Forum » Strojna oprema » Error
Error
seminal ::
A problem has been detected and windows has been shut down to prevent damage to your computer.
If this is the first time you're seen this stop error screen, restart your computer, if this screen appear again, follow these steps:
Check to be sure you have adquate disk space. If a driver is identified in the stop message, disable the driver or check with manufacture for driver updates, try changing video adapters.
Check with your hardwear undor for any BIOS updates, disable bios memory optionssuch as caching or shadowing.If you need to use Safe mode to remove or disable components, restart your computer, press F8 to select Advance startup options and then select Safe mode.
Technical information:
*** STOP: 0x0000008e (0xc0000005, 0xbf805c5o, 0xf0d78664, 0x00000000)
*** win32k.sys - Addres BF805c50 base at BFF800000, Date stamp 422511 a2
Beginning dumo of physical memory
Physical memory dump complete
Contact your system administration or technical suspport group for further assistance.
To je moj problem
Že vnaprej se vam zahvaljujem za pomoč
To je moj problem
Good Guy ::
probi najprej palčke ndat v druge slote
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
| » | Problemi...Oddelek: Pomoč in nasveti | 2473 (1803) | Cifix63 |
| » | Ugašanje računalnika (samodejno resetiranjeOddelek: Pomoč in nasveti | 3035 (2390) | Aleš Ocepek |
| » | samodejni vklop in izklop računalnikaOddelek: Pomoč in nasveti | 2880 (2704) | RuskiSnajper |
| » | Sesuvanje računalnikaOddelek: Pomoč in nasveti | 1711 (1507) | Mitch |
| » | win 7 bsod - okvara matične ?Oddelek: Pomoč in nasveti | 2394 (2223) | vander |
