Forum » Programiranje » Dev-C++ in napaka pri prevajanju funkcij
DanKick ::
Torej, kadarkoli uporabim lastno funkcijo, mi program javi opozorilo in se posledično ne prevede.
En primer, skupaj z napako prilagam.
Warning in function 'int main()'
'squ' undeclared (first use function)
in še program:
#include stdio.h
int main()
int x, y;
for(x = 0 ; x < 8 ; x++)
y = squ(x);
printf("The square of %d is %d\n", x, y);
for (x = 0 ; x < 8 ; ++x)
printf("The square of %d is %d\n", x, squ(x));
return 0;
squ(input)
int input;
int square;
square = input * input;
return(square);
in še program:
#include stdio.h
int main()
int x, y;
y = squ(x);
return 0;
squ(input)
int input;
int square;
return(square);
DMouse ::
Poskusi takole:
#include <stdio.h>
int squ(int);
int main(void)
int x, y;
y = squ(x);
return 0;
int squ(int input)
int square;
return square;
#include <stdio.h>
int squ(int);
int main(void)
int x, y;
y = squ(x);
return 0;
int squ(int input)
int square;
return square;
DanKick ::
Yep, tako pa gre.
Se pravi, da moram vse kasneje uporabljene funkcije definirati že na začetku, a ne?
DanKick ::
[Linker error] undefined reference to gx__personality_v0'
Torej, gre za enak program, mi pa javi compiler to napako. Ne vidim, v čem je razlika z zgornjim, bi pa rad vedel, v kakšnem primeru javi to napako.
Še program:
#include stdio.h
#include conio.h
int squ(int);
int main(void)
int x, y;
y = squ(x); /* go get the value of x*x */
getch();
return 0;
int squ(int input)
int square;
return(square);
Še program:
#include stdio.h
#include conio.h
int squ(int);
int main(void)
int x, y;
getch();
return 0;
int squ(int input)
int square;
return(square);
- spremenil: DanKick ()
Vesoljc ::
naredis lahko celo funkcijo pred mainom, ali pa le njen prototip (glavo)
sej to dela, neee?
int calc(int, int);
void main()
cout << calc(666,999);
int calc (int a, int b)
return(a+b);
sej to dela, neee?
Vesoljc ::
#include <iostream> using namespace std;
to je to...
drgač ti pa napako javu linker in ne compiler
sklicuješ se na nekaj, česar ne najde...
DanKick ::
Še vedno imam problem z linkerjem.
Če funkcijo na začetku navedem kot prototip, mi linker javlja napako.
Če celotno funkcijo prenesem pred main() pa stvar deluje.
Prilagam še primer z nedelujočim prototipom:
#include stdio.h
void fixup(int nuts, int *fruit);
int main()
int pecans, apples;
pecans = 100;
apples = 101;
printf("The starting values are %d %d\n", pecans, apples);
fixup(pecans, &apples);
printf("The ending values are %d %d\n", pecans, apples);
return 0;
printf("The values are %d %d\n", nuts, *fruit);
nuts = 135;
*fruit = 172;
printf("The values are %d %d\n" ,nuts, *fruit);
#include stdio.h
int main()
int pecans, apples;
pecans = 100;
apples = 101;
return 0;
nuts = 135;
*fruit = 172;
Vesoljc ::
meni dela
#include <stdio.h>
#include <iostream>
int main()
int pecans, apples;
pecans = 100;
apples = 101;
std::cin.get();
return 0;
nuts = 135;
*fruit = 172;
Vesoljc ::
- zavaroval slike: Vesoljc ()
MartnKrp ::
DanDick, po mojem mas ti napako v include stavku:
napacno:
pravilno:
napacno:
#include stdio.h
pravilno:
#include <stdio.h>
Vesoljc ::
imho jih je izpustil, zaradi sintakse foruma
DanKick ::
Vesoljc:
Dobro, mi lahko poveš, kje je razlika v programu, ki si ga "prepisal" in tistim, ki sem ga postal jaz.
Jaz jo namreč ne vidim, dejstvo pa je, da, če tvojo kodo kopiram v compiler, jo brez problema prevede
What the f... ?!?
What the f... ?!?
DanKick ::
MartnKrp: ha,ha, spremenil si mi nick ------> DanDick, ni slabo, moram priznat
Drugače pa ima Vesoljc prav. Znake pri include sem izpustil, ker so to rezervirani znaki v tem forumu.
Vseeno pa mi ni jasno, zakaj se koda od Vesoljca prevede, moja pa ne.
Vesoljc ::
vesoljc ma filling
vesoljc ma filling
MartnKrp ::
Primerjaj dele kode, znak po znak, nekje mora bit napaka!
Mogoce kaki skriti znak?
Ali pa prepisi vesoljcevo kodo in ne daj copy-paste.
| » | c++ datotekeOddelek: Programiranje | 4617 (4106) | Vesoljc |
| » | Kako bi izbrisal vrstico v neki datotekiOddelek: Programiranje | 1445 (1322) | DMouse |
| » | srand in program v Cju???Oddelek: Programiranje | 1903 (1773) | nuclear |
| » | Težave pri prevajanju kode z Borlandovim prevajalnikomOddelek: Programiranje | 1253 (1114) | DixieFlatline |
| » | Zanimiva C koda @ Win2K/XPOddelek: Programiranje | 1383 (1183) | wintermute |
