware Sandra
Benchmark Results
RAM Bandwidth Int Buff'd aEMMX/aSSE : 3454MB/s
RAM Bandwidth Float Buff'd aEMMX/aSSE : 3113MB/s
Int Buff'd aEMMX/aSSE (Integer STREAM) Results Breakdown
Assignment : 3465MB/s
Scaling : 3464MB/s
Addition : 3446MB/s
Triad : 3444MB/s
Data Item Size : 8-bytes
Buffering Used : Yes
Offset Displacement Used : Yes
Bandwidth Efficiency : 93% (estimated)
Float Buff'd aEMMX/aSSE (Float STREAM) Results Breakdown
Assignment : 3466MB/s
Scaling : 3159MB/s
Addition : 2929MB/s
Triad : 2898MB/s
Bandwidth Efficiency : 84% (estimated)
grem dalje...
235 2.5-2-2-11 3.1vdimm
SiSoftware Sandra
Benchmark Results
RAM Bandwidth Int Buff'd aEMMX/aSSE : 3468MB/s
RAM Bandwidth Float Buff'd aEMMX/aSSE : 3117MB/s
Assignment : 3400MB/s
Scaling : 3578MB/s
Addition : 3447MB/s
Triad : 3450MB/s
Bandwidth Efficiency : 92% (estimated)
Assignment : 3404MB/s
Scaling : 3202MB/s
Addition : 2959MB/s
Triad : 2906MB/s
Bandwidth Efficiency : 83% (estimated)
zdej bom probal 240*11 2.5-2-2-11 .....upajmo,da bo 3.1vdimm dovolj...
aja to vse sem delal pr CPC ON....rami so enostranski
hehe vidite in vi jih niste hoteli.........priložnost zamujena ne vrne se nobena
SiSoftware Sandra
Benchmark Results
Scaling : 3464MB/s
Addition : 3446MB/s
Triad : 3444MB/s
Scaling : 3159MB/s
Addition : 2929MB/s
Triad : 2898MB/s
grem dalje...
SiSoftware Sandra
Benchmark Results
Scaling : 3578MB/s
Addition : 3447MB/s
Triad : 3450MB/s
Scaling : 3202MB/s
Addition : 2959MB/s
Triad : 2906MB/s
- spremenil: MEDENA ()
Boki_ ::
Ha, MEDENA meni si obljubil da mi shraniš eno BH5, pa si mi jo prodal pred nosom. Zdej mam $$$, tako da bi lah kupu. Jaja, Buffalo kliče, glej da če se kej zmeniva, da mi daš tisto tadobro...
I'm back
_Dejan_ ::
Medena zakaj pa ne probaš cas2? Probej do kolk prideš na 7 3 3 cas2 in 2,9V. In a je to 100% stabilno kar si dosegu al samo za benchmark? Kolk caša si testiru Prime95?
ASUS P5E3, INTEL Q6600(3000Mhz 333x9), ATI HD 2600XT,
A-Data 4x2GB PC3-10700H(9-9-9-24-2T),LSI 9260-8i,
4x OCZ Vertex Turbo 30GB(RAID10), 3x1TB (RAID1+Spare)
TribesMan ::
Oglasevanje je prepovedano! Za to imamo male oglase. Ostalo se zmenite prek ZS.
TribesMan
TribesMan
MEDENA ::
ja ja tirbes
Impresivno tile CH-5 delajo 220 in 225 FSB 2-2-2-11 3.1/3.2 vdimm
zdej furam 230 2-2-2-11 3.2vdimm ...
hehe jao kaj ste spustili z rok ....skoraj bi jaz...
MEDENA ::
omg
240 CPC ON 2-2-2-11 3.3VDIMM
SiSoftware Sandra
Benchmark Results
RAM Bandwidth Int Buff'd aEMMX/aSSE : 3684MB/s
RAM Bandwidth Float Buff'd aEMMX/aSSE : 3389MB/s
Assignment : 3693MB/s
Scaling : 3707MB/s
Addition : 3666MB/s
Triad : 3672MB/s
Bandwidth Efficiency : 96% (estimated)
Scaling : 3421MB/s
Addition : 3235MB/s
Triad : 3209MB/s
Bandwidth Efficiency : 88% (estimated)
SiSoftware Sandra
Benchmark Results
Scaling : 3707MB/s
Addition : 3666MB/s
Triad : 3672MB/s
Scaling : 3421MB/s
Addition : 3235MB/s
Triad : 3209MB/s
Spajky ::
jebeš Sandra teoretični max bandwith, nič ne pomeni v praksi!
poglej si na moji strani pod komp/benči link pred NEW za frišno primerjavo z ostalimi...
