Forum » Programiranje » Še eno mysql vprašanje
lordgreg ::
delam na stvari previous in next..
imam stolpec ID, ki pa je primary key. je pa recimo finta, kako sploh spraviti PREJŠNJI PODATEK, če sem recimo na 5. 4-ke ni, ker je izbrisana, kako torej prit na podatke prejšnjega IDja???
darh ::
maš funkcijo mysql_insert_id(), ki ti vrne zadnji ID, ki ga je naredu SQL stavek "INSERT INTO db_name....."
mysql_insert_id -- Get the id generated from the previous INSERT operation
Description
int mysql_insert_id ([int link_identifier])
mysql_insert_id() returns the ID generated for an AUTO_INCREMENT column by the previous INSERT query using the given link_identifier. If link_identifier isn't specified, the last opened link is assumed.
mysql_insert_id() returns 0 if the previous query does not generate an AUTO_INCREMENT value. If you need to save the value for later, be sure to call mysql_insert_id() immediately after the query that generates the value.
Note: The value of the MySQL SQL function LAST_INSERT_ID() always contains the most recently generated AUTO_INCREMENT value, and is not reset between queries.
Excuses are useless! Results are priceless!
darh ::
oops.. jest sm mal zgresu.... mal sm narobe prebral kaj ti hoces sploh...
i gues.. .:)
mas IDje 1,2,3,6,7,8
sj, kaj pa je to problem, namest da direktno prstejes neo stevilko in jo pokazes kot next ali odstejes in pokazes kot prev, nardis tko:
use IDje ( oz une k rabs ) shrans u array..
da dobis neki tazga:
1: 1,
2: 2,
3: 3,
4: 6,
5: 7,
6: 8
pa ker ne mors rect nej ti gre na ID 4 od tabele, reces nej ti gre na ID 4 od arraya... :)
bluzim.. lahko noc :)
i gues.. .:)
1: 1,
2: 2,
3: 3,
4: 6,
5: 7,
6: 8
Gre-Gor ::
lordgreg lahko pa tud nekak tko nardis:
prev:
SELECT id FROM table WHERE id < '5' ORDER BY id DESC LIMIT 1
next:
SELECT id FROM table WHERE id > '5' ORDER BY id LIMIT 1
prev:
next:
http://www.delphi-si.com
lordgreg ::
obedve ideji delata, čeprav je zadnja hitrejša in preprostejša..
mi pač smo taki,.. nekaj lahkega je treba naredit, a mi zakomplicirama do kraja..
okej.,
hvala
okej.,
hvala
| » | [SQL] primary key inkrementalno dodajanje (strani: 1 2 )Oddelek: Programiranje | 9731 (8921) | ejresnevem |
| » | Težave z arrayOddelek: Izdelava spletišč | 1619 (1431) | Kricert |
| » | [PHP] moj forum :DOddelek: Izdelava spletišč | 1870 (1709) | medobear |
| » | portal ostal, baza slaOddelek: Izdelava spletišč | 2342 (2227) | bombacina |
| » | mySQL(+php) auto_increment field v tabeli.. Kako...?Oddelek: Izdelava spletišč | 1453 (1385) | Zzzzzzz |
