Forum » Navijanje » Volt mod pomoc
Volt mod pomoc
bozicek ::
Odlocil sem se, da dam temo sem, saj ima vec veze z navijanjem, kot z samim AC/DC.
Se opravicujem.
Moj R9600pro je dosegel mejo (550/340), zato sem se odlocil za Vmod. Ampak, kot popolni zacetnik rabim vaso pomoc pri tolmacenju necesa.
Copy/Paste:
The next step you need tot ake is calculate what value of resistance you need to apply to come out with the desired voltages. using 9.43k Ohms of resistance on the core gave me a 1.389V reading afterthe mod. If you decrease the resistance you will net higher voltages. a 7.8k Value resistance will give you roughly 1.4V. Going above 1.4v requires a better hsf. and going above 1.5v isn't such a good idea. For the memory lowering the resistance will also net you more volts. using a 12.23k ohm resistance resulted in a 2.91V to the mem. My samsung 2.86ns ram is specified to operate at 2.9V safely. DOing the vmem mod netting me 0 mhz. Other vref and etc. mods havne't worked for other people.
Some sample resistance -> voltages are: (thanks Jethrodude)
12k ohm = 2.88 vmem
10k ohm = 2.91 vmem
8.2k ohm = 2.95 vmem
6.9k ohm = 2.98 vmem
3.9k ohm = 1.52 vgpu
4.7k ohm = 1.48 vgpu
6.8k ohm = 1.4 vgpu
10k ohm = 1.36 vgpu
No izmeril sem koliko omov mi da moj radeoncek na mem in core, sedaj pa me zanima.
Recimo, da zelim imeti 2.98 na mem. Se pravi 6.9 ohm=2.98v
Ali moram jaz sedaj kupiti 7ohm uporcek in ga nalotati, ali moram kupiti recimo par 10ohm uporckov in jih toliko casa vezati zaporedno, da bo na koncu imel, ko bom meril ohm, skupni rezultat 6.9ohm.
Ce moram vezati uporcke, koliko ohm naj kupim?
Upam, da sem razumljivo povedal
Se opravicujem.
Copy/Paste:
12k ohm = 2.88 vmem
10k ohm = 2.91 vmem
6.8k ohm = 1.4 vgpu
10k ohm = 1.36 vgpu
Jackal ::
Najbolje bo, če kupiš trimer-potenciometer z več vrtljaji. S tem si lahko lepo poljubno nastavljaš napetost.
Takole sem jaz modificiral mojega Radeona 9600Pro
Vmod za VPU
Vmod za GPU
Uporabil sem 20kOhm potenciometre z oznako 43P, ki jih lahko dobiš v IC Elektroniki
Najprej sem nastavil upornost na maksimum, prispajkal upor in izmeril novo napetost. Potem sem pa počasi vrtel potenciometer tako, da se mu je nižala upornost in sproti meril napetost.
Glede Vmod-a na ramih ti svetujem, da najprej izmeriš privzeto napetost, ki je na RAM-u in si potem preračunaš, koliko je varna meja napetosti (okoli 5 do največ 10% čez privzeto vrednost - drugače tvegaš da boš skuril RAM - vem iz lastnih izkušenj)
Vmod za VPU
Vmod za GPU
Walking the way is something completely different than imagining the way.
- zavarovalo slike: OwcA ()
Jackass ::
Ok mene mal mede vse tole. Mam R9800SE AIW in bi rd spravu grafo do 9800XT.
Pa berm tle na forumu "ja sm naredu Vmod..." in js to berm in samo gledam. Sm v 3. letniku gimnazije in morm povedat, da se mi popolnoma nč ne sanja kako vi izvajate Vmod. Elektrike še nismo jemal tko, da zaenkrat moje znanje zajema samo U×I=P. Zato bom mogoče neki butastga vprašu zdej, ampak me ful zanima.
Kako veš kaj morš povezat (in umes dat upor)?
S čim nastavljaš trimer-je (to so verjetno kakšni nastavljivi upori)?
Predvsem zgornje vprašanje me zanima. Tm na grafični je namreč tolk stvari, da js glih ločm rame in GPU od ostalga.
jAcKaSS
bozicek ::
Superca. Hvala obema. takoj jutri v LJ po te trimercke.