MrGTO ::
Zivjo!
Da ne bom odpiral nove teme bom kar tukaj vprasal.
Imam plosco DFI NF2 infinity in rame ki naj bi bili BH-5 ali BH-6.
Rami so enostranski in na njih sem prilepil TT bakrene hladilnike. Sedaj sem se pa lotil navijanja in so pri voltazi 3.1 V kar vroci, tako da jih skoraj ne morem vec tikati. A se pri povisani temperaturi ramov javljajo napake pri Prime 95 ali se le zakadi in ne dela vec?
Pa se neki...opazil sem da na BH-5,6 cipih na tisti nalepki pise A.00 al neki tacga...a to pomeni da so 100% BH cipi gor al ne? Ker doma imam 2x256 rame in 1x512 pa na obeh pise isto, torej A.00 ce se prav spomnem.
Prosim za nasvete...
Lp, Blaž
Lp, Blaž
MrGTO ::
Torej naj bi moji bili CH-5?
se neki...2x256 so kingston value ram pc 2700, 512 pa so KHX 3000. A to velja tudi za ostale ali samo za verzije pc 3200?
Kako je pa s hlajenjem? A je mozno da jih skurim al se prej pojavijo napake?
Lp, Blaž
Lp, Blaž
MEDENA ::
Lp, Blaž
KHX3000 so bili v večina primerih BH-5....
fajn je kak vent dat na rame ...skurit jih ne moreš samo prej se javijo napake....
Lp, Blaž
billy ::
ja probaj rame s prstom, tile čipi bi naj komot zdržali 70-80 stopinj. tako da boš prec ugotovu kdaj je preveč.
Malecky ::
Js sm dal pa disečo smrekco v rit pa moj prdec ne smrdi vec!
Ramov ni treba hladit..se HSji so samo za izgled ubistvu pa dvigujejo povprecno temperaturo cipa
VASkO ::
ko dobim PQI Turbo pc3200 1G kit ali pa GSkill pc4400, pol se bomo sli, kdo "ma vecjega" LOL
MEDENA ::
Dons sem dobil KHX3200/256 enostranskega....njam
230 CPC ON 2-2-2-11 3.1Vdimm z lahkoto...
DjTonic ::
Lepo, sicer pa je 3.1V že kar lepa napetost. Moji PC2700 bi šli pomoje še višje.
MEDENA ::
evo še boljši score
235 cpc on 2-2-2-11 3.1vdimm 4h stable pri samo 1.65vcore...235*9
zdej furam
240 cpc on 2-2-2-11 3.2vdimm 1.725vcore... yay 3 hours stable + fifa 2005/nba 2005
ni mi jasno zakaj potreben tako skok v napajanju proca...
ne me fukat bootal so normalno na 245
SiSoftware Sandra
Benchmark Results
RAM Bandwidth Int Buff'd aEMMX/aSSE : 3695MB/s
RAM Bandwidth Float Buff'd aEMMX/aSSE : 3329MB/s
Assignment : 3708MB/s
Scaling : 3702MB/s
Addition : 3692MB/s
Triad : 3678MB/s
Bandwidth Efficiency : 94% (estimated)
Assignment : 3698MB/s
Scaling : 3412MB/s
Addition : 3148MB/s
Triad : 3058MB/s
Bandwidth Efficiency : 85% (estimated)
zdej furam
SiSoftware Sandra
Benchmark Results
Scaling : 3702MB/s
Addition : 3692MB/s
Triad : 3678MB/s
Scaling : 3412MB/s
Addition : 3148MB/s
Triad : 3058MB/s
| » | SiSoft Sandra 2004 Memory Bandwith Benchmark rezultati (strani: 1 2 3 )Oddelek: Navijanje | 13076 (8985) | GaS |
| » | Memory testOddelek: Strojna oprema | 2217 (2058) | tonex23 |
| » | Ram Geil in timingiOddelek: Strojna oprema | 1722 (1477) | cojss |
| » | RAMOddelek: Strojna oprema | 2185 (1785) | celada |
| » | Sandra 2002 rezultati in vaša mnenja ter nasvetiOddelek: Pomoč in nasveti | 1571 (1440) | SisQ |
