Bsplayer in divx4 codec
boko34 ::
Ali mi zna kdo povedat zakaj film kodiran z zadnjim codecom divx4 je film v Bsplayerju ZELEN????!!!!!
Drugi filmi kodirani z codecom 3 delajo normalno.Tudi film z divx4 codecom dela v Media Playerju ali v The Playa normalno,samo z Bsplayerjem ne dela pravilno.
Ali kdo pozna resitev.Ali je to Bsplayer bug,codec4 bug???
DivX ::
loh da zarad kakih nastavitev al pa je bil res kak bug!!
DivX filmi na mail hlot12@yahoo.com
boko34 ::
Mislim,da sem ugotovil napako.Napaka je namrec v divx codecu,ki pa naj bi bil resen z novim codecom 4.01,ki si ga lahko poberete na teji strani.
Njihov komentar:
DivX 4.01 has been released and it features improved DivX3 decoding (for instance the getting green problem should be solved now), proper bitrate when using for capture in AVI_IO, compatibility with Vidomi, and better RGB to YUV conversion.
Bx ::
al pa mal pogledaš po DivX.com strani.
Bx
kateri program uporabiti za kompresijo videa v DivX formatu (delam iz DV AVI formata)
Oddelek: Zvok in slika
402914 (2166) nemesis
XP - media player - DivX problemi
151525 (1346) freserovski
Podnapisi
121880 (1496) zile
GeForce
211558 (1354) Huey P
novi divx codecs
202230 (1586) Kriko