Jackass: Kdaj pa mislis, da sem jaz nazadnje imel fiziko. Prelepa tri leta nazaj in se ne spomnim ama nic.
zato naredis tako kot drugi. Poisces na netu in sprobas.
Tuki je za tvojega. Delas pa seveda na lastno odgovornost:
http://www.ocfaq.com/article.php/overcl...
Samo na tej kartolini je tako slabo prikazano, da je joj. Na opisu za mojo je vse bolj trotel ziher
Jackal ::
Vsak čip rabi za svoje delovanje neko primerno napetost. Ker pa vsi čipi, ki jih imamo danes v računalnikih ne delujejo samo na 12V, 5V ali 3.3V, kolikor nam da napajalnik, je treba primerno napetost nekako dobiti iz teh, ki so nam na voljo. Največkrat je to izvedeno z nekaj MOS-FETi (Tranzistoji na poljski pojav), ki poenstavljeno rečeno delujejo kot nekakšni napetostni regulatorji. Potem pa je tu še en čip, ki skrbi za regulacijo teh MOS-FET tranzostorjev.
Ta regulator pa mora od nekje dobit vrednost napetosti, ki jo mora ohranjati in ponavadi je to izvedeno kar z uporovnim delilnikom (napetost se razdeli v razmerju uporov). V takem primeru je treba nekako spremeniti razmerje teh dveh uporov. Ker pa so ponavadi ti upori zelo majhni (fizično), je bolje da vzporedno k enemu od teh dveh uporov (tistemu, ki je vezan na 0V) vežemo še en upor. S tem zmanjšamo skupno upornost enega od prvotnih uporov. Zaradi zmanjšane upornosti je na sredini med obema uporoma zdaj drugačna (nižja) napetost kot pred vezavo paralelnega upora. Regulator tazna nižjo napetost in takoj bolj odpre MOS-FET tranzistor, da povišajo napetost. S tem se tudi poviša napetost, ki jo zaznava regulator, na privzeto vrednost. In tako v bistvu malo prelisičimo regulator za napajanje.
bozicek ::
Aja Jackal.
Koliko imas ti sedaj ohm, koliko si kaj pridobil in ali hladis?
Osebno ze imam gor svoja rebra in svoj hladilnik (BOX Barton) tako, da bom po moje sel kar na maximum.
Rami so trenutno na 12k in bom sel na okoli 8.5 medtem ko je cpu trenutno na 4k ohm.
Nimam vec dost fore.
Sem pa nasel na nekem forumu ko je nekdo fural to kartolino pri 750/350. Seveda ne na zrak
Jackal ::
Glede upornosti niti ne vem koliko je bila, ker sem meril napetost na kartici in nižal upornost na potenciometru.
Za VPU sem imel okoli 1.5V (iz privzetih 1.25V) in za ram 2.7V (Iz privzetih 2.5V). Pri RAM-u predvsem pazi, kakšno ima privzeto napetost, ker obstajata dve verziji tega Samsungovega ram-a. En deluje privzeto na 2.5V, drugi pa na 2.75V in če prvega dvigneš na kake 2.9V ali celo 3V lahko pričakuješ katastrofalne artefakte že pri samem zagonu, pri daljšem delovanju pa lahko s tem skuriš RAM.
Kartica je delovala z dvignjenimi napetostmi na: VPU - 620MHz, RAM - 384MHz (768DDR)
Pa še moje hlajenje:
Tole je vse, kar se lahko spomnem, ker kartice nimam več. Je bila srečno prodana novemu lastniku.
bozicek ::
No stvar je narejena. Core je sedaj na 1.48 in laufa pri 600MZh, medtem ko sem moral z memorije dati mod dol, saj mi je zacuda stvar slabse delovala.
No sedaj je 600/330 in smo veseli
| » | Problem z Volt modom na GF4 TI4200 (strani: 1 2 3 )Oddelek: Elektrotehnika in elektronika | 8972 (7480) | _Dejan_ |
| » | Homemade fan controler (strani: 1 2 )Oddelek: Elektrotehnika in elektronika | 13256 (11320) | SodVina |
| » | Zamenjava plate Abit NF7-SL ?Oddelek: Navijanje | 1444 (1303) | JIM22 |
| » | MouseMan modOddelek: Hlajenje in modifikacije | 2206 (1799) | burekar |
| » | voltazaOddelek: Pomoč in nasveti | 2367 (2063) | morphling1 |
