Dober brezplačen text editor (urejevalnik teksta)
b0B3k ::
Torej, iščem dober in brezplačen text editor (za Win), preizkusil sem že Context, Jedit in Crimson editor, pa me niso dodobra zadovoljili. Zdaj pa se obračam na vas, da mi pripomorete z vašimi predlogi. (mr. gugl je že bil uporabljen :) )
P.S. zelo bi bil vesel, če bi ob vašem predlogu lahko prebral še hiter opis oz. "feature-je" vašega predloga.
Predvsem je zame pomembna funkcionalnost. (ustrezalo bi mi nekaj takega kot npr. UE-32 )
OmegaBlue ::
Notepad, wordpad :]
stefanc ::
Notetab
Tole je iz helpa, light verzija je free, pro in std pa ne
Key Features
· Open and edit many documents at once, even huge files (only limited by system resources).
· NoteTab Pro: multi-level undo/redo.
· Text drag-and-drop editing.
· AutoCorrect/Auto-replace mode similar to Microsoft® WinWord.
· Supports MS-Office sound events.
· Fully configurable toolbar with flat or standard style buttons (more than 90 commands available).
· Commercial versions of NoteTab: Clipbars let you create your own custom toolbars.
· Fully configurable shortcut menu.
· Programmable. Add your own custom features using an easy script language.
· Web enabled: can open links and HTML documents in browser.
· Supports third-party Web tools: HTML Tidy, TopStyle, and CSE HTML Validator.
· Powerful Clipbook tool makes it easy to memorize and insert any kind of text in your document. Includes libraries for HTML tags, acronyms, smilies, etc. Can also be used for "shorthand" glossaries or to launch other applications.
· Commercial versions of NoteTab: Clipbars, to add your own toolbars to NoteTab.
· Innovative In-Context Clipbook reduces mouse movement and speeds up work.
· Integrates support for Perl and Gawk interpreters; scripts can be stored in NoteTab and applied directly to highlighted text or whole document.
· Can calculate (type a mathematical expression and NoteTab will calculate the result).
· Each document can have different settings such as font, tab widths, word wrap.
· Supports outline-type documents that help you organize your notes or any kind of information.
· Supports document templates.
· Can search/replace text in all open documents or disk files; accepts search tokens and regular expressions.
· Functions to convert text files to Web documents, strip HTML tags, sort lines, change case, process text in blocks, etc.
· NoteTab Pro: can highlight URLs, HTML tags, Clip code, and HyperLinks.
· Drag-and-drop image files from the Quick List tool into an HTML document creates image tags with the correct size attributes.
· Commercial versions of NoteTab: spell checker and thesaurus (requires the appropriate dictionary files).
· NoteTab Pro: insert up to 10 bookmarks per document.
· Automatic scrolling for hands-free reading of documents.
· Options to set margins, page numbering, headers and footers for printing jobs.
· Reformat text, including left and right justification.
· Text statistics (counts number of characters, words, and frequency of each word).
· Drag-and-drop files from File Manager or Explorer.
· Accepts multiple file names, including wildcards, passed as command-line parameters to the program.
· Quickly open files or directories from the Favorites list.
· Can capture text copied to the Clipboard from any application.
· Can read and write files in DOS ASCII, UNIX, EBCDIC, and Mac formats.
· Year 2000 compliant.
· Covers all essential features available in Notepad (including LOG).
goba ::
Metapad (50KB)
http://www.liquidninja.com/metapad/
metapad was created (as was Notepad) in pure ANSI C with the Win32 API.
It contained around 1200 lines of code as of version 1 and now has about
7000 lines as of version 3.0. Thus, it is almost as small and just about
as fast as Notepad is. Unlike some other so-called Notepad replacements,
metapad actually loads in an instant. (Those other programs tend to
approach 1 or 2MB instead of being under 100KB and are written using C++
with MFC or even, gasp!, Visual Basic.)
b0B3k ::
Poznate morebiti še kakega, ki bi imel tud text-highlight oz syntax type ? ( PL/SQL, C, Delphi ... itd.)
moj_nick ::
vim
110111001001010001010000
Caligula ::
A ma kaksen tud spellcheck?
moj_nick ::
  • spremenil: moj_nick ()
b0B3k ::
moj_nick Poskusi še z Jedit-om, pomojem ti bo všeč link
  • spremenilo: b0B3k ()
moj_nick ::
Glede na to, da se šele učim programirati in potrebujem text editor le za editiranje config datotek v Linuxu in pisanje TeX kode, je vim krasen ;)
dr.J ::
Če ne moreš izbrati text bloka (recimo od 5-9 vrstice in 33-53 stolpca) in ga potem premetavati po svoje, text editor ni vreden da ga pes povoha.
krho ::
b0B3k ::
hvala krho. PSPad zgleda orgazmično :)) , bomo še mal stestiral ...
marS ::
...no more heroes...
https://ecency.com/@seckorama
krho ::
Jaz sem povsod zamenjal UE-32 za PSPad.
Jebiveter ::
x/emacs - ni ga boljsega... sam kaj ko ne delajo sumniki (vsaj meni ne :'( )
Certainty of death. Small chance of success. What are we waiting for?
Caligula ::
Sm si kr openoffice gor vrgu pa sm zadovoljen.
smok3 ::
scite
http://www.scintilla.org/SciTE.html (za linux/win)
editpad
http://www.editpadpro.com/ (lite verzija je free - se mi zdi - za win)
b0B3k ::
Zaenkrat mi je PSPad najbolj všeč, hočem nekaj majhnega in zmogljivega. Ne maram, da se mi dolgo časa loada, prej ko ga začnem uporabljat...
Roadkill ::
ConText
TextPad
...takih programov je miljon. :)
Kateri urejevalnik texta za gradnjo spletnih strani?
Oddelek: Izdelava spletišč
282907 (2437) Road Runner
Text editor
Oddelek: Programiranje
71653 (1542) darkolord
Kater program je najboljsi za izdelavo spletisc?
101771 (1570) Ziga Dolhar
kak se na slohostingu postav forum in katerega?
392806 (2450) Klemenn
Izdelava internet strani
111680 (1469) webcreator
