Forum » Operacijski sistemi » Samba pomoč
Samba pomoč
Aškerc ::
Namestil sem Sambo na RH9 in kot kaže deluje OK.
Na winxp vidim linux comp v mreži, a nimam dovoljenja za dostop.
Poizkušal sem že na vse načine s Server conig toolsi, pa mi nikakor ne uspe.
Mogoče kdo ve, kako je to potrebno nastavit. V win xp nimam nastavljenih nobenih gesel za mrežo.
Hvala
Hvala
borchi ::
em primer /etc/samba/smb.conf (predvidevam, da imaš zagnan samba strežnik, verjetno si napisal /etc/init.d/samba start al pa si ga zagnal v gui-ju:
#======================= Global Settings =====================================
[global]
netbios name = xxxxxxxx
workgroup = xxxxxx
server string = xxxxxxxxxx
bind interfaces only = yes
interfaces = eth0
printcap name = /etc/printcap
load printers = yes
max log size = 50
security = user
encrypt passwords = yes
smb passwd file = /etc/samba/private/smbpasswd
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
dns proxy = no
# WINS / VPN
preferred master = no
wins support = no
wins server =
# Other handy directives
# domain master = yes
# local master = yes
# os level = 65
# remote announce =
# remote browse sync =
#============================ Share Definitions ==============================
[printers]
printing = cups
print command = lpr -r -P%p -o raw %s
browseable = yes
printable = yes
public = yes
guest ok = yes
[shared]
comment = xxxxxxxx
path = /home/share/
valid users = root smbuser
writable = yes
public = no
printable = no
create mask = 0765
drugače pa imaš dobro komentirano v /etc/samba/smb.conf.
v mojem primeru imam dostop do share-anega direktorija za root in smbuser, ki ju moraš kreirati s:
za smbuser userja npr:
#smbpasswd -a smbuser
#smbpasswd -e smbuser
za začetek bi lahko zadostovalo.
[global]
workgroup = xxxxxx
interfaces = eth0
load printers = yes
max log size = 50
security = user
dns proxy = no
# WINS / VPN
wins support = no
wins server =
# os level = 65
# remote announce =
[printers]
printing = cups
browseable = yes
printable = yes
public = yes
guest ok = yes
[shared]
comment = xxxxxxxx
path = /home/share/
writable = yes
public = no
printable = no
create mask = 0765
l'jga
- spremenil: borchi ()
Brane2 ::
Je pa se nekaj. V tako konfiguriranem stroju mora imeti vsak tak samba user tudi veljaven unix account. Ko userja torej dodas s smbpasswd-om, ga moras dodati tudi z useraddom in mu dolociti veljaven login shell.
Brane2 ::
Netbios name je ime, pod katerim se Win mashina zaveda sebe. To je tisto ime stroja v grupi.
Pri sambi je lahko Netbios name enak kar DNS imenu stroja ali pa drugacno. Celotno poglavje v dokumentaciji za Sambo je posveceno problematiki imen.
Tako lahko uporabljas servise iz Unixa (DNS itd), lahko uporaabljas Wins, lahko uporabljas rocno napisane tabele ali pa kar Netbios name broadcast. Zadnji je najbolj butast, vendar dela O.K. v majhnih mrezah.
borchi ::
veljaven login shell? kaj misliš s tem? js mam za samba userje kreirane unix userje, ki nimajo shell accessa (-s /bin/false).
l'jga
MasterMind ::
Važn je, d obstaja. Seveda je pa najbolš, d nima shell accessa. (varnostni razlogi...).
Aškerc ::
Kot zaenkrat kaže, dela.
A mi prosim lahko še namigneš, kako naj skonfiguriram tiskalnik. Priključen je namreč na router CNet, za njegovo sheranje z win mašin sem moral naložiti nek print server.
V Linuxu je ta print server verjetno CUPS. Ko nastavim vrsto povezave CUPS in dodam IP routerja mi javi tole:
Network host 192.168.123.254 is busy.
INFO: connecting to 192.168.123.254 on port 631
Hvala za pomoć
Hvala za pomoć
Brane2 ::
Nisem reku login shell, ampak user account. Ja, lahko imas pac za login shell tudi /bin/false.
Aškerc ::
Še ena težava s Sambo.
Zadevo konfiguriram na drugem računalniku, naredil sem vse enako kot prej, ampak pride do naslednjega:
v winxp vidim linux računalnik v mreži, a nimam dostopa do njega
v linux rač. mi pri povezavi na mrežo napiše "Nisem se mogel povezati z gostiteljem localhost"
Če ima kdo od strokovnjakov čas, prosim za pomoč.
Hvala
Hvala
borchi ::
lažje ti bojo/bomo pomagali, če boš povedal, kaj ti napiše v samba log (verjetno v /var/log/samba/ ).
l'jga
| » | SambaOddelek: Programska oprema | 4806 (4098) | kiFni |
| ⊘ | Samba, Linux, Windows XPOddelek: Omrežja in internet | 2348 (2120) | hruske |
| » | Vaša smb.conf datoteka-nasvet?Oddelek: Operacijski sistemi | 1884 (1780) | Gh0st |
| » | LINUX+WIN2000Oddelek: Pomoč in nasveti | 2426 (1991) | tec |
| » | SAMBA problemiOddelek: Programska oprema | 1913 (1812) | simon |
