Osveževanje zaslona - beatrix linux
dux ::
Živjo !
Instaliral sem si beatrix linux, ki na moji stari mašii deluje super hitro.
Problem je le v osveževanju zaslona, ki je prenizko, saj zaslon utripa in tako uporaba ni prijetna saj trpijo moje oči.
Poskusil sem spremeniti /etc/X11/XF86Config-4, in sicer sem tam dodal
Modeline "1024x768" 7.50 1024 1056 1080 1112 75 76 78 79
vendar pa je osveževanje še vedno nizko ne glede na spremembe.
Sicer sedaj v GUI dobim možnost izbire 85 Hz, vendar pa zaslon ne osvežuje pri ti frekfrenci - kaj naj storim ?
hvala
Upanje je v nasih odlocitvah
dux ::
Če bo komu mogoče tole kaj pomagalo...
XF86Config -4
Section "ServerLayout"
Identifier "XFree86 Configured"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
# PS/2 Mouse using /dev/input/mice in Kernel 2.6
# Serial Mouse not detected
InputDevice "USB Mouse" "CorePointer"
EndSection
Section "ServerFlags"
Option "AllowMouseOpenFail" "true"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
ModulePath "/usr/X11R6/lib/modules"
FontPath "/usr/X11R6/lib/X11/fonts/misc:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/Speedo"
FontPath "/usr/X11R6/lib/X11/fonts/PEX"
# Additional fonts: Locale, Gimp, TTF...
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
# FontPath "/usr/X11R6/lib/X11/fonts/latin2/75dpi"
# FontPath "/usr/X11R6/lib/X11/fonts/latin2/100dpi"
# True type and type1 fonts are also handled via xftlib, see /etc/X11/XftConfig!
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/ttf/western"
FontPath "/usr/share/fonts/ttf/decoratives"
FontPath "/usr/share/fonts/truetype"
FontPath "/usr/share/fonts/truetype/openoffice"
FontPath "/usr/share/fonts/truetype/ttf-bitstream-vera"
FontPath "/usr/share/fonts/latex-ttf-fonts"
FontPath "/usr/X11R6/lib/X11/fonts/defoma/CID"
FontPath "/usr/X11R6/lib/X11/fonts/defoma/TrueType"
EndSection
Section "Module"
Load "ddc" # ddc probing of monitor
Load "GLcore"
Load "dbe"
Load "dri"
Load "extmod"
Load "glx"
Load "bitmap" # bitmap-fonts
Load "speedo"
Load "type1"
Load "freetype"
Load "record"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "keyboard"
Option "CoreKeyboard"
Option "XkbRules" "xfree86"
Option "XkbModel" "pc105"
Option "XkbLayout" "us"
EndSection
Identifier "Serial Mouse"
Driver "mouse"
Option "Protocol" "Microsoft"
Option "Device" "/dev/ttyS0"
Option "Emulate3Buttons" "true"
Option "Emulate3Timeout" "70"
Option "SendCoreEvents" "true"
EndSection
Identifier "PS/2 Mouse"
Driver "mouse"
Option "Protocol" "auto"
Option "ZAxisMapping" "4 5"
Option "Device" "/dev/psaux"
EndSection
Identifier "USB Mouse"
Driver "mouse"
Option "Device" "/dev/input/mice"
Option "Protocol" "IMPS/2"
Option "Buttons" "5"
EndSection
# Auto-generated by KNOPPIX mkxf86config
Section "Monitor"
Identifier "Monitor0"
Option "DPMS" "true"
VendorName "CPL"
ModelName "CPL7701"
