Catalyst 3.7 izšli
Catalyst 3.7 izšli
ATI - ATi zadnje čase izdaja gonilnike kot po tekočem traku, tako da so vam sedaj tukaj na voljo še vroči Catalysti 3.7, ki odstranijo nekaj nadležnih hroščev v igrah in nekoliko pospešijo izris slike. Tako naj bi ob uporabi glajenja robov (AA) v Unreal Tournamentu 2003 pridobili kar 23 odstotkov hitrosti. Če vas zanima še kaj več, si preberite komentarje ob izidu in spisek odpravljenih hroščev.
15 komentarjev
boštjan ::
no ja, ko vključim AA UT2003 šteka malo. 3dmark2001SE sem dobil najboljši rezultat do sedaj.Pa kdor še ni dol vleko,naj opozorim da naj vleče dol 22,3MB vlki paket.ker če bo driverje in CP posebej dol vleko,bo mel CP od c3.2
NF7-S,2500+@2200MHz,MSi 5900SP,LCD Philip 190X6,Maxtor DM+9 120GB SATA,
2*256 3200/A KHX, PSU 420W DF chieftek
kuglvinkl ::
Known Issues ( z 3.7)
The following section provides a brief description of known issues associated with the latest version of CATALYST™.
* When updating to future CATALYST™ releases your current color control panel profiles will be lost. This will be fixed in an upcoming CATALYST™ release
* Running the 3D Pipes screen saver for an extended period of time (24 hours or longer), produces an error message indicating that the virtual memory is not enough
* Setting the Landscape details to Perfect in the game IL2 Sturmovik Forgotten Battles results in the system not responding during track playback
* Playing the game Tiger Woods with the game options set to 1280x1024 32bpp and graphic parameters set to high results in the game failing to respond after the scorecard is displayed. This issue will be fixed in an upcoming CATALYST™ release
* Setting the game Flight Simulator 2004 to display at 1024x768 or 1280x1024 followed by starting a new flight results in the menu being flipped just before the new flight is about to begin. This issue will be fixed in an upcoming CATALYST™ release
* The CodeCreatures benchmark score drops by approximately 10-12% on DX8-class hardware (RADEON™ 9200, 9000, and 8500). This is due to a minor performance bug introduced in CATALYST™ 3.7. The issue is already resolved and a fix will be released in CATALYST™ 3.8. No other titles are known to be affected
pingo76 ::
Upam, da se bodo bolje obnesli kot 3.6! 3.6 so totalno destabilizirali moj sistem. Kar v prazno kdaj pa kdaj zmrzne. Fuj to. Sicer pa bi bil že čas, da bi spisali vsaj STABILNE drajverje raje kot neke leve preformance improvemente... :\
Naj jih kolkja...
ferdo ::
boštjan: od kje tebi ta podatek??
jzt mama instalerano... 3.5control panel verzija 6.14.10.5014 in
3.5XP driverje verzija 6.14.10.6360
3.7control panel verzija 6.14.10.5029
3.7 XP driverji verzija 6.14.10.6378
od kje tebi da maš zdej CP 3.2 verzijo???? ne prodajaj buč.
.: w w w . s l o - t e c h . c o m :.
.: I can`t believe the news today :.
tx-z ::
a so boljši od 3.5; pa itaq bom mogu počakat na adsl da jih dobim: do takrat bojo pa že novi :)
tx-z
CaqKa ::
Text no longer appears blurred when font smoothing is enabled and set to Standard. This issue was known to occur under Windows XP with a RADEON™ 8500 or 9100 series card installed
ne me jebat.. mater so dugo rabli da so to popravli... samo jaz mam r9000pro pa imam tele fonte zjebane...
ja res zaj so pa zamnjali nvidia in ati glede hitrosti izdajanja driverov
boštjan ::
ferdo,včeraj dol vleko driverje in CP posamezno in ko danes naložim je CP starejše verzije.Pa grem na rage3d in ugotovim da nisem edini stem problemom. nato pa dol potegnem skupen file driverjev,CP in AIW driverjev in ko naložim je vse tako kot mora bit. evo o tem govorim
PS.buč pa ne prodajam
nosferatu666 ::
ferdo, očitno ti je uspelo nemogoče, saj si potemtakem edini, mu je napačen CP delal pravilno :\
undefined ::
Kdor išče probleme, jih bo tud našel. Gonilniki preizkušeno delajo BP. :)
pingo76 ::
Iceman: Čestitam. Po 3.5 drajverjih imam kar lep problemček v 2d.
Ni lastnika ati kartice ki nebi imel vsaj kakšen problem. Razen če ne uporablja pc kot pisalni stroj.
ferdo ::
meni delajo brez problema.
igram UT2003 dela hitreje kot prej
Colin relly2
GTA Vice City
nobenih problemov
ferdo ::
pingo67: daj pojasni, kake probleme imaš.
jaz neuporabljam PC namesto pisalnega stroja. in dela OK
pingo76 ::
2D me juga. Po cat 3.5 mi tu pa tam (med igrami ne) zmrzne pc. Napako lahko reproduciram med čačkanjem po radeon tweakerju tja v tri dni, brez karkoli stweakat. No ja Gun metal tudi rad random flikne ven iz igre v kaki misiji. Imam pa še paleto drugih iger ki pa delajo kot urca. 2D je moj problem, in nisem edini (še zdaleč ne) tweak3d forum.
flipflop ::
Ne popravljaj če ni pokvarjeno,pravijo.
ferdo ::
lej, jzt sm instaleri 3.5 driverje, potem sem se pa lotu twekanja, pa sm vse zjebo...
sm reku: klinc gleda te tweak programe...instaleru jovo na novo samo driverje in basta! meni vse dela, tako kot treba, imam 3Drage za navijat in that`s all .
zdej mam pa 3.7 in isto delajo brez problema.
mam herculesa flashanga na 8500
pasivno hlajenje 275/300
na mami plati 8rda+
winXP professional sp1 in nekaj sp2 hot fix
in najbrš nisem edini ki dela vse brezhibno. kaj pa tweakte grafične:)
jzt sm jo sm 1x, in je jebalo, zdej pa nič več. kar naštimam je v control panel nastavitvah
če misliš, da boš s twekanjem kej naredu da bo bolje špilalo, si se očitno zmotu.
pregovor pravi: osel gre samo 1x na led
AMD izdal dodatno dokumentacijo za grafične kartice
345938 (3610) mile
Novi gonilniki za ATi-jeve kartice
323886 (3886) CaqKa
Catalyst 3.9 izšli
323203 (3203) Romčy
radeon 9100 128MB problemi
101389 (1255) freejack
