[asp.net] Dvojni sql stavek
SloDave ::
Kako lahko izvedem dvojno sql poizvedbo (nekaj takega):
Koda:
OleDbConnection objConn = new OleDbConnection(ConfigurationSettings.AppSettings["DSN"]);
OleDbCommand objCmd;
OleDbDataReader objRdr;
OleDbCommand objCmd1;
OleDbDataReader objRdr1;
OleDbDataAdapter objDA;
DataSet objDS = new DataSet();
DataRow objDR;
DataTable testtable;
void Page_Load(){
DataTable objDT = new DataTable("Plan");
DataColumn objDC;
DataRow objDR;
objDC = new DataColumn(("Šifra"), Type.GetType("System.Int32"));
objDT.Columns.Add(objDC);
objDC = new DataColumn(("Opis"), Type.GetType("System.String"));
objDC = new DataColumn(("Kolicina"), Type.GetType("System.Int32"));
objDC.DefaultValue = 0;
objDC = new DataColumn("Cena", Type.GetType("System.Int32"));
objDC = new DataColumn("Znesek", Type.GetType("System.Int32"));
objDC = new DataColumn("Grupa", Type.GetType("System.Int32"));
objConn.Open();
//glej tukaj
objCmd = new OleDbCommand("SELECT * FROM os WHERE group = 2", objConn);
objRdr = objCmd.ExecuteReader();
while (objRdr.Read()){
objCmd1 = new OleDbCommand("SELECT * FROM plan WHERE SM = 1234 and osID = '"+objRdr["osID"]"'", objConn);
objRdr1 = objCmd1.ExecuteReader();
objDR = objDT.NewRow();
objDR["Šifra"] = objRdr["osID"];
objDR["Opis"] = objRdr["NazivOS"];
objDR["Kolicina"] = objRdr1["kolicina"];
objDR["Cena"] = objRdr["cena"];
objDR["Znesek"] = objRdr1["znesek"];
objDT.Rows.Add(objDR);
objRdr1.Close();
objRdr.Close();
objConn.Close();
objDS.Tables.Add(objDT);
dg.DataSource = objDS;
dg.DataMember = "Plan";
dg.DataBind();
Problem pri tej kodi je ker nista dovoljena dva ExecuteReader-ja, ima kdo kakšno idejo kako drugače rešiti težavo?
Če obstaja kakšna alternativa kako rešiti problem, bi bil zlo vesel?
MaCoFaCo ::
INNER JOIN obeh tabel?
Nekaj v stilu (pišem na pamet):
SELECT * FROM plan INNER JOIN os ON plan.osID = os.osID WHERE os.group = 2 AND plan.SM = 1234
SloDave ::
Inner Join enostavno ne gre, ker želim dobiti iz tabele os vse rezultate, iz tabele plan pa samo tiste ki imajo vnos z določenim osidjem ter SMjem. (pa tut LEFT JOIN ne prikaže prov).
Stvar sm rešil tako da sm najprej s prvim sqljem pobral rezultate jih spravu v array ter jih potem uporabu pri drugem sqlju.
destiny ::
Zakaj pa ne uporabiš datatabel v navezi s dataadapterjem?.
Datareader je učinkovit, če iščeš 1. vrstico iz tabele v bazi. Za več vrstic je precej boljša Dataadapterjeva fill metoda...
destiny ::
Aja, drugač pa lohk vse dobiš naenkrat ven tud z LEFT OUTER JOIN...
[Visual C#] kako narediti vrstice?
Oddelek: Programiranje
92054 (1536) dbeong
[Visual C#] TableAdapter
61556 (1432) detroit
razložitev nekaterij elementov v visual studio 05
72596 (2401) darkolord
[ASP.NET]
61703 (1557) OmegaM
[C#] unboxing
61301 (1191) noraguta
