Forum » Operacijski sistemi » Vaša smb.conf datoteka-nasvet?
suse80 ::
Imam sambo, do katere dostopajo v glavnem Win 98 klienti. Trenutno nisem najbolj zadovoljen z datoteko smb.conf, čeprav sem prebral in preizkusil ogromno FAQ in podobne literature. Stvar mi sicer deluje, ampak bi rad videl še kak vaš primerek datoteke, če ni pretežko....
Obiščite stran o astronomiji ijn astrologiji http://www.mojevesolje.org
Gh0st ::
Moj:
[global]
workgroup = x
netbios name = x
server string = Samba Server
hosts allow = 127.0.0.1 192.168.0. 192.168.1. 192.168.2. 192.168.3. 192.168.4. 192.168.10. 212.103.154.
load printers = yes
printcap name = /etc/printcap
; printcap name = lpstat
; printing = bsd
guest account = x
log file = /var/log/samba.%m
; log level = 101
max log size = 1024
security = user
; password server =
; unix password sync = yes
encrypt passwords = yes
min passwd length = 4
username map = /etc/samba/usermap
; include = /usr/local/samba/lib/smb.conf.%m
socket options = TCP_NODELAY
; interfaces = 192.168.12.2/24 192.168.13.2/24
lm announce = false
local master = yes
os level = 65
character set = ISO8859-2
client code page = 852
domain master = yes
preferred master = yes
; domain controller =
domain logons = yes
# run a specific logon batch file per workstation (machine)
; logon script = %m.bat
# run a specific logon batch file per username
; logon script = %U.bat
; logon path = \\%L\profiles\%m\%U
wins support = yes
; wins server = 192.168.0.1
; wins proxy = yes
dns proxy = no
time server = yes
max open files = 128
case sensitive = no
preserve case = yes
short preserve case = yes
[homes]
comment = Home Directories
valid users = %S
browseable = no
writable = yes
create mask = 0644
[netlogon]
comment = Network Logon Service
path = /etc/samba/netlogon
admin users = x
guest ok = yes
browseable = no
writable = no
share modes = no
[profiles]
path = /etc/samba/profiles
browseable = no
guest ok = yes
admin users = x
;[printers]
; comment = All Printers
; path = /var/spool/samba
; browseable = no
; public = yes
; guest ok = no
; writable = no
; printable = yes
[hp4l]
comment = HP LaserJet 4L
path = /tmp
public = yes
readonly = yes
printable = yes
guest ok = yes
print ok = yes
print command = lpr -h -r P%p %s
;[hplj4l]
; comment = HP LaserJet 4L
; path = /tmp
; public = yes
; readonly = yes
; printable = yes
; guest ok = yes
; print ok = yes
; print command = lpr -h -r P%p %s
[data]
comment = Data
path = /data
browseable = no
writeable = yes
create mask = 0664
directory mask = 2775
[bicom]
comment = x
path = x
writeable = yes
create mask = 0664
[goldmine]
comment = x
path = x
writeable = yes
create mask = 0664
[clients]
comment = Clients
path = /data/clients
browseable = no
writeable = yes
create mask = 0664
[global]
workgroup = x
netbios name = x
load printers = yes
; printing = bsd
guest account = x
; log level = 101
max log size = 1024
security = user
; password server =
lm announce = false
local master = yes
os level = 65
domain master = yes
domain logons = yes
wins support = yes
; wins proxy = yes
dns proxy = no
time server = yes
case sensitive = no
preserve case = yes
[homes]
valid users = %S
browseable = no
writable = yes
create mask = 0644
[netlogon]
admin users = x
guest ok = yes
browseable = no
writable = no
share modes = no
[profiles]
browseable = no
guest ok = yes
admin users = x
;[printers]
; browseable = no
; public = yes
; guest ok = no
; writable = no
; printable = yes
[hp4l]
path = /tmp
public = yes
readonly = yes
printable = yes
guest ok = yes
print ok = yes
;[hplj4l]
; path = /tmp
; public = yes
; readonly = yes
; printable = yes
; guest ok = yes
; print ok = yes
[data]
comment = Data
path = /data
browseable = no
writeable = yes
create mask = 0664
[bicom]
comment = x
path = x
writeable = yes
create mask = 0664
[goldmine]
comment = x
path = x
writeable = yes
create mask = 0664
[clients]
comment = Clients
browseable = no
writeable = yes
create mask = 0664
you might start believe in Gh0st stories. you're in one. :)
suse80 ::
Uh, ta je pa zelo dolga.
Moja je taka: (samo pomemnejše postavke):
[global]
# ime serverja netbios
netbios name = serverime
workgroup = imeskupine
security = share
[public]
browseable = yes
path = /home/public
valid users = users
writeable = yes
create mask = 0660
directory mask = 0770
#debugiranje, za optimalno hitrost pusti 0, pri problemih 1-3
log level = 1
# ustvari po eno log datoteko za vsak comp, ki dostopa do sambe
log file = /var/log/%m.log
#ko ima server svoj dostop do interneta
interfaces = 192.168.0.0/16 127.0.0.1
bind interfaces only = yes
#kriptografija za gesla
#v primeru win95 klienta je bolje to izklopiti
#dovoljenje za uskladitev ure s serversko
time server = yes
#optimizacija socketa - lahko se izpusti
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_KEEPALIVE
SO_RCVBUF=8192 SO_SNDBUF=8192
#skrije datoteke,ki so v Linuxu deklarirane kot nedostopne
hide unreadable = yes
# opcija, ki naj bo False v primeru win clientov ter Accessa
oplock = False
level2oplocks = false
[global]
security = share
[public]
browseable = yes
path = /home/public
valid users = users
writeable = yes
create mask = 0660
log level = 1
time server = yes
oplock = False
Gh0st ::
Zanimivo.
Ne razumem tega:
Nedostopne za windows (kao non-executable for windows)?
Ne razumem tega:
suse80 ::
Ja, tudi meni se zdijo nekatere stvari weird. V zgornjem primeru sem sicer malo zamenjal global in drugo sekcijo, ampak point ni v tem.
Te parametre sem pobral na linku Unofficial Samba How-to , link sem dobil na samba.org. Ugotovil sem, da nekaterih parametrov moja verzija sambe sploh ne pozna...smbstatus mi vrne polno napak...
"#Unreadable files where the Linux permissions don't allow access won't show up in the client's file listings
hide unreadable = Yes
Zgornji parameter mi ne dela sploh, razen ko spremenim verzijo sambe v povsem tazadnjo, kar pa mi ne ustreza, ker pa potem eni drugi parametri ne delajo.
Sicer pa - sem stvar usposobil za osnovne potrebe.
Gh0st ::
Stvari, ki jih nepoznaš je najbolje odmisliti. Nekateri lahko izkoristijo to kot varnostno luknjo. Kako, nevem, ker to ni moje področje, pa tudi ne verjamem, da bi se kdo trudil vdreti prav v tvoj sistem.
Ampak za future reference je dor vedt..
| » | Samba (Debian mašina) + prenosnik = počasno kopiranjeOddelek: Omrežja in internet | 1286 (1182) | |Luka| |
| » | Pomoč pri sambi, hitrost prenosa je prenizka.Oddelek: Omrežja in internet | 1528 (1391) | gfighter |
| » | Samba pomočOddelek: Operacijski sistemi | 1715 (1553) | borchi |
| » | LINUX+WIN2000Oddelek: Pomoč in nasveti | 2426 (1991) | tec |
| » | SAMBA problemiOddelek: Programska oprema | 1911 (1810) | simon |