# HorizSync 28.0 - 78.0 # Warning: This may fry very old Monitors
# HorizSync 30.0 - 107.0 # Warning: This may fry old Monitors
# VertRefresh 48.0 - 170.0 # Very conservative. May flicker.
# VertRefresh 50.0 - 62.0 # Extreme conservative. Will flicker. TFT default.
# These are the DDC-probed settings reported by your monitor.
# 1280x1024, 75.0Hz; hfreq=79.98, vfreq=75.03
# ModeLine "1280x1024" 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync
# 1024x768, 85.0Hz; hfreq=68.68, vfreq=85.00
# ModeLine "1024x768" 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync
# 1024x768, 75.0Hz; hfreq=60.02, vfreq=75.03
# ModeLine "1024x768" 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
# 1024x768, 70.0Hz; hfreq=56.48, vfreq=70.07
# ModeLine "1024x768" 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync
# 1024x768, 60.0Hz; hfreq=48.36, vfreq=60.00
# ModeLine "1024x768" 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync
# 800x600, 85.0Hz; hfreq=53.67, vfreq=85.06
ModeLine "800x600" 56.25 800 832 896 1048 600 601 604 631 +hsync +vsync
# 800x600, 75.0Hz; hfreq=46.88, vfreq=75.00
ModeLine "800x600" 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync
# 800x600, 60.0Hz; hfreq=37.88, vfreq=60.32
ModeLine "800x600" 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync
# 800x600, 56.0Hz; hfreq=35.16, vfreq=56.25
ModeLine "800x600" 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync
# 640x480, 75.0Hz; hfreq=37.50, vfreq=75.00
ModeLine "640x480" 31.50 640 656 720 840 480 481 484 500 -hsync -vsync
# 640x480, 72.0Hz; hfreq=37.86, vfreq=72.81
ModeLine "640x480" 31.50 640 656 696 816 480 481 484 504 -hsync -vsync
# 640x480, 60.0Hz; hfreq=31.47, vfreq=59.94
ModeLine "640x480" 25.17 640 648 744 784 480 482 484 509 -hsync -vsync
# Extended modelines with GTF timings
# 640x480 @ 100.00 Hz (GTF) hsync: 50.90 kHz; pclk: 43.16 MHz
ModeLine "640x480" 43.16 640 680 744 848 480 481 484 509 -HSync +Vsync
# 768x576 @ 60.00 Hz (GTF) hsync: 35.82 kHz; pclk: 34.96 MHz
ModeLine "768x576" 34.96 768 792 872 976 576 577 580 597 -HSync +Vsync
# 768x576 @ 72.00 Hz (GTF) hsync: 43.27 kHz; pclk: 42.93 MHz
ModeLine "768x576" 42.93 768 800 880 992 576 577 580 601 -HSync +Vsync
# 768x576 @ 75.00 Hz (GTF) hsync: 45.15 kHz; pclk: 45.51 MHz
ModeLine "768x576" 45.51 768 808 888 1008 576 577 580 602 -HSync +Vsync
# 768x576 @ 85.00 Hz (GTF) hsync: 51.42 kHz; pclk: 51.84 MHz
ModeLine "768x576" 51.84 768 808 888 1008 576 577 580 605 -HSync +Vsync
# 768x576 @ 100.00 Hz (GTF) hsync: 61.10 kHz; pclk: 62.57 MHz
ModeLine "768x576" 62.57 768 816 896 1024 576 577 580 611 -HSync +Vsync
# 800x600 @ 100.00 Hz (GTF) hsync: 63.60 kHz; pclk: 68.18 MHz
ModeLine "800x600" 68.18 800 848 936 1072 600 601 604 636 -HSync +Vsync
# 1024x768 @ 100.00 Hz (GTF) hsync: 81.40 kHz; pclk: 113.31 MHz
ModeLine "1024x768" 113.31 1024 1096 1208 1392 768 769 772 814 -HSync +Vsync
