Router Level One FBR-1412TX zajebano!!!
Jaz prvič tako stvar delam in nič neznam s tem routerju :( A bi mi kdo celi postopek napisal za ta routek kako in kaj? Prosim ko res neznam:8) :8)
Lith ::
v navodilih piše:
1. Setup LAN connection: connect an Ethernet cable from your computer’s Ethernet
port to one of the LAN ports of this product.
2. Setup WAN connection: prepare an Ethernet cable for connecting this product to
your cable/xDSL modem or Ethernet backbone.
3. Power on:
Network Settings and Software Installation
To use LevelOne FBR-1412TX correctly, you have to properly configure the network settings of your
computers and install the attached setup program into your MS Windows platform (Windows
95/98/NT/2000).
3.1 Make Correct Network Settings of Your Computer
The default IP address of this product is 192.168.123.254, and the default subnet mask is 255.255.255.0.These addresses can be changed on your need, but the default values are used in this manual. If the
TCP/IP environment of your computer has not yet been configured,
1. configure IP as 192.168.123.1, subnet mask as 255.255.255.0 and gateway as 192.168.123.254,
2. configure your computers to load TCP/IP setting automatically, that is, via DHCP server of this
product.
After installing the TCP/IP communication protocol, you can use the ping command to check if your
computer has successfully connected to this product. The following example shows the ping procedure
for Windows 95 platforms. First, execute the ping command
ping 192.168.123.254
If the following messages appear:
Pinging 192.168.123.254 with 32 bytes of data:
Reply from 192.168.123.254: bytes=32 time=2ms TTL=64
a communication link between your computer and this product has been successfully established.
Activate your browser, and disable the proxy or add the IP address of this product into the exceptions.
Then, type this product’s IP address in the Location (for Netscape) or Address (for IE) field and press
ENTER. For example: http://192.168.123.254.
After the connection is established, you will see the web user interface of this product. There are two
appearances of web user interface: for general users and for system administrator.
To log in as an administrator, enter the system password (the factory setting is ”admin”) in the System
Password field and click on the Log in button. If the password is correct, the web appearance will be
changed into administrator configure mode. As listed in its main menu, there are several options for
system administration.
¤ black holes rule; I like the speed, speed kills ¤
Lith ::
navodila dobiš tukaj !!!
OmegaBlue ::
level one ROUTER FBR-1418TX- nastavitve
Oddelek: Omrežja in internet
476574 (3557) OmegaBlue
težave z level one fbr-1413tx
101912 (1793) steev
problem pri postavitvi omrežja
152150 (2050) Meamoto
LevelOne router FBR-1409TX
102029 (1880) ToniT
D-link mrk?
101391 (1231) alex32
