Forum » Programiranje » visual basic .net resetiranje
boss-tech ::
setup zahteva resetiranje ker kao nek program hoče resetirat com- ko ga resetiram pa spet isto- in ne morm pognat inštalacije. v čem je problem?
Tutankhamun ::
A ti mislš na VB.NET Express.
Kater program zahteva reset, a maš možnost preklicat reset? Kdaj se to zgodi, nek na začetku, al prot koncu inštalacije?
AMD Phenom QUAD 9950 Black Edition, 8GB
Microsoft ::
Ze od prej mas nekaj instaliranega, kar zahteva reboot, pa ga nisi naredil.
by Miha
by Miha
Nerdor ::
Poglej na MSDN, ozr. vpiši v search to napako in to bo posredoval odgovor na težavo. Jest sem si hotel inštalirati VS.Net 2003 (v službi), pa se mi je podobna težava kot je tvoja. Jest sem hotel windowse na novo formatirati, medtem je pa šef pogooglal in našel rešitev na msdn-ju.
... for lifetime!
mainman ::
Na win98 je bila to datoteka wininit.ini v windows direktoriju, ki jo je bilo potrebno zbrisati, na nt platformi pa ne vem.
mainman ::
To bi ti moralo pomagati:
Another file, C:\Windows\WININIT.INI, also is loaded at each Windows normal mode startup. WININIT.INI is used to complete Windows and program installation steps that cannot be completed while Windows is running and, therefore, are deferred until after a reboot. During the boot process, Windows checks to see if there is a WININIT.INI file and, if it finds one, executes its instructions. (After its successful use, it is supposed to be automatically renamed to WININIT.BAK.) You can search for a copy of this file using the Find or Search feature on your Start Menu, and then examine and edit its contents with Notepad. You can temporarily suspend any line of this file by placing a semi-colon in front of the line.
In Windows 2000 and XP, the WININIT.INI file, if existing, will be executed. However it is usually replaced by the “PendingFileRenameOperations” sub-key in the Registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager.
mainman ::
Zbriši ga. Ko je meni nagajala inštalacija Internet Exlorerja sem vedno pobrisal to datoteko. Moram pa te opozoriti, da je bi sistem vedno Win 98.
| » | Težave z windows 8Oddelek: Pomoč in nasveti | 4020 (3426) | mrsofa |
| » | HP Pavilion dv7 reboot problemOddelek: Pomoč in nasveti | 2666 (2599) | Yacked2 |
| » | C-disk se mi sam polni ???Oddelek: Pomoč in nasveti | 12052 (11147) | cookyx |
| » | Win XP SP2 in BlutoothOddelek: Pomoč in nasveti | 2449 (2294) | jast |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2610 (2206) | Swiwer |