# 1152x864 @ 60.00 Hz (GTF) hsync: 53.70 kHz; pclk: 81.62 MHz
ModeLine "1152x864" 81.62 1152 1216 1336 1520 864 865 868 895 -HSync +Vsync
# 1152x864 @ 85.00 Hz (GTF) hsync: 77.10 kHz; pclk: 119.65 MHz
ModeLine "1152x864" 119.65 1152 1224 1352 1552 864 865 868 907 -HSync +Vsync
# 1152x864 @ 100.00 Hz (GTF) hsync: 91.50 kHz; pclk: 143.47 MHz
ModeLine "1152x864" 143.47 1152 1232 1360 1568 864 865 868 915 -HSync +Vsync
# 1280x960 @ 72.00 Hz (GTF) hsync: 72.07 kHz; pclk: 124.54 MHz
ModeLine "1280x960" 124.54 1280 1368 1504 1728 960 961 964 1001 -HSync +Vsync
# 1280x960 @ 75.00 Hz (GTF) hsync: 75.15 kHz; pclk: 129.86 MHz
ModeLine "1280x960" 129.86 1280 1368 1504 1728 960 961 964 1002 -HSync +Vsync
# 1280x960 @ 100.00 Hz (GTF) hsync: 101.70 kHz; pclk: 178.99 MHz
ModeLine "1280x960" 178.99 1280 1376 1520 1760 960 961 964 1017 -HSync +Vsync
# 1280x1024 @ 100.00 Hz (GTF) hsync: 108.50 kHz; pclk: 190.96 MHz
ModeLine "1280x1024" 190.96 1280 1376 1520 1760 1024 1025 1028 1085 -HSync +Vsync
# 1400x1050 @ 60.00 Hz (GTF) hsync: 65.22 kHz; pclk: 122.61 MHz
ModeLine "1400x1050" 122.61 1400 1488 1640 1880 1050 1051 1054 1087 -HSync +Vsync
# 1400x1050 @ 72.00 Hz (GTF) hsync: 78.77 kHz; pclk: 149.34 MHz
ModeLine "1400x1050" 149.34 1400 1496 1648 1896 1050 1051 1054 1094 -HSync +Vsync
# 1400x1050 @ 75.00 Hz (GTF) hsync: 82.20 kHz; pclk: 155.85 MHz
ModeLine "1400x1050" 155.85 1400 1496 1648 1896 1050 1051 1054 1096 -HSync +Vsync
# 1400x1050 @ 85.00 Hz (GTF) hsync: 93.76 kHz; pclk: 179.26 MHz
ModeLine "1400x1050" 179.26 1400 1504 1656 1912 1050 1051 1054 1103 -HSync +Vsync
# 1400x1050 @ 100.00 Hz (GTF) hsync: 111.20 kHz; pclk: 214.39 MHz
ModeLine "1400x1050" 214.39 1400 1512 1664 1928 1050 1051 1054 1112 -HSync +Vsync
# 1600x1200 @ 100.00 Hz (GTF) hsync: 127.10 kHz; pclk: 280.64 MHz
ModeLine "1600x1200" 280.64 1600 1728 1904 2208 1200 1201 1204 1271 -HSync +Vsync
EndSection
Section "Device"
### Available Driver options are:-
# sw_cursor is needed for some ati and radeon cards
#Option "sw_cursor"
#Option "hw_cursor"
#Option "NoAccel"
#Option "ShowCache"
#Option "ShadowFB"
#Option "UseFBDev"
#Option "Rotate"
Identifier "Card0"
# The following line is auto-generated by KNOPPIX mkxf86config
Driver "fbdev"
VendorName "All"
BoardName "All"
# BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
# DefaultColorDepth 16
SubSection "Display"
Depth 1
Modes "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
Depth 32
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
CCfly ::
Compal; Compal M770; CPL7701; 30-70; 50-120;
Poskusi:
HorizSync 30.0 - 70.0
VertRefresh 50.0 - 120.0
"My goodness, we forgot generics!" -- Danny Kalev
ATI linux gonilnliki in resolucija
Oddelek: Operacijski sistemi
122619 (2506) roli
radeon 9200 suse10 brightness problem
252385 (2201) roli
Ati radeon, Xorg in Xv
101867 (1739) MasterMind
Linux / ATI Radeon / problem z driverji
132224 (2041) ahac
Suse 8.2 težave z grafično...
92255 (2143) norvalk
