Dolžina kabla pri WEB kameri
Arrivo ::
Koliko je lahko dolg kabel za web kamero brez dodatnega napajanja, ki bi jo priklopil na USB ?
Hvala za pomoč .
Ja ja to drži !!!
st0jko ::
16m :P
Gwanaroth ::
Q: What is the max. length of a USB 2.0 cable?
A: 5m. However, if you cascade 5 hubs with 5m USB cables, this will allow you to connect a device 30m away.
Q: I saw one cable supplier making USB A-B with the length of 10 and 20 meters per piece. So does it means these 2 cables or any cables with the length over than 5meters won't work or get full use of it? Pls advice. Thanks in advance.
A: It won't work. The rules are the rules - 5M max.
Q: Does the USB2.0 transfer rate become slower for a longer cable?
Let say a USB2.0 device reach 480Mbps in 1 meter cable, can it reach 480Mbps too in a 5 meter cable?
A: No - it's the same anywhere within the acceptable range envelope.
Skopirano iz http://www.everythingusb.com/
HDMI kabel (strani: 1 2 )
6314632 (9952) showsover
Thunderbolt vs USB Type-C
112205 (1690) krepki
USB 1.1 ali 2.0 ?
71397 (1173) playboy
Zakaj ISDN, če hočem ADSL ???
Oddelek: Omrežja in internet
92185 (2033) Bx
Zvok z vecih cd-romov?
Oddelek: Zvok in slika
142562 (2333) Justy
