Forum » Programska oprema » Tweak XP Task manager disabled by administrator...wtf?!
Primoz78 ::
Pred par dnevi sem si probal instalirat Tweak XP pro pa sem se mal spilal not. Pol sem probal prit v task manager pa mi vedno mece ven opozorilo da je disabled by administrator...v rac. sem pa prijavljen kot edini administrator, nikjer pa nism dobil v Tweak XP-ju kje bi to lahko odstranil. Imam winodws XP Pro SP1, ista zadeva se mi pojavi ceprav sem odstranil Tweak XP Pro. A kdo ve kaj se dogaja oz. kje se da to poravit?
Lp Primoz
Lp Primoz
- premaknil iz Pomoč in nasveti: gkovac ()
Phoebus ::
To naredijo tudi eni virusi.
Click Start | Run.
Enter gpedit.msc at the command line and click OK.
This will open the Group Policy settings window.
Select User Configuration | Administrative Templates | System | Ctrl+Alt+Delete Options | Remove Task Manager.
Double-click the Remove Task Manager option from the Group Policy menu. You can then disable, enable, or set the policy to Not Configured. Remember: Since the policy in question is called Remove Task Manager, by disabling the policy, you are actually enabling the Task Manager. Disabling or setting this policy to Not Configured should alleviate Main's problem.
Click Start | Run.
| » | Tale tweak res pomaga?Oddelek: Omrežja in internet | 2508 (1645) | Izi |
| » | My computer izginil iz sistemaOddelek: Operacijski sistemi | 1929 (1791) | R33D3M33R |
| » | Ikone v win XP izginile po uporabi programa Spybot Search & Destroy. Kako dobiti ikonOddelek: Pomoč in nasveti | 2690 (2646) | riba43 |
| » | ctr+alt+del pomoč.Oddelek: Pomoč in nasveti | 1642 (1462) | Mercier |
| » | Omejen uporabnik na Windows XPOddelek: Programska oprema | 2390 (2145) | |SNap| |
