Novice » Znanost in tehnologija » Google predstavil projekt nadgrajene resničnosti Project Glass
eric_cartman ::
Ker tisti ki hodijo s slusalko v usesu in se derejo na sogovronika na telefonu pa zgledajo povsem normalno, al kako?
Ti dam prav. Sam si useen ne predstavlam kako bodo ljudje s temi očali naokol paradirali. Bo treba verjetno sprobat. Potem pa bom zagotovo komentiral.
:P Do takrt pa se bom pustil presenetit.
roli ::
Itak mora reč projicirat reči na mrežnico, če se hoče izognit težavam s fokusiranjem.
Tako nekako ja. Tisti link od lumusa, ki sem ga pripopal v tejle temi lahko razsvetli situacijo. V glavnem ti se moraš fokusirat na nekaj karkoli drugega in ne na sam displey - nanj se niti ne moreš. Torej je to overlay čez sliko, ki jo vidiš. Nekako tako kot ogledalo. Če se boš fokusiral na ogledalo ne boš kaj dosti videl ampak se vedno fokusiraš na predmet, ki ga v ogledalu gledaš. Na engadgetu je nekje tudi video posnetek lumusovega modula s kamero kjer se to malenkost bolj opazi.
Mogoče še en quote s lumusovega FAQja:
Do you actually see through the video you are watching in the eyeglasses?
The choice is up to you. The image is displayed on the LOE, which is a transparent lens. When no image is on, you see through the LOE completely. When the image is on, you can select the brightness level, going high enough to completely block out the active area of the image, while still being able seeing around the image (giving you situational awareness). And, of course, the illumination is completely eye-safe. Alternatively, text and images can be displayed to appear as if they are "floating" over the wearer's view – this feature is especially useful for augmented reality applications. The trick their is on the image generation/ content side: by setting the image background to black (an inherently see-through color) and generating the words, symbols or images in bright colors, the floating effect is thus created.
Vsekakor upam da google cilja na nekaj takega. V nasprotnem primeru bi se pa rad dokopal do Lumusovega development kita. Klinc je ker je zadeva namenjena zaenkrat samo velikim OEM proizvajalcem.
http://www.r00li.com
- spremenil: roli ()
eric_cartman ::
Se pravi naj nošenje teh očal nebi bilo niti mal motece za uporabnika.
A je kdo kje zasledil podatek o ceni?
Zanima me tut kaj pomeni in kako bo razvidno ce bos izpostavljen mocni soncni svetlobi.
A bo potem tut display tako svetel, da bo kljuboval soncni svetlobi ali pa bo trik mogoce na zunanji strani ocal (da prepreci vdor svetlobe iz nasprotne smeri).
3furious ::
Posodobljena Googlova predstavitev z oglasi
In the age of information, ignorance is a choice.
eric_cartman ::
hehehe :P Potem zna še crashat.. Ti bo ob strani napisal system memory low. Pol ti bo pa bluescreen error gor vrglo.. :D
.:joco:. ::
več ali manj je vse le HUD
Realtime matchmoving.
Sam verjetno hardver (+software) še ne bo hmal zmožen tega.
"Is science true?"
You don't get it.
You don't get it.
antonija ::
Ubistvu je tko, da imas (vsaj pri lumusu) od strani vir svetlobe, ki pade na optiko, ki naredi zarke paralelne (torej kot da bi prihajali from far, far away) in jih odbije nazaj v oko (verjetno jih nekaj gre tudi skozi). Ce prav razumem je to dovolj, da clovesko oko, nastavljeno na "neskoncni fokus" zazna jasno sliko.
Cena za tisto drugo nalimano resitev (ne lumus) mislim da pise okrog 700USD.
ABX ::
Ultimativno res, ampak baje da je ta ST1080 glede tega izredno dober.
Glede oglasov ne vidim problem za ljudi ki se spoznajo. Če primerjaš trenutno situacijo z browserji, tisti ki obvlada lahko skoraj 100% odstrani to nesnago.
- spremenilo: ABX ()
M.B. ::
Zdaj pa je treba očala samo še z Šestim čutom združit, pa smo zmagali. Stvar je celo OSS.
- spremenil: M.B. ()
smash ::
ABX ::
Upam da bo 2013 leto VR. Takoj ko pride ven Oculus rift commercial version ga nabavim. Sploh če bo po 300E.
Testman42 ::
Predstavljen osnutek APIja in demonstracija uporabe
Jaz sem mislil da bo to bolj v stilu "SmartWatch za na glavo" kot pa podaljšek oblačne storitve.
(")_(") world domination.
- spremenil: Testman42 ()
| » | CES: BMW-jeva pametna motoristična čeladaOddelek: Novice / Ostale najave | 16451 (14294) | Fritz |
| » | Toshibin odgovor na Google GlassOddelek: Novice / Zasloni / projektorji / ... | 7281 (5812) | mitja_i |
| » | Znane specifikacije Google Glass (strani: 1 2 )Oddelek: Novice / Znanost in tehnologija | 27694 (23038) | dr.Akula |
| » | Razkrite manjkajoče specifikacije Google Glass, pridobljen rootOddelek: Novice / Android | 16604 (14007) | smash |
| » | Google predstavil projekt nadgrajene resničnosti Project Glass (strani: 1 2 )Oddelek: Novice / Znanost in tehnologija | 21946 (15791) | Testman42 |
